> turn signal light stays on why
TonyA
post Apr 3 2026, 01:39 PM
Nachmal
I had everything working fine before i installed the engine.
Now the small green turn signal light stays on. I removed all the turn signal bulbs and its still on? I moved the hazard switch a bunch of times on and off.
any ideas.?
Rob-O
post Apr 3 2026, 02:26 PM
Is the turn signal stalk actuated? It’s a 70’s European vehicle. The turn signal (both front and rear) is designed to stay on when the key is removed and the stalk is actuated for a left turn or a right turn.
TonyA
post Apr 3 2026, 02:56 PM
Nachmal
Yea i read about that. No it is not on. This is a 1974 early march if that matters
Thanks
Spoke
post Apr 3 2026, 07:19 PM
Jerry
Do the turnsignals work left and right?
Do the hazards flash all external turnsignal bulbs?
Does the L/R tach indicator flash with the turnsignals?
Below is the basic schematic for the 74-76 914 with single L/R tach indicator.
The tach indicator is powered by the C/K/C2 pin of the flasher relay. That should only operate with flashers flashing.
What other wiring work was done?
- Lo-Fi Version Time is now: 3rd April 2026 - 11:16 PM
