> Engine Rebuild Cleaning Process, Need some advice please!
Aayala
post Dec 1 2025, 10:07 PM
Post #61
Good evening y'all,
Making some progress on my 914 1975 1.8L project and I was wondering if anyone had some workflows or do's and don'ts of how to properly clean the engine case and parts? I work a full time job and only have some time at the end of the day or maybe on weekends (hopefully more soon been insanely busy with life) to get to working on this.
I think I am in a "analysis paralysis" stage where I do not want to do something to the engine where it will ruin it. My big concern is using a wrong cleaner, leaving it too long, not properly following steps that might cause some damage or rust to the engine case itself. And dealing with both steel parts and aluminum parts I want to make sure to get the proper products for both. I am planning on maybe sending this to a machine shop but need to get it pretty clean prior to that. I also was wondering if I should take all of the head studs out of the case from both sides to clean it? Any resources or if someone has done this would be greatly appreciated!
I was thinking of soaking it in a plastic tote with the simple green hd pro degreaser and then scrubbing to get most of the gunk off, rinsing off with water and possibly break clean, then drying either with a leaf blower or getting my hands on an air compressor and maybe applying some wd40 or engine oil to prevent any rust? I also do not know how long I will be working on this so if there is a proper way to store it while I do this work that would be great.
Appreciate any advice you might have! Pics of the current state of the engine case for reference.
Attached ImageAttached ImageAttached Image
Aayala   Engine Rebuild Cleaning Process   Dec 1 2025, 10:07 PM
Ishley   I’m not a fan of the soak. Some of those cleaner...   Dec 1 2025, 11:02 PM
bdstone914   I think Simple green will darken the case. Dawn di...   Dec 1 2025, 11:20 PM
Aayala   I think Simple green will darken the case. Dawn d...   Dec 1 2025, 11:54 PM
930cabman   Welded oil galley plugs, that's a new one for ...   Dec 2 2025, 06:14 AM
Superhawk996   Welded oil galley plugs, that's a new one for...   Dec 2 2025, 07:30 AM
Puebloswatcop   Wow, Thats a first, I've never seen them welde...   Dec 2 2025, 08:40 AM
cgnj   Save a headache Scrap it. People have been able to...   Dec 2 2025, 09:17 AM
Aayala   Yikes... :( Well that is not something I was expe...   Dec 2 2025, 10:02 AM
930cabman   It's very possible to save this case and I wou...   Dec 2 2025, 10:21 AM
Aayala   It's very possible to save this case and I wo...   Dec 2 2025, 11:47 AM
Superhawk996   It's very possible to save this case and I w...   Dec 2 2025, 01:04 PM
Jamie   [quote name='Aayala' post='3235231' date='Dec 2 2...   Dec 2 2025, 01:12 PM
Superhawk996   In my non machining ignorance, what is the down ...   Dec 2 2025, 01:16 PM
Jamie   In my non machining ignorance, what is the down ...   Dec 2 2025, 01:50 PM
Aayala   In my non machining ignorance, what is the down ...   Dec 2 2025, 02:00 PM
Aayala   [quote name='Aayala' post='3235231' date='Dec 2 2...   Dec 2 2025, 01:56 PM
mepstein   I would let my machinists take care of it. Mill, d...   Dec 2 2025, 01:01 PM
930cabman   Locktite is semi permanent, meaning it will lock b...   Dec 2 2025, 03:07 PM
mepstein   Lock tight loosens with heat. A propane torch does...   Dec 2 2025, 03:20 PM
