| robkammer |
Mar 29 2026, 07:30 PM
Robbo ![]() ![]() Group: Members Posts: 258 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: NineFourteenerVille |
Teeners, or Brain Trust if you prefer. While I have the engine out of the BB I would like to address the rear ride height if it’s fairly easy. The Koni’s came with the car, and the rear height is almost an inch lower than I would like it, although the shocks seem to be performing well. To me, it looks like I might be able to add spacers to the lower perch, if I can find some. Or am I not seeing the geometry correctly? If this would work, any idea where I can source the spacers?
Robbo |
| bkrantz |
Mar 29 2026, 07:41 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,645 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
It looks like the spring perch is adjustable. If so, the collar around the shock body has grooves and a snap ring that sets the height of the perch section. Move the ring and perch to a higher groove and raise the ride height.
| Literati914 |
Mar 29 2026, 07:43 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,234 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Got a picture of the car's stance, as-is ? - I'm just curious where it sits now.
I have some spacers that I just took off of a set of Konis, but the engine is out and so I'm not sure where it's gonna sit or if I'm gonna like it. If I like it without the spacers, I might would part with mine. Attached thumbnail(s) |
| Krieger |
Mar 29 2026, 10:56 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,846 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
It looks like the spring perch is adjustable. If so, the collar around the shock body has grooves and a snap ring that sets the height of the perch section. Move the ring and perch to a higher groove and raise the ride height. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 30th March 2026 - 03:12 AM |
