| frank_c |
Dec 27 2025, 11:09 PM
Member ![]() ![]() Group: Members Posts: 83 Joined: 29-December 24 From: Austin, TX Member No.: 28,542 Region Association: None |
Today I started the process of dropping the engine & transmission so that I can send the transmission off to Dr. Evil and take care of some misc engine work (rear main seal, oil return tubes, etc. ). As part of this work I was also hunting for a clunking noise I hear from the back when the car is stopped and as I let the clutch out and the car just starts rolling forward. I already checked and/or replaced all suspension and engine mounts, as well as the outer CV joint bolts (inners are safety wired) and found nothing loose. So next on my list was either the CV joints themselves, or possibly loose flywheel bolts.
When I removed the inner CV joints from the transaxle flanges, I was surprised to see some pretty deep gouges in the flanges from the CV joint inner race/star (see photos below). This seems like a good candidate for the noise I am hearing. I have never seen this type of wear before with any of the other cars I've worked on - what would cause this? I noticed that there is not much grease in the joints, which I suppose is one possibility. Was the inner race put on backwards? Wrong parts? I did confirm that the axle shaft does move in and out freely at the outer CV joint. Thanks for any insight. Left flange: Right flange: Circled area shows where inner race is cutting into the flange. |
frank_c Flange Wear from CV Joint Dec 27 2025, 11:09 PM
Jack Standz "I have never seen this type of wear before w... Dec 28 2025, 12:37 AM
Superhawk996 That isn’t normal wear. The CV spider should ne... Dec 28 2025, 01:10 AM
bdstone914
That isn’t normal wear. The CV spider should n... Dec 28 2025, 01:58 AM
914Sixer It is a rare but I have seen in before in stock ax... Dec 28 2025, 06:56 AM
930cabman
It is a rare but I have seen in before in stock a... Dec 28 2025, 01:42 PM
Jack Standz
It is a rare but I have seen in before in stock a... Dec 28 2025, 01:23 PM
frank_c
The problem now is how to get replacement CVs if ... Dec 28 2025, 01:56 PM
Superhawk996
The problem now is how to get replacement CVs if... Dec 28 2025, 02:11 PM
frank_c First, I want to say thank you to everyone who has... Dec 28 2025, 06:19 PM
Superhawk996
[quote name='Superhawk996' post='3238548' date=... Dec 28 2025, 06:39 PM
bkrantz
The problem now is how to get replacement CVs if... Jan 15 2026, 08:38 PM
frank_c Thanks for all the responses. Please find my answe... Dec 28 2025, 01:45 PM
Superhawk996 “ Observation 1:
The inner conical washer has gr... Dec 28 2025, 02:03 PM
Jack Standz
"I have never seen this type of wear before ... Dec 28 2025, 02:44 PM
930cabman In the few years of my 914 "habit" I hav... Dec 28 2025, 04:04 PM
Jack Standz 914/4 axle length:
http://www.914world.com/bbs2/i... Dec 28 2025, 04:11 PM
frank_c
914/4 axle length:
http://www.914world.com/bbs2/i... Dec 28 2025, 06:54 PM
Krieger When I disassembled my 75 thirty years ago both my... Dec 28 2025, 07:36 PM
Krieger I kept these to use as tools. :D
Dec 28 2025, 08:00 PM
frank_c
Wow - thanks ... Dec 28 2025, 11:20 PM
IronHillRestorations Looks like witness marks from a broken CV in the p... Dec 29 2025, 08:21 AM
Superhawk996 Or even currently broken with a cracked cage we ca... Dec 29 2025, 11:32 AM
frank_c A quick update on this topic.
I got some time to ... Jan 8 2026, 12:32 AM
frank_c Another update on this topic. I disassembled and c... Jan 15 2026, 12:33 AM
930cabman just sayin, I noticed the "grease" in yo... Jan 15 2026, 05:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th March 2026 - 05:50 PM |
