used AutoX tires value |
GaroldShaffer |
Aug 1 2003, 11:13 AM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
As part of a deal for my new 914 I was offered a set of used Hoosier on steel rims. The current owner of my car used them once (so he says) for one Auto X. What do you think there value would be??? I never Auto X before but it is something I would like try. what do you think?
MJHanna |
Aug 1 2003, 01:46 PM
Does this 911 make my butt look big? Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
It depends on how old they are. Consider them worth less except for the wheels and they are worth 10-20 bucks each?
campbellcj |
Aug 1 2003, 02:38 PM
I can't Re Member Group: Members Posts: 4,543 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
If they are essentially "just scrubbed in" (1 short event)....AND haven't been flat-spotted then they are worth a few hundred bucks. They would cost $700 to replace new.
BUT...if they sat out in the sun/heat for a long time and/or are several years old and/or were flat-spotted or abused, then they are basically worthless. Very tough call -- you have to look at tires in person to get any kind of sense of condition and that is still not easy. Well used race/autox tires toward the end of their life are typically like $20-50/ea... |
airsix |
Aug 1 2003, 02:54 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Hey, let's hear some more about tire aging. This topic has been on my mind lately. When does race rubber become "too old" assuming there is still plenty of matterial left? How about street tires? I ask because I've still got some good tread left on my SP8000's but they just don't feel as grippy as they used to be, say 2 years ago.
If I bought say, some Victoracers just for autocross, and assuming I only did a few events each season with them at what point would they be thow-aways? I assume they'd loose grip from age before wearing out. FYI the winters are mild here, humidity is low, and the summers are very very hot, so even just sitting in the garage the tires would see >100F regularly. This is of course all purely hypothetical - if I buy a set of race rubber I'll feel obligated to do enough events to wear them out before they are too old. (IMG:style_emoticons/default/wink.gif) -Ben M. |
SirAndy |
Aug 1 2003, 03:09 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(airsix @ Aug 1 2003, 01:54 PM) Hey, let's hear some more about tire aging. the rubber gets harder when it ages. softer rubber = more grip harder rubber = less grip exposure to sun or heat does the same. racing tires are even more vulnerable because they're very soft to begin with. so, if they have been sitting for a while, they're probably toast. Andy |
mskala |
Aug 1 2003, 04:38 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
QUOTE(airsix @ Aug 1 2003, 03:54 PM) If I bought say, some Victoracers just for autocross, and assuming I only did a few events each season with them at what point would they be thow-aways? I assume they'd loose grip from age before wearing out. I'm in the middle of the 3rd season with the Kumho's, about 20 events I'd say, plus 50 miles each way to the events, and still grippy and still rubber left. |
URY914 |
Aug 1 2003, 08:04 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,411 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
What also kills tires is "heat cycles". If the runs are slow and no heat is generated-it is less damaging than if you drove several very hot runs. Heat is the killer.
And Hoosiers also breakdown from UV more than orhers I've found. The sidewalls start to crack. Thats why you see guys putting them in plastic garbage bags to store them. There is an additive they put in the tire compound that protects the tire from UV rays. That why trailer tires can sit outside without cracking. But Hoosier doen't put it thier tires. Paul |
EdwardBlume |
Aug 1 2003, 11:22 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I'd knock the tires down if they weren't stored properly or aren't properly balanced. You don't know what you are getting, so don't make the guy rich.
Then again, having race tires are well worth the money in times, and enjoyment. Go for it!!! |
Demick |
Aug 3 2003, 03:53 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
QUOTE(airsix @ Aug 1 2003, 12:54 PM) If I bought say, some Victoracers just for autocross, and assuming I only did a few events each season with them at what point would they be thow-aways? I assume they'd loose grip from age before wearing out. Unless you are super competetive, they are throwaways when they look like this. This is how mine looked after the autocross yesterday. They are about 4 years old. For the last 2 years I've treated them with Formula V tire treatment before each event to try and keep them sticky. They worked well until they corded. Attached image(s) |
ChrisReale |
Aug 3 2003, 04:43 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Id say its time for a new set of shoes (IMG:style_emoticons/default/laugh.gif)
Lo-Fi Version | Time is now: 6th May 2024 - 01:46 PM |
