| Flyinlow |
Mar 31 2026, 05:39 PM
Flyinlow ![]() ![]() Group: Members Posts: 137 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada
Nearing the end of my restoration drove car today for first time in 30 years!! Start up is 1000 rpm a little high…. Then on its own goes to 3000 rpm then seems to settle to 2500 rpm.. when shifting rpm rises? I checked throttle cable for routing… all good and it did decel but not quickly as it seemed to be hunting any help much appreciated.TIA Dennis (IMG:style_emoticons/default/blink.gif)
| Flyinlow |
Mar 31 2026, 05:44 PM
Car is 74 2.0 D jet and I had no response from idle adjustment screw
| emerygt350 |
Mar 31 2026, 05:49 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,506 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
If you just start the car and let it sit, what does it do? Cold or hot?
| mgphoto |
Mar 31 2026, 05:53 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Big air leak in the intake.
| Flyinlow |
Mar 31 2026, 06:14 PM
| Flyinlow |
Mar 31 2026, 06:16 PM
| mgphoto |
Mar 31 2026, 08:37 PM
If it changes when it gets hot must be something with the AAR, Auxiliary Air Regulator, for cold weather starting.
| mgphoto |
Mar 31 2026, 08:41 PM
If the idle undulates, it usually is the idle air screw out too far, but you said screwing it in made no difference.
The next possibility would be an air leak. |
| porschetub |
Mar 31 2026, 11:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Big air leak in the intake. Certainly sounds like it, quick test on the throttle cable ,when the engine is up to temp disconnect it and see what it does . The vacuum leak is a telltale of loose /leaking air hose/s or many other reasons ,D-jet isn't happy with air leaks ,even a small leak will render the air screw to no non -op . Go back and check everything ,cheers. |
Lo-Fi Version | Time is now: 1st April 2026 - 01:58 AM |
