3 Pages V < 1 2 3
> HEDALIGHT Disperate faulty, Unexpected fault
Spoke
post Jan 17 2026, 02:26 PM
Post #41
Jerry
QUOTE(Superhawk996 @ Jan 17 2026, 02:14 PM) *
3) We need to figure out why the passenger side relay is continuously being powered.
To figure out #3:
A) Remove the passenger side headlamp motor relay. Manually move the passenger headlamp to the full down position manually if necessary.
Perfect test! This is key.
Can I ask for information at this point? With Battery=ON, Key=OFF, Headlight=OFF, pass relay=OUT: measure voltage pass relay coil pin 85 to pin 86 while manually cycling motor UP and DOWN. Note when pin 85-86 voltage is 12V or zero V.
3 Pages V < 1 2 3
- Lo-Fi Version Time is now: 18th January 2026 - 10:03 AM
