| TonyA |
Mar 10 2026, 04:28 PM
Nachmal ![]() ![]() ![]() Group: Members Posts: 654 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States
Is there a special way to remove an oil pressure switch on a 2.0. I am worried that i may drop it behind the tin.
| FlacaProductions |
Mar 10 2026, 05:32 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,168 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
Interesting - I took mine out and replaced it with a hose for a remote "block" in order to use both a sender for the idiot light as well as one for a gauge. I think it's a 24mm - but I don't remember anything special to avoid dropping it behind the tin....maybe i just got lucky?
| Shivers |
Mar 10 2026, 07:02 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,315 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Is there a special way to remove an oil pressure switch on a 2.0. I am worried that i may drop it behind the tin. If I can not find my spark plug socket, I will use a strip of cardboard from the spark plug box and wedge the plug into the socket. You can remove them the same way. Just a thought |
Lo-Fi Version | Time is now: 10th March 2026 - 07:16 PM |
