Neo914 single piece door windows, the plan at least... |
neo914-6 |
Sep 13 2005, 11:30 PM
I think they designed those doors so you can light your pipe's matchstick while driving (no working elect lighter) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
neo914-6 |
Sep 13 2005, 11:33 PM
I hear ya, it's worse when there is proof that you cannot deny... (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
effutuo101 |
Sep 13 2005, 11:45 PM
Advanced Member Group: Members Posts: 2,734 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
I saw a body kit a long time ago for a convertable. I can't remember if the side windows were solid, but I know the front windscreen was raked back several degrees. Why not rake the windsheild and create a 911 style targa top? I think there was somebody in Las Vegas working on one.
jonwatts |
Sep 14 2005, 09:58 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
So how does this SPA mirror fit with the 914 windshield? Does it need to be modified? (the base looks like machined aluminum)
(IMG:http://www.914world.com/bbs2/uploads/post-2-1126661602.jpg) |
neo914-6 |
Sep 14 2005, 10:37 PM
First page last post here
Supplied triangle is plastic for a particular model but I need a fabricate metal triangle. |
neo914-6 |
Nov 30 2005, 02:44 AM
Finally found and received a 996 Cab window mechanism. I need to shorten the mounts and modify the cable lengths to make it work...
neo914-6 |
Nov 30 2005, 02:47 AM
with the "triangle" in front, the glass should look similar to:
Oh, and yes I will re-arch the top of the glass and top... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Attached image(s) |
Air_Cooled_Nut |
Dec 1 2005, 07:37 AM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
I'd rather have a working wing window like in my air-cooled VW. Windows rolled up, vent window cracked open, sucks the cigar smoke right outta the car. Doesn't stink up the car (only the driver (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) ).
neo914-6 |
Jan 10 2006, 12:33 AM
I took apart the regulator mechanism and found it a fairly simple design. Motor rolls cable so that two brackets move at the same time in one of two directions. They must have got the idea from SF cable cars. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) The cables ends will have to be shortened, ends crimped, and soldered after I shorten the track height. I got some ideas on how to do it from Motion Pro and Terrycable.
jonwatts |
Jan 10 2006, 12:45 AM
So where did we leave off with the actual door glass in this saga? Did you find a usable donor or are you going with Speedglass?
neo914-6 |
Jan 10 2006, 12:55 AM
Plexi for track development, Speedglass for show, molded bent glass if production worthy...
neo914-6 |
Nov 11 2006, 03:58 PM
Didn't know where to put the door panel fab so I thought I show them here. The pockets are BMW E36 and the door cores are fiberglass from Amity914. The core was cut, the pockets bonded to them, urethane foam transisiton, and then upholstered in leather. I still need to shorten and mount the 914 door latch.
neo914-6 |
Nov 11 2006, 04:09 PM
Here's my first attempt at cold curving the side window with a furniture clamp and aluminum L channel. My next step is to heat it with lamps as Rick-S suggested and maybe create a wood form for it.
TheCabinetmaker |
Nov 11 2006, 04:45 PM
Neo, I'm a master cabinetmaker. It's what i do. I make lots of radius pieces for many different things. I make them from a form that I build with only the radius' from an architect's drawing. Building a form from a 914 glass would be simple. You then take the form to a glass company and have them do the glass from the form.
JPB |
Nov 11 2006, 05:11 PM
Sickly cool project bro. (IMG:style_emoticons/default/smilie_pokal.gif) Hope it works out.
neo914-6 |
Dec 3 2006, 01:29 AM
I made and trimmed a black cardboard template before I got the plexiglass pieces cut
The upper aluminum window channel actually uses stock pieces cut down with another piece welded to hold a rubber weatherstrip. A triangular aluminum piece is welded to fill the void and mount the mirrors. A plastic sheet piece covers the interior void The lower is pinned, to the door with a simple construction bracket |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:18 PM |
