> Any suggestions?, Vapor lock? Or?
Ebradley
post Nov 28 2025, 10:56 AM
I have a 74(2.0) that has issues when it’s hot outside. I’ll drive it and then it won’t start or stalls when stopped. It tries to start crescendo like ramping up faster and faster and when it does I have to keep the RPMs going or it will die. I’ve never had a problem when the weather is not hot. Until today. I drove it this morning and it’s cold outside, and I’ve encountered the same issue. Any ideas? Vapor lock? Not even sure. Thanks.
chmillman
post Nov 28 2025, 11:42 AM
Region Association: Europe
QUOTE(Ebradley @ Nov 28 2025, 05:56 PM) *
Original D-Jet or onverted to carbs?
Ebradley
post Nov 28 2025, 11:53 AM
All original d-jet. Car has little over a 100k miles
FlacaProductions
post Nov 28 2025, 12:25 PM
collapsing/clogged fuel line or filter?
JamesM
post Nov 28 2025, 01:12 PM
Need more information to properly diagnose but at this point I don't consider any 914 reliable until it has had the fuel pump relocated under the tank. I also update to the later style 2 port pump as they are available new and relatively cheap. They are easier to plumb and given their age I think all 3 port pumps are questionable.
Other updates I make to the fuel system are to remove the plastic pre pump filter (VW started to do this in the mid 80s on Vanagons using the same pump to combat cavitation / pump starvation issues) and install a high pressure low micron post pump filter instead.
Not saying that is for sure your problem (or only problem) but its a known issue that should be addressed if you want a reliable car.
wonkipop
post Nov 28 2025, 01:48 PM
is it starting ok after being left over night?
and then being difficult after you have run it for a while?
this can seem like a hot start v cold start scenario but not due to vapor lock.
rather a blocked fuel line somewhere. either collapsed line or blocked filter.
if so i'd check out what @JamesM is hinting at.
if the fuel pump is in original location check the plastic cube fuel filter just before the fuel pump. under the car near the pump. could be clogged. good first port of call.
agree with @JamesM about installing a full flow high pressure filter after the pump.
check the eletrical connection to the pump. make sure its not corroded or loose.
Ebradley
post Nov 28 2025, 02:15 PM
I’ll check that. Thanks for the suggestions
Dlee6205
post Nov 28 2025, 02:33 PM
Since you're thinking it's fuel related, I would put a fuel pressure gauge on it to verify if that's your problem or not before replacing or moving anything.
FlacaProductions
post Nov 28 2025, 04:41 PM
Hey Doug @Dlee6205 - sent you a PM.
- Lo-Fi Version Time is now: 29th November 2025 - 03:02 AM
