> Neo914 single piece door windows, the plan at least...
neo914-6
post Sep 5 2005, 12:57 AM
neo life
New Porsches have done away with "vent" glass as have most modern cars so this feature should be on the Neo914. Apparently this has been done by someone in AK but was too much custom work such that it required constant adjustment and the fabricator would not duplicate them based on these problems. The person telling me the information guessed the donor glass came from a Jeep. Miles claims one was done with Miata door glass but they come with a vent window like the 914…? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Installing them will require a triangle "filler" so the front rail will have enough space to be mounted and there will be more than a "point" of the glass in the rail. There are two metal pockets that strengthen the hinges and there is a door stop mechanism which will interfere with a rail at the forward side of the door. Since the door is relatively short, there is very little room for structure below the window to firmly hold the window upright in extension. Some doors actually bond a mount up on the glass for the lifter. If I can’t find an existing side glass that works I'll go ahead and cut a plexiglass piece to develop the lift mechanism. If there is enough interest I’d consider having them manufactured. I’ve got tooling estimates and they can produce them out of tempered or laminate glass. A kit may not be feasible since the door will require cutting and fabrication to fit the glass, rails, and mechanism. It would likely be a complete door with core charge.
neo914-6
post Sep 13 2005, 11:30 PM
neo life
I think they designed those doors so you can light your pipe's matchstick while driving (no working elect lighter) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
neo914-6   Neo914 single piece door windows   Sep 5 2005, 12:57 AM
neo914-6   The door and various pieces, including an electric...   Sep 5 2005, 12:59 AM
neo914-6   Here’s the door glass pieces, notice the "notch"...   Sep 5 2005, 01:00 AM
neo914-6   I traced a single piece template of the two pieces...   Sep 5 2005, 01:01 AM
neo914-6   I test fit the template on dozens of cars at a dis...   Sep 5 2005, 01:05 AM
neo914-6   VW, Volvos, and BMWs had lower rake. I didn’tâ€...   Sep 5 2005, 01:07 AM
Brent   What about MR2 or Fiero or similar? Saw many of th...   Sep 5 2005, 02:00 AM
redshift   heh damn if they aren't! I was told the gl...   Sep 5 2005, 03:08 AM
neo914-6     Sep 5 2005, 03:09 AM
redshift   <...   Sep 5 2005, 03:12 AM
Brent   <...   Sep 5 2005, 03:37 AM
neo914-6   <...   Sep 5 2005, 03:41 AM
neo914-6   Can anyone substantiate this: <...   Sep 5 2005, 03:49 AM
MecGen   Hi Felix I have been looking into this for about ...   Sep 5 2005, 03:49 AM
neo914-6     Sep 5 2005, 04:02 AM
neo914-6     Sep 5 2005, 04:04 AM
Brent   I can go and do the dirty work for you. I will tak...   Sep 5 2005, 04:06 AM
redshift   <...   Sep 5 2005, 07:05 AM
neo914-6   <...   Sep 5 2005, 11:19 AM
neo914-6     Sep 5 2005, 01:29 PM
Qarl   If you change the rake of the windshield, the targ...   Sep 5 2005, 02:48 PM
redshift   It will if you add material to the hoop, and secti...   Sep 5 2005, 02:50 PM
jonwatts   What about the curvature, isn't that a crucial...   Sep 5 2005, 03:00 PM
Brent   The MR2's were promoted to the compactor! ...   Sep 5 2005, 06:51 PM
redshift   Uhhmmm... Mr2... http://www...   Sep 5 2005, 06:57 PM
Tobra   <...   Sep 5 2005, 07:01 PM
redshift   A hot rod guy would make aluminum templates, wussi...   Sep 5 2005, 07:02 PM
