> Throttle body question, L-jetronic throttle body bracket spring
mcericmc
post Jun 10 2026, 02:06 PM
Would someone please tell me where the spring goes to from the throttle body bracket assembly? There wasn't one on the car when I got it, but the hole is worn as though there used to be one. The "arm" with the hole rotates counterclockwise when looking down from the top. I can't seem to locate anywhere to hook the other end of the spring. Any info would be greatly appreciated. A description of what that "arm" actually does would be great. I've attached a photo because I'm probably not using the correct terminology. Thanks.Attached Image
Artfrombama
post Jun 10 2026, 02:32 PM
Artfrombama
Thanks again @clayperrine for pointing this missing spring out to me
mcericmc
post Jun 10 2026, 03:30 PM
QUOTE(Artfrombama @ Jun 10 2026, 03:32 PM) *
Thanks!
- Lo-Fi Version Time is now: 11th June 2026 - 01:58 AM
