| Superhawk996 |
Nov 12 2025, 12:56 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,735 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
what happens when you over-torque that oil screen? I assume you taking about something really odd as a one off like this http://914world.com/bbs2/index.php?showtopic=322065 Post #10. Where bottom of strainer wasn’t in right spot and blocked oil pickup? But that doesn’t happen from over tightening. That was a damaged or defective oil screen that is too close to the pickup. Likewise it would still result in low oil pressure light and I can’t imagine it lasting 800 miles before it would seize. Otherwise the threaded stud breaks and is a nightmare to fix requiring case disassembly, or the strainer nut would strip. Either of these should be obvious oil leaks. |
| tpines |
Nov 12 2025, 10:50 PM
Member ![]() ![]() Group: Members Posts: 82 Joined: 12-November 08 From: San Diego Member No.: 9,745 Region Association: Southern California |
So I went back over all my records:
Original 2.0 motor rebuilt with Keith Black 96mm p/c 8:1 compression. Kept stock cam and fuel injection Hydraulic lifters installed Rebuilt 4/23 500 mile break in oil change 6/23 6/ 24 3,000 mile oil change did not need to add oil during this time 7/25 3,000 mile oil change 11/2 Driving to work motor dies after adding 900 miles since oil change. No sign of oil all over the engine or anywhere else. I used VR1 the entire time. |
| mepstein |
Nov 13 2025, 06:08 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,535 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
You said you apparently ran low on oil. How low? How much oil left in the engine? Something is way off.
“Performance engines burn a lot of oil” really? Granted, we are building high performance 911 engines, not type 4’s but burning a lot of oil isn’t our experience. |
| tpines |
Nov 13 2025, 08:51 AM
There was probably half a quart to a quart left in the engine when we checked for any metal shavings. Which there were not thankfully.
| mepstein |
Nov 13 2025, 09:06 AM
| sixnotfour |
Nov 13 2025, 09:08 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,157 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
somebody forgot to Add oil...
| GregAmy |
Nov 13 2025, 09:16 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,643 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
That’s a lot of oil loss in (if I read correctly) 800 miles. That would make either one helluva mess on the floor, or one helluva smoke screen behind. Not something that could escape someone's notice. somebody forgot to Add oil... <Taps side of nose...> |
| davep |
Nov 13 2025, 09:24 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,359 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I am very sorry to hear of your engine failure, and it certainly does seem to be a mystery.
Was there much oil in the intake tract that might result from too much oil vapor in the engine venting? Were the spark plugs oil fouled, or the piston crowns with a lot of carbon? Can you tell if it was burning the oil? Were the piston ring gaps staggered or were they lined up? Were the gaps excessive? Were the rings properly installed? The bolt for the pulley on the side of the engine case (for the warm up flaps) goes into a through hole, so if missing you would have an open hole in the case. A friend forgot this and drove a thousand miles or so adding oil every few hours, but obviously leaving a smoke screen. The oil dripped on the exhaust so creating the smoke. Essentially, you should have an obvious leak or smoking a lot to lose that much oil in such a short distance. |
| Ninja |
Nov 13 2025, 09:35 AM
Member ![]() ![]() Group: Members Posts: 182 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
Kept stock cam and fuel injection Hydraulic lifters installed (IMG:style_emoticons/default/WTF.gif) This doesn't account for the missing oil... |
| emerygt350 |
Nov 13 2025, 09:49 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,475 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I wonder if you filled it with penetrating oil, drained it, refilled it with some cheap 30 weight and gave it a little tickle if you couldn't get it spinning again...
| Geezer914 |
Nov 13 2025, 09:56 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,242 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Who did the oil change?
| mepstein |
Nov 13 2025, 10:02 AM
That’s a lot of oil loss in (if I read correctly) 800 miles. That would make either one helluva mess on the floor, or one helluva smoke screen behind. Not something that could escape someone's notice. somebody forgot to Add oil... <Taps side of nose...> It happens... I won't put hood pins on my cars because I've seen too many people forget to replace them after opening the hood. I know I would forget at least once. |
| Jack Standz |
Nov 13 2025, 10:27 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 730 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
There was probably half a quart to a quart left in the engine when we checked for any metal shavings. Which there were not thankfully. That’s a lot of oil loss in (if I read correctly) 800 miles. Please don't take this as "piling on", just trying to understand the cause from the limited information we have read here. The statement that there was only 1/2 to 1 quart left in the motor and the oil pressure light never came on cannot be reconciled unless the oil pressure light was not working properly. Strongly urge that a mechanical oil pressure gauge is installed for startup of the rebuilt motor and use a working cockpit gauge. In addition, since the builder of your motor installed hydraulic lifters (with a used FI cam) in a 914 motor, this indicates yet another reason you should question their competency. |
| Artfrombama |
Nov 13 2025, 10:31 AM
Artfrombama ![]() ![]() Group: Members Posts: 433 Joined: 21-January 24 From: One of the chosen few Member No.: 27,870 Region Association: South East States
Since it was a new motor I didn't think I needed to check the oil
I think this explains the damage. Very sorry this happened, glad the damage was minimal. |
| Ottomotion |
Nov 13 2025, 07:22 PM
Member ![]() ![]() Group: Members Posts: 67 Joined: 12-January 23 From: Central California Member No.: 27,090 Region Association: None |
If the motor failed due to oil starvation, the oil had to go somewhere. Burning 4 quarts would seem like there would be something coming out the exhaust. Loosing 4 quarts would be on the floor....unless the loss was sudden...then there would be a trail on the road and an opening on the motor through which the oil would have departed.
Where did the oil go? |
| FlacaProductions |
Nov 13 2025, 09:15 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
I'm wondering if there was any in it to start - add in a non-functioning idiot light and....
Either way, it stinks but something doesn't add up here. |
| GregAmy |
Nov 13 2025, 09:36 PM
| tpines |
Nov 13 2025, 10:44 PM
Thank you all again for all of your advice.. I'm going to keep you posted on the outcome.
| wonkipop |
Nov 13 2025, 11:51 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,451 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
If the motor failed due to oil starvation, the oil had to go somewhere. Burning 4 quarts would seem like there would be something coming out the exhaust. Loosing 4 quarts would be on the floor....unless the loss was sudden...then there would be a trail on the road and an opening on the motor through which the oil would have departed. Where did the oil go? i'm with your observation. where did it go? if all else is reported correctly by OP then its a sudden (or fairly quick) loss of some sort. so how did it get out and from where? given its being said there was not much oil left in engine! oil change carried out. oil drain plug tightened correctly? crush washer? its got to have left the engine somehow? and it was fine up until oil change? |
| 930cabman |
Nov 14 2025, 01:19 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,532 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Losing an engine is never a good thing, and it really sucks I'm sure.
How did it run out of oil? smoking, dripping on the ground |
Lo-Fi Version | Time is now: 14th March 2026 - 12:20 AM |
