> 14 Pin Relay board connector, Same for all cars?
914werke
post Mar 16 2026, 07:05 PM
Typically ..Im troubleshooting a Cust. car were someone thought it was a good idea to hack off pins & reroute circuits (IMG:style_emoticons/default/WTF.gif)
Did a bit of searching for the correct position & color coding of the contained wires.
I have a couple of cars around here that I could pull the cover off to check (IMG:style_emoticons/default/wacko.gif)
but its dark & raining & Im lazy. (IMG:style_emoticons/default/ar15.gif)
The question du jour is do all chassis harnesses have generally the same wire color scheme ?
I did notice some use a solid Yellow vs Yellow w/ red for Pin #1 but the rest seems
pretty consistent, except for Pin #6 = Oil temp (Grn w/black)
Some cars have it others dont (empty) is this normal?
(IMG:style_emoticons/default/slap.gif)
TRP
post Mar 16 2026, 08:08 PM
This is a question for @JeffBowlsby , He has probably seen more wiring harnesses than anyone!
post Mar 16 2026, 08:29 PM
Resident German
There's at least two versions (early vs. late) (might even be three) with several different wires.
JeffBowlsby
post Mar 16 2026, 10:03 PM
I know that 14pin connector circuits has differences between some of model years. Recommend checking the schematics for model year specifics.
3 User(s) are reading this topic (2 Guests and 1 Anonymous Users)
- Lo-Fi Version Time is now: 17th March 2026 - 12:52 AM