neo914-6   <...   Sep 5 2005, 07:50 PM
cha914   Might want to take a look at early - mid 90's ...   Sep 5 2005, 09:09 PM
neo914-6     Sep 5 2005, 09:45 PM
neo914-6     Sep 5 2005, 09:49 PM
Aaron Cox   did you look at volvo 740/760's? they have a p...   Sep 5 2005, 09:55 PM
neo914-6   ...   Sep 5 2005, 09:59 PM
aircooledboy   Felix, First, you are wasting your time looking a...   Sep 6 2005, 02:55 PM
neo914-6   Chris, I am more confident because it's alre...   Sep 6 2005, 04:16 PM
aircooledboy   To be honest, when you said you had a quote for ma...   Sep 6 2005, 07:39 PM
neo914-6   That catalog could be usefull as long as they are ...   Sep 6 2005, 08:18 PM
aircooledboy     Sep 7 2005, 09:37 AM
redshift   are you sure it can't be cut with a water saw?...   Sep 8 2005, 01:23 AM
jonwatts   Yeah, I saw the Wonder Twins do it once. Or was it...   Sep 8 2005, 08:18 AM
Mark Henry   Even the one-piece windows kits for bugs are a PIT...   Sep 8 2005, 08:51 AM
aircooledboy   <...   Sep 8 2005, 09:34 AM
jonwatts   I appreciate the fact that you have 20 years of ex...   Sep 8 2005, 09:40 AM
aircooledboy   http://www.914world.com/bbs2/htm...   Sep 8 2005, 09:45 AM
neo914-6   Well I got the RX7 glass to test fit angainst the ...   Sep 11 2005, 02:48 AM
neo914-6   Here's the problem which is bigger than what c...   Sep 11 2005, 02:51 AM
neo914-6   Another is the overall size vs. the door space to ...   Sep 11 2005, 02:53 AM
neo914-6   And yet another problem to solve is having the cor...   Sep 11 2005, 02:55 AM
neo914-6   There may be the right shape existing but there ar...   Sep 11 2005, 03:08 AM
Andyrew   Is there no possible way to heat up the glass with...   Sep 11 2005, 08:52 AM
neo914-6   <...   Sep 11 2005, 01:22 PM
jonwatts   Ok, part of me hates this, but how about doing wha...   Sep 13 2005, 06:46 PM
neo914-6   ...   Sep 13 2005, 07:33 PM
redshift   ...   Sep 13 2005, 07:33 PM
redshift   You could put stationary/removable windows in, dit...   Sep 13 2005, 07:37 PM
neo914-6   http://www.914world.com/bbs2/...   Sep 13 2005, 07:48 PM
redshift   LOL! WhatSoEver! M   Sep 13 2005, 08:20 PM
jonwatts   Dude that was like 50 posts ago. If my memory were...   Sep 13 2005, 08:48 PM
redshift   ...   Sep 13 2005, 09:31 PM
Gary   ...   Sep 13 2005, 10:34 PM
neo914-6   ...   Sep 13 2005, 11:33 PM
effutuo101   I saw a body kit a long time ago for a convertable...   Sep 13 2005, 11:45 PM
jonwatts   So how does this SPA mirror fit with the 914 winds...   Sep 14 2005, 09:58 PM
neo914-6   First page last post here Supplied triangle is pl...   Sep 14 2005, 10:37 PM
neo914-6   Finally found and received a 996 Cab window mechan...   Nov 30 2005, 02:44 AM
neo914-6   with the "triangle" in front, the glass should loo...   Nov 30 2005, 02:47 AM
Air_Cooled_Nut   I'd rather have a working wing window like in ...   Dec 1 2005, 07:37 AM
neo914-6   I took apart the regulator mechanism and found it ...   Jan 10 2006, 12:33 AM
jonwatts   So where did we leave off with the actual door gla...   Jan 10 2006, 12:45 AM
neo914-6   Plexi for track development, Speedglass for show, ...   Jan 10 2006, 12:55 AM
neo914-6   Didn't know where to put the door panel fab so...   Nov 11 2006, 03:58 PM
neo914-6   Here's my first attempt at cold curving the si...   Nov 11 2006, 04:09 PM
vsg914   Neo, I'm a master cabinetmaker. It's what ...   Nov 11 2006, 04:45 PM
JPB   Sickly cool project bro. :trophy: Hope it works ou...   Nov 11 2006, 05:11 PM
neo914-6   I made and trimmed a black cardboard template befo...   Dec 3 2006, 01:29 AM
- Lo-Fi Version Time is now: 17th May 2024 - 08:25 PM
