> MPS tunning, Do my plugs seem to lean
Ron914
post Mar 17 2026, 04:17 PM
I have a 2056 and was advised I should tune my MPS for optimum performance .
I rebuilt it with CFR diaphragm kit so I could dial it in .
I have not tried to tune it yet and am wonder how my plugs look ?
I have to richen the mixture on the ECU to run well (CW).
I understand running lean will cause high heat , which could be part of my problem with high running temperatures .
They look on the rich side to me .
Plugs are in order 1-4 (#3) does not have the number on it.
worn
post Mar 17 2026, 04:22 PM
They look about right to me, but you may want to be richer than OK with a 2056. These days an A/F gauge is not that expensive and you can get a bung that clamps on so you do not have to weld. Then you can chase cylinder head temps for #3.
I talked to George Hussey several years ago and as I understood it he suggested that the CHT gauge would simply frighten me most of the time. Apparently you don't have to actually melt the aluminum to cause trouble.
rjames
post Mar 17 2026, 04:42 PM
I'm made of metal
What Worn said. You'll need a wideband AFR kit to properly tun it.
Montreal914
post Mar 17 2026, 05:24 PM
QUOTE(Ron914 @ Mar 17 2026, 03:17 PM) *
If you are referring to the knob on the ECU, that is only for the idle and has no influence on normal driving (gets canceled).
If I recall, there are no adjustments on the DJet ECU.
FlacaProductions
post Mar 17 2026, 06:39 PM
Re: MPS tuning - this will get you to post 12 of a good thread that you might want to scroll to the top of - but the chart shown there has helped me getting my head around MPS tuning. I do have a CHT under #3 and an AFR (which i resisted for a while but has proven really really handy for tuning...)
http://www.914world.com/bbs2/index.php?s=&...t&p=2963536
My AFR - bluetooth so you don't have to put another gauge in:
https://pe-ltd.com/product/wideband/
emerygt350
post Mar 17 2026, 06:55 PM
Ron, those look pretty good.
Besides the afr and cht and the plugs, just keeping track of mpg can tell you quite a bit too.
brant
post Mar 17 2026, 07:17 PM
You really have to use an AFR
Plugs are not sensitive enough to get it correct
Plus you need to read wide open throttle for real safety of the ratio (and heads). So plugs won’t work
Superhawk996
post Mar 17 2026, 07:36 PM
The color of the ceramic electrode insulator is what matters.
Those look really good.
- Lo-Fi Version Time is now: 18th March 2026 - 02:24 AM
