| slapshot |
Apr 17 2026, 04:04 PM
Member ![]() ![]() Group: Members Posts: 147 Joined: 11-June 23 From: Utah Member No.: 27,409 Region Association: Rocky Mountains
My speedometer stopped working right after I filled up for gas.
I checked the angle drive and it does not appear to turn when the car is in gear at idle. I then disconnected the speedo cable at the gauge, and the cable does spin when turning by hand at the rear but this did not move the speedometer needle at all when plugged in. This makes me think I might have two separate issues (angle drive and gauge), but I’m not sure if I’m testing this correctly. https://www.youtube.com/watch?v=BwwqVfQ2fhY |
| bkrantz |
Apr 17 2026, 07:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,662 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
You can put a drill on the end of the cable and try spinning it to see if the speedo responds. Sorry I can't remember which way to spin it.
Lo-Fi Version | Time is now: 17th April 2026 - 09:07 PM |
