> Need Help- Cannot Remove Auxiliary Carrier, Trying to replace steering rack
Osnabruck914
post Nov 11 2025, 01:51 PM
According to the factory manual, you must remove the auxiliary carrier in order to have clearance to remove the steering rack. I have removed every bolt from the carrier plus the torsion bar adjusting lever arms, and I still cannot budge the carrier away from the A-arms. How is this accomplished? Urgent advice needed.
Osnabruck914
Osnabruck914
post Nov 11 2025, 06:19 PM
Nevermind. Solved my problem with a big screw driver used as a lever- carrier slid right off the bushings.
Osnabruck914
sixnotfour
post Nov 11 2025, 11:09 PM
(IMG:style_emoticons/default/first.gif)
Jack Standz
post Nov 13 2025, 10:57 AM
Proof again tht sometimes you just need a bigger hammer, or in this case a bigger screwdriver (IMG:style_emoticons/default/biggrin.gif) .
Good job! (IMG:style_emoticons/default/piratenanner.gif) !
- Lo-Fi Version Time is now: 7th December 2025 - 09:49 AM