Ninja   ASE Master machinist is one of my credentials. Do...   Dec 2 2025, 03:21 PM
Aayala   ASE Master machinist is one of my credentials. D...   Dec 2 2025, 11:28 PM
Aayala   Got it! I thought that meant permanent. In r...   Dec 2 2025, 03:55 PM
Puebloswatcop   Got it! I thought that meant permanent. In ...   Dec 2 2025, 05:15 PM
Aayala   Got it! I thought that meant permanent. In...   Dec 2 2025, 11:31 PM
Puebloswatcop   [quote name='Puebloswatcop' post='3235267' date='...   Dec 4 2025, 09:17 AM
Aayala   [quote name='Puebloswatcop' post='3235267' date=...   Dec 9 2025, 09:44 AM
Jack Standz   Just some thoughts. These motors are 50+ years o...   Dec 2 2025, 04:41 PM
Jack Standz   Oh, one other thought. The type 1 VW guys are p...   Dec 2 2025, 04:49 PM
Aayala   Oh, one other thought. The type 1 VW guys are ...   Dec 2 2025, 11:29 PM
Jack Standz   Here's an inexpensive tool for stud removal, a...   Dec 3 2025, 12:59 PM
Jack Standz   2nd photo   Dec 3 2025, 01:01 PM
Artfrombama   A gallon of mineral spirits, a stiff bristled brus...   Dec 3 2025, 01:20 PM
Olympic 914   A gallon of mineral spirits, a stiff bristled bru...   Dec 3 2025, 01:39 PM
Jack Standz   A gallon of mineral spirits, a stiff bristled bru...   Dec 3 2025, 01:30 PM
Jack Standz   Good point. Use a brush that's sized appropri...   Dec 3 2025, 01:43 PM
930cabman   I am not a pro engine builder, but have been build...   Dec 3 2025, 02:31 PM
Jack Standz   :agree: Yes, thoroughly clean the engine during ...   Dec 3 2025, 03:09 PM
Superhawk996   Some might say that means you have to remove the ...   Dec 3 2025, 07:57 PM
Superhawk996   And here’s a picture of a tear down with a piece...   Dec 3 2025, 08:01 PM
Jack Standz   OK, fair enough. But, I have a type iv motor than...   Dec 4 2025, 12:22 AM
Superhawk996   In other words, most type iv motors over the ye...   Dec 4 2025, 01:23 AM
930cabman   OK, fair enough. But, I have a type iv motor tha...   Dec 4 2025, 05:54 AM
Aayala   If I am planning on first power washing the case f...   Dec 9 2025, 09:45 AM
mepstein   I would power wash it, wet it with degreaser, let ...   Dec 9 2025, 09:57 AM
Dlee6205   I would power wash it, wet it with degreaser, let...   Dec 9 2025, 11:56 AM
Aayala   PERFECT! I will try that! Yeah I need to f...   Dec 9 2025, 01:19 PM
930cabman   PERFECT! I will try that! Yeah I need to ...   Dec 11 2025, 10:27 AM
Aayala   PERFECT! I will try that! Yeah I need to...   Dec 11 2025, 11:52 AM
Superhawk996   I will hopefully get it back clean after oil gall...   Dec 11 2025, 08:41 PM
Aayala   I will hopefully get it back clean after oil gal...   Dec 12 2025, 10:13 AM
Aayala   sorry double posted somehow, not sure how to delet...   Dec 11 2025, 11:53 AM
Jack Standz   OK. Finally got around to pulling the three oil g...   Dec 23 2025, 05:34 PM
Jack Standz   photos:   Dec 23 2025, 05:35 PM
Jack Standz   photos   Dec 23 2025, 05:37 PM
Jack Standz   photos   Dec 23 2025, 05:38 PM
Jack Standz   photo   Dec 23 2025, 05:38 PM
Jack Standz   photo   Dec 23 2025, 05:39 PM
Jack Standz   Photo   Dec 23 2025, 05:39 PM
Aayala   Photo That doesn't look bad at all!...   Jan 2 2026, 04:17 PM
Aayala   Hello all, So.... I just got to cleaning the engi...   Jan 2 2026, 04:23 PM
mepstein   Probably a casting line. If you can smooth it out ...   Jan 2 2026, 05:59 PM
4 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
3 Members: Jamie, kplatt914, Highland
- Lo-Fi Version Time is now: 2nd January 2026 - 09:30 PM
