| Literati914 |
Nov 11 2025, 02:43 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
.. the fuel filter you still have under the engine shelf could be a problem. is it a high flow pressurized filter you have fitted there? they are larger diam metal cylinders. it is essential that it is one of those in the configuration you are describing you have. if its high flow it should be fine. standard type filter location would only be fit for purpose between tank and pump up front. must be before the pump. I've got a CarQuest 86012 under the engine shelf in the rear. It'a a metal can filter unit but I see no mention of high flow or being pressurize. Though I was getting 28-29psi before the regulator. (IMG:style_emoticons/default/confused24.gif) ? https://shop.advanceautoparts.com/p/carques...6012/10859986-P |
| wonkipop |
Nov 11 2025, 03:07 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,227 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
.. the fuel filter you still have under the engine shelf could be a problem. is it a high flow pressurized filter you have fitted there? they are larger diam metal cylinders. it is essential that it is one of those in the configuration you are describing you have. if its high flow it should be fine. standard type filter location would only be fit for purpose between tank and pump up front. must be before the pump. I've got a CarQuest 86012 under the engine shelf in the rear. It'a a metal can filter unit but I see no mention of high flow or being pressurize. Though I was getting 28-29psi before the regulator. (IMG:style_emoticons/default/confused24.gif) ? https://shop.advanceautoparts.com/p/carques...6012/10859986-P that will be a full flow high pressure filter looking at it on the link. thats what they look like. + you are getting pressure before the FPR correctly. i doubt your filter is causing any problems. or making your pump work too hard. (IMG:style_emoticons/default/beerchug.gif) |
| Literati914 |
Nov 11 2025, 06:08 PM
The FP is an Airtex 8445 iirc , perhaps it’s an intermittent issue with this particular unit.
Lo-Fi Version | Time is now: 12th November 2025 - 01:00 AM |
