Toby's Phoenix Red '74, Turns out orange can be red |
Tobra |
Nov 6 2006, 04:46 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Discovered the seat tilts, , so that is what that other lever does, who knew?
ConeDodger |
Nov 8 2006, 08:38 AM
Apex killer! Group: Members Posts: 23,612 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Have not added much to this thread in a while. Adjusted the clutch, checked the rear brakes and the clearance is right. Did my first auto cross today in Stockton, it was a hoot. Most fun I ever had for $35. Finally have a decent pic of the car with alloy wheels on it Went from 86 seconds to 76 seconds in five runs. Each run was about 2 seconds faster than the one before. I don't know what that means, but I improved every time, so that is good. Can't imagine the tires lasting very long if I keep driving it like this. Kind of fun to slide around a little, even if it slowed me down Toby, An improvement of 2 seconds a lap is great. With a proper alignment street tires tend to last a year or more with autocross use. Because they are narrow and you are doing some cornering in anger, they will tend to wear the outside edges first. You roll over onto the side wall and wear the edge. An alignment that includes negative camber will take away some of the tendency to wear in that way. Corner balancing is relatively cheap and effective as well. Some people who use their cars daily or nearly so, have a second set of wheels with autocross tires on them to mitigate the wear and get more time on the tires. This can be a slippery slope. A 914 with a good alignment, good tires, a front sway bar (at least) is all you need to have a good time with a nimble car. Once you start chasing TTOD, the money flows. It is really seat time that means the most. In order to improve your times to yours and the cars optimum, you need to spend lots of time in the seat driving it in anger. You can spend a half million on a Carrera GT and after you put in your best effort a guy with lots of seat time will better your best in your own car. Moral of the story is drive it. Enter every event you can get to . Better yet, get involved. I could use help with the events. Sorry I was so little help at that event. I didn't feel well so the best I could do was tow the trailer and set up the course... |
Tobra |
Mar 17 2007, 02:49 PM
Finally fixed the interior light, radio shack female plug crimped on wire, plugged in and voila, let there be light. Does not work when I open passenger door, probably dirty contacts, but don't care much. Put new license plate light on too, one that did not work was crumbling, one that did is crumbling but not corroded, like the driver's side, go figure.
Dropped $200 on a bunch of stuff I don't really need. Nice leather wrapped wheel with brand new rubber spring, won't go on until post painting. Nice steel front lower valence, rocker covers and little cover that goes over the master cylinder well. Picked up a spare transmission, including rear mounts, rear shift rod with coupler and little boot for the firewall too. The wife did not complain too much though. Been driving it a lot, which is good. Need to check my cone screws again, seems a little sloppy shifting oooh, pretty |
porschecb |
Mar 17 2007, 03:26 PM
Senior Member Group: Members Posts: 1,092 Joined: 13-August 04 From: Las Vegas NV Member No.: 2,529 Region Association: None |
Hey Toby! Where did get all those parts? (not to mention the money) (IMG:style_emoticons/default/biggrin.gif)
Tobra |
Mar 18 2007, 12:11 AM
What do you need Michael?
Went over and got them from my friend Jim, you want to put a 2 liter in your car, I think he has the right one with a fresh top end, he has a lot of stuff |
Lo-Fi Version | Time is now: 8th June 2024 - 12:16 AM |
