| Chaznaster |
Jan 20 2026, 06:31 PM
Member ![]() ![]() Group: Members Posts: 341 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States
Hi.
I am planning to address the grinding I get when going into 1st gear at anything faster than a full stop. The Pelican article on the replacing first gear seems pretty good, and I plan to search these pages for nuggets of wisdom before starting. This thing has been grinding as long as I have had it and certainly long before that ... so I figure it is in pretty bad shape. Pelican suggests the following parts: slider, shift fork, synchro ring and brake band, dog teeth, and maybe first gear if it is worn. I plan to open it up before getting parts - and I assume they are all available without much trouble. I'd appreciate your thoughts on tackling this project as well as any advice. Thanks. Christian |
| targa72e |
Jan 21 2026, 10:57 PM
Member ![]() ![]() Group: Members Posts: 307 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None
I have read in some other post about getting 1st gear syncro to work well, particularly when at full stop and trying to get into first, that there is a syncro that works better.
First gear syncro use part number 911 302 301 08 I have not used this before. When I rebuilt my transmission I put in new syncros on first and it works great if you are moving even the slightest. If you are at a full stop and the transmission is hot it can be difficult to get into first. Others have thoughts on this? john |
| rfinegan |
Jan 22 2026, 08:38 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,230 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
A little sneak peak of what is involved: youtube links to my repair:
https://youtu.be/sZVd2ldRjmk https://youtu.be/k5FpdBIMmJY https://youtu.be/zULWZD_DBvI |
| Chaznaster |
Jan 22 2026, 07:32 PM
A little sneak peak of what is involved: youtube links to my repair: https://youtu.be/sZVd2ldRjmk https://youtu.be/k5FpdBIMmJY https://youtu.be/zULWZD_DBvI These are great. Thanks! |
| Dave_Darling |
Jan 23 2026, 02:49 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,367 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Has anyone on this board ever down shifted from 3000 rpm in second gear to first, and had their tranny survive. No need to try. LOL! Just because the parts are there doesn't mean they're in good shape. And I'd be more worried about the engine and clutch than the trans at that point. --DD |
| Chaznaster |
Feb 15 2026, 02:43 PM
I finally found some time to tear into the transmission. The disassembly was pretty easy.
Dr. Evil's videos were worth every penny, even though I am not doing a full rebuild. It really helped me understand what goes on in that box when I shift gears and was a confidence booster for taking it apart. There was not much metal on the plug magnets. Some, but I was expecting a golfball of metal fuzz. It was tricky to not have the middle section of the transmission come off with the end. That took some careful tapping. The diagnosis and fix are clear - That dog don't bite, that's for sure (see pix). The slider teeth look like they have been smeared around. I'm certain I need new dog teeth, slider and synchro. Now to get parts ... ![]() ![]() ![]() ![]() |
| mepstein |
Feb 15 2026, 03:09 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,012 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
If first gear is gone, second is usually close behind.
| mlindner |
Feb 15 2026, 03:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,809 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
I do have the tools needed for a small rental fee. Mark
| jim_hoyland |
Feb 15 2026, 04:03 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,161 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
(IMG:style_emoticons/default/smile.gif) Nice pics, thanks for posting
| 914werke |
Feb 16 2026, 12:25 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,800 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Sucker is toast
| rudedude |
Feb 16 2026, 02:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 577 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest
If you haven't spend some time on the bird site and read about dog teeth from oem supplier that aren't ground quite right. The rausch and spiegel brand are correctly machined and fit to factory specs easily.
| ctc911ctc |
Feb 16 2026, 03:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,397 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
If first gear is gone, second is usually close behind. (IMG:style_emoticons/default/agree.gif) 2nd gear takes a great deal of abuse - NOT the gear but the slider and DogTeeth A good trick to save $$$ is to exchange the 2nd/3rd Slider with the 4th/5th slider. The 4th/5th parts are not treated to as much abuse and are in good shape in near all cases, Looking at your 1st Slider and DogTeeth pretty sure there are dogs barking from 1st to Second. GOOD LUCK! |
| Chaznaster |
Feb 16 2026, 05:40 PM
Thanks to all for the confirmation and advice.
I am going to be traveling in the next month so pulling the transmission for a complete rebuild is not going to happen this year. I'll stick with the "in the car" 1st gear fixes and make it in time for driving season to start. But I definitely get the point and it's on my project list. I'll check out the bird on the dog tooth gear issues. I'd prefer to get this right the first time. |
| ctc911ctc |
Feb 16 2026, 06:42 PM
Sent you a pm
Thanks to all for the confirmation and advice. I am going to be traveling in the next month so pulling the transmission for a complete rebuild is not going to happen this year. I'll stick with the "in the car" 1st gear fixes and make it in time for driving season to start. But I definitely get the point and it's on my project list. I'll check out the bird on the dog tooth gear issues. I'd prefer to get this right the first time. |
| Chaznaster |
Mar 1 2026, 02:21 PM
Today I separated the dog teeth and pressed in the new ones. It went really well.
Then I put some bright lights on the transmission to get the old gasket scraped off and saw something I wish I could unsee. The race of the bearing that sits under 1st gear is cracked in four places. Maybe a full rebuild is going to happen sooner than I had hoped. Like maybe now. Ugh ... ![]() |
| Ninja |
Mar 1 2026, 03:51 PM
Member ![]() ![]() Group: Members Posts: 323 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
You might have gotten lucky! (IMG:style_emoticons/default/ninja.gif)
Finding crap like that NOW, before it has trashed any shafts or the case means you could have a good core that just requires normal rebuild parts. I think you missed a bullet! (IMG:style_emoticons/default/beerchug.gif) |
| brant |
Mar 1 2026, 04:12 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,295 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Zzz you’re half way there and you have the videos. Can borrow the tools. Keep going
| Chaznaster |
Mar 5 2026, 07:20 PM
I am going to go for it. Will report back!
| Chaznaster |
Mar 30 2026, 05:30 PM
So I finally got around to dropping the engine in prep for tearing into the transmission. I have the engine sitting on a floor jack on a Tangerine Racing engine removal plate.
After searching, I could not find anything on separating the trans from engine. I am thinking to stabilize the engine mount bar with a few blocks of wood and but am not sure if that is the best approach. I'd appreciate any guidance you might be able to give. Many thanks! |
| Montreal914 |
Mar 30 2026, 06:25 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,229 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
Not familiar with the tangerine plate but the cross bar is stable.
I would remove the muffler (if stock banana) to clear the back and the muffler bracket. Remove the four bolts and pull the gearbox on a small movers dolly (harbor freight). Matching heights. (IMG:style_emoticons/default/confused24.gif) |
| Chaznaster |
Apr 6 2026, 06:22 PM
The transmission is off the engine. That was easier than expected.
I will start teardown this week. Does anyone know the bearing needed for the lower shaft on the 1st gear end? I cannot seem to find it in the PET. I see I will need to remove the plate that holds the bearing in. Are there any tricks to removing it or putting it back on? I have not seen the detail in the Dr. Evil videos. Thanks. |
Lo-Fi Version | Time is now: 22nd November 2026 - 03:05 PM |
