> Windshield mirror glue
TonyA
post May 7 2026, 07:39 AM
Nachmal
What should i use to glue the rearview mirror to the windshield?
The permatex adhesive kit is glue only and wipes. There should be a thin
Pad to take up the thin lip around the mirror mount. Where do I purchase?
Shivers
post May 7 2026, 07:53 AM
QUOTE(TonyA @ May 7 2026, 06:39 AM) *
When mine fell off of my 72 it was just the base. I didn't see a pad.
Dlee6205
post May 7 2026, 08:06 AM
This?
https://914rubber.com/rear-view-mirror-adhesive-pad
TonyA
post May 7 2026, 08:48 AM
Nachmal
Thanks much appreciated. I just ordered it
porschetub
post May 7 2026, 06:03 PM
QUOTE(TonyA @ May 8 2026, 02:48 AM) *
Only solution that lasts , i used the 944 one from Pelican way back ,cleaning is really important for a lasting bond ,you will be fine .
post May 7 2026, 06:05 PM
914-6 GT in waiting
I use the high strength glue available at flaps. I've done 6 customer cars and so far, so good. Prep is the key.
worn
post May 7 2026, 06:06 PM
QUOTE(Dlee6205 @ May 7 2026, 07:06 AM) *
A trick that George Hussey suggested is to run a bead of silicone RTV around the edge after installation. That helps prevent space forming between the foam tape and the glass. Basically keeps a vacuum. I cannot say how much that helps but I can say mine haven't fallen off.
- Lo-Fi Version Time is now: 7th May 2026 - 09:03 PM
