> 2056 and MPS location, A bit ‘if her n to der right
worn
post May 17 2026, 05:10 PM
I am starting to break in my 2056. I bench adjusted the MPS by inductance, bought an A/F meter and am getting going. But with aftermarket injector elbows the MPS was durn hard to attach to the car. So I cut drilled and bent an adaptor.
It moves the location of the MPS upwards and towards the front of the car by about 25 mm or so in each direction with a bit of a bend away from the inner fender. Looks like this.
Or from the left side
Anyone find this a useful move?
Replies(1 - 3)
emerygt350
post May 17 2026, 07:01 PM
That's a great idea. Its stock location makes it hard to work on an around. Did you keep the rubber isolators? Probably a good idea to have those.
FlacaProductions
post May 17 2026, 07:35 PM
i actually have mine flipped 180 front-to-back right now as i'm tuning it. REALLY hard for me to get to the screws when they're on the back side. I may make a different, temp bracket that runs the unit straight up and down with the adjustment screw on top....we'll see.
I'd keep the rubber isolators if you can.
worn
post May 17 2026, 08:48 PM
QUOTE(emerygt350 @ May 17 2026, 06:01 PM) *
Yes. The isolators are between the car and the new bracket. I think that the isolators are important.
- Lo-Fi Version Time is now: 9th June 2026 - 05:52 PM
