| Steve1956 |
Jan 30 2026, 12:23 PM
Newbie ![]() Group: Members Posts: 28 Joined: 4-November 22 From: Morocco,Indiana Member No.: 26,966 Region Association: None |
Ok,so Ive read a thread on the pros and cons of this. I have the 240 calipers installed and lines hooked up. they rubbed on my Pedrini style wheels so I bought 6mm wheel spacers and that fixed the problem. But recently bought a set Of Fuchs with Vredestein
tires that I want to run. The Fuchs rub the caliper,doubled up the wheel spacer and they still rubbed. Ground some clearance on the caliper frame to no avail. I saw a guy on one of these forums that was making brackets to move the caliper inward. This would solve both problems. Any thoughts? |
| rick 918-S |
Jan 30 2026, 01:36 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,184 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
IMHO unless you are increasing the unsprung weight (heavier wheels- larger diameter tires with an increased contact patch) Volvo 4 piston calipers are completely unnecessary. Pull those off and put the stock brakes back on.
| yeahmag |
Jan 30 2026, 01:45 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
Just to put this in perspective. I race with 911 M calipers and good pads. Unless racing with big HP those are unnecessary. If you are racing, you'll find yourself more focused on heat management than the number of pistons.
| infraredcalvin |
Jan 30 2026, 03:38 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,717 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
I'm failing to understand how you move the caliper back without the rotor moving. Unless we're talking about a mm or so of clearance, you can't move the caliper much without moving the rotor with it.
Easiest solution would be to use a larger spacer if you have the fender clearance... |
| Ninja |
Jan 30 2026, 04:05 PM
Member ![]() ![]() Group: Members Posts: 89 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
Nother problem will be fluid volume. You will change brake bias BADLY to the rear if the caliper volumes are different. Even on the 914-6 (bigger volume front caliper) Porsche changed the master cylinder size, rear caliper piston volume, and what they use as a proportioning valve. That prop valve is special. It's not "normal" like most. It was made special to keep the rear brakes from EVER locking as too much rear brake bias can exacerbate handling issues that most mid/rear engine cars face (trailing throttle oversteer). Just changing the front calipers to much larger ones will likely degrade your overall braking performance, maybe dangerously. I'm going Boxster all way round AND changing master to 20mm+ to closely mimic the original Boxster configuration. I have not seen "Volvo calipers mod" before, don't know what size the Volvo pistons are but all of the 4 piston calipers I've researched require careful balancing of all of the brake hydraulic system. Real 914-6 rear calipers are $$$$ but PMB makes modern clones that are significantly more affordable. The 914-6 rear caliper will pair OK with Boxster fronts and allow stock E-brake stuff. The rear Boxster calipers require early 911 e-brake stuff/ fabrication on trailing arms, and some special bits. I'm still leaning towards the Boxster stuff... |
| mepstein |
Jan 30 2026, 05:14 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,370 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
(IMG:style_emoticons/default/agree.gif) Nother problem will be fluid volume. You will change brake bias BADLY to the rear if the caliper volumes are different. Even on the 914-6 (bigger volume front caliper) Porsche changed the master cylinder size, rear caliper piston volume, and what they use as a proportioning valve. That prop valve is special. It's not "normal" like most. It was made special to keep the rear brakes from EVER locking as too much rear brake bias can exacerbate handling issues that most mid/rear engine cars face (trailing throttle oversteer). Just changing the front calipers to much larger ones will likely degrade your overall braking performance, maybe dangerously. I'm going Boxster all way round AND changing master to 20mm+ to closely mimic the original Boxster configuration. I have not seen "Volvo calipers mod" before, don't know what size the Volvo pistons are but all of the 4 piston calipers I've researched require careful balancing of all of the brake hydraulic system. Real 914-6 rear calipers are $$$$ but PMB makes modern clones that are significantly more affordable. The 914-6 rear caliper will pair OK with Boxster fronts and allow stock E-brake stuff. The rear Boxster calipers require early 911 e-brake stuff/ fabrication on trailing arms, and some special bits. I'm still leaning towards the Boxster stuff... Tangerine Racing has a kit to add a 911 rear e-brake. It's about $150 and you use stock 911 parts. No fabrication and just a couple easy welds to make it work. I did it on my suby conversion car that got M calipers and just bought another set since I'm using Boxster calipers f&r on my GT car. PMB's GT calipers are the easiest and best "bolt on" solution. |
| porschetub |
Jan 30 2026, 09:05 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,012 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Waste of time trying to make these work ,many things previouly mentioned , there are better options without the hassle like stock front calipers for example they in good condition work pretty well ,cheers.
Lo-Fi Version | Time is now: 30th January 2026 - 10:31 PM |
