| Ron914 |
Dec 9 2025, 06:51 PM
Member ![]() ![]() Group: Members Posts: 481 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
In preparation and hope that I pass my smog test I want to go on the So. Cal.Toy Drive in my 914 on Saturday (not sure if this is a good idea) .
I need to address what I think might be a high oil temp problem . After driving around town for 30 minutes the photo shows my oil temperature oil gauge and a actual thermometer reading using a turkey fryer thermometer. The needle on my console gauge gets very close to the red high mark and sometimes just about to cross into the red . At this point the turkey thermometer reads ~216 F degrees . My Dakota Digital head cylinder temperature reads 111C (231F) . It is almost 80F here today in sunny So Cal. but this seems too high for me . What would be a normal reading for the oil temp gauge? This is a newly rebuilt motor (less than 300 miles on it). I did not replace the oil cooler (its original) but it was flushed and was clear. The baffles are held open by spring tension since the thermostat is not working but I checked they were open by removing the coil and checking through the bolt hole. This should be ok until I get a chance to replace it . If I pass my smog check tomorrow or Thursday I am hesitant to take the car on a long canyon drive , so not sure if I can attend the toy drive this Saturday. Any thoughts ? |
Ron914 High Oil temperature Dec 9 2025, 06:51 PM
brant It’s not broke in yet
It will come down if only ... Dec 9 2025, 06:59 PM
worn
It will come down if only... Dec 9 2025, 07:03 PM
brant
It will come down if onl... Dec 10 2025, 04:18 PM
Ron914
It will come down if only... Dec 9 2025, 07:53 PM
Superhawk996 Do you have the stock 200c temp sensor? Dec 9 2025, 07:38 PM
Ron914
Yes I do... Dec 9 2025, 07:40 PM
Superhawk996
Yes I d... Dec 9 2025, 07:47 PM
Ron914
[quote name='Ron914' post='3236265' date='Dec 9 2... Dec 9 2025, 08:07 PM
bkrantz 10W-30 might be too thin. Dec 9 2025, 08:01 PM
dtmehall what does your oil pressure run cold/hot, idle/at ... Dec 9 2025, 08:28 PM
Ron914
what does your oil pressure run cold/hot, idle/at... Dec 9 2025, 08:39 PM
Superhawk996 When the engine is cold (as in overnight cold) it ... Dec 9 2025, 08:51 PM
dtmehall superhawk
are you discounting that oil pressure m... Dec 9 2025, 08:57 PM
Superhawk996
superhawk
are you discounting that oil pressure ... Dec 9 2025, 09:08 PM
dtmehall :agree: Dec 9 2025, 09:13 PM
Superhawk996 Posting this just for clarity on how temperature, ... Dec 9 2025, 09:27 PM
Dave_Darling The temp gauge on the center console is not super ... Dec 10 2025, 02:45 AM
Geezer914 2056 motor, 9:1 cr., biral cylinders, Tangerine oi... Dec 10 2025, 07:17 AM
930cabman
2056 motor, 9:1 cr., biral cylinders, Tangerine o... Dec 10 2025, 04:03 PM
Geezer914
2056 motor, 9:1 cr., biral cylinders, Tangerine ... Dec 10 2025, 04:39 PM
Ron914
[quote name='930cabman' post='3236378' date='Dec ... Dec 11 2025, 08:59 AM
Ron914
2056 motor, 9:1 cr., biral cylinders, Tangerine ... Dec 11 2025, 08:53 AM
Superhawk996
I need to find a dual sender so I can hook up the... Dec 11 2025, 09:31 AM
930cabman
I need to find a dual sender so I can hook up th... Dec 12 2025, 06:55 PM
emerygt350 I agree with the 50 weight hypothesis. I would tr... Dec 11 2025, 07:20 AM
brant Too early for synthetic
I would put 1000 miles o... Dec 11 2025, 07:28 AM
emerygt350
I would put 1000 miles ... Dec 11 2025, 07:51 AM
Superhawk996 Because the receipt says oil pump and cover we kno... Dec 11 2025, 09:39 AM
Superhawk996 I’m also going to write this for your benefit de... Dec 11 2025, 09:49 AM
930cabman
I’m also going to write this for your benefit d... Dec 11 2025, 10:23 AM
73-914
I’m also going to write this for your benefit d... Dec 11 2025, 11:45 AM
JamesM
Tying to make an air cooled engines run at 180F... Dec 11 2025, 09:44 PM
Ninja
I’m also going to write this for your benefit d... Dec 11 2025, 03:29 PM
Ninja Sorry, forum's been glitchy for me recently... Dec 11 2025, 03:29 PM
Ron914
Sorry, forum's been glitchy for me recently..... Dec 11 2025, 05:24 PM
emerygt350 Getting the oil over 210, as mentioned is importan... Dec 11 2025, 03:46 PM
Ron914 I made a couple of more temperature readings when ... Dec 11 2025, 06:24 PM
Superhawk996
Thoughts of abandoning this project are floating... Dec 11 2025, 08:17 PM
emerygt350 I think the turkey thermometer is probably as good... Dec 12 2025, 06:07 AM
930cabman
I think the turkey thermometer is probably as goo... Dec 12 2025, 06:58 PM
Ninja
[quote name='Ninja' post='3236494' date='Dec 11 2... Dec 13 2025, 01:55 PM
Ninja The double post gremlin is very active with me now... Dec 13 2025, 01:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd March 2026 - 11:47 PM |
