> Fred's 2374 -> 2258 Engine Build Thread
friethmiller
post Jun 26 2026, 03:07 PM
I can't believe it but after 1-1/2 years of waiting for my engine components to be machined, I am finally picking up the parts tomorrow (IMG:style_emoticons/default/blink.gif). I will post more after talking to the owner about the issues he found with my case. This is what was holding everything up. Luckily. I have source another case (from my shed) and will be using this one instead. Here's a few pics of the my "other '74" after uncovering it today and wiping off a bit of dust. She needs to ride again! Hoping for Okteenerfest. Stay tuned!
zig-n-zag
post Jul 2 2026, 02:53 AM
A tip I got long ago was to always store engine cases bolted together to
prevent warping. Check the camshaft saddle under the #2 bearing to see
if it had collapsed or rocks using a straight edge. Run the straight edge
horizontally over all 3 cam saddles, on both sides of the saddles, and
vertically over the #2 main bearing saddle, and out to the case perimeters.
A problem there might mean a cam tunnel line bore. And there’s 1 more
check to do. Bolt the case together with the 6 big nuts and torque it to
25lbs. Back light the center main at the parting face. If you see any light
between the parting faces, that means you’ll have low oil pressure,
because oil will be leaking out from the back side of the bearing.
friethmiller   Fred's 2374 -> 2258 Engine Build Thread   Jun 26 2026, 03:07 PM
Ron914   I can't believe it but after 1-1/2 years of w...   Jun 26 2026, 04:59 PM
friethmiller   Car looks great . Did this one start out like the...   Jun 26 2026, 07:54 PM
930cabman   Been holding out eh   Jun 26 2026, 05:35 PM
friethmiller   Turned out alright, I think. Learned a lot!   Jun 26 2026, 07:58 PM
Ninja   SHOW OFF!! An engine thread needs ENGINE ...   Jun 26 2026, 08:47 PM
friethmiller   Hee, hee… yes, it’ll all start tomorrow, Rick.   Jun 26 2026, 09:05 PM
friethmiller   Initial Layout (6/27/2026): After about 5 hours o...   Jun 27 2026, 05:16 PM
seanpaulmc   I’m so excited and it’s not even my car. :ch...   Jun 27 2026, 05:57 PM
friethmiller   I’m so excited and it’s not even my car. :c...   Jun 27 2026, 06:40 PM
Jack Standz   Hi Fred, Me thinks that's a great cam choice...   Jun 27 2026, 06:05 PM
Montreal914   WOW, super cool!! Where to begin my commen...   Jun 27 2026, 06:19 PM
friethmiller   Did you install the braces for the inner suspensi...   Jun 27 2026, 06:45 PM
Montreal914   Did you install the braces for the inner suspens...   Jun 27 2026, 07:49 PM
friethmiller   All this to say that your LN lifters may be WebCa...   Jun 27 2026, 08:59 PM
Puebloswatcop   I can't believe it but after 1-1/2 years of w...   Jun 27 2026, 06:44 PM
friethmiller   Fred, If she needs some TLC, I would be happy to ...   Jun 27 2026, 07:19 PM
Ninja   Ah, meat and potatoes... Thank you! So, 2258 ...   Jun 27 2026, 06:55 PM
friethmiller   Ah, meat and potatoes... Thank you! So, 2258...   Jun 27 2026, 07:16 PM
914werke   Rods checked out fine but were modified for bett...   Jun 27 2026, 07:43 PM
friethmiller   Curious , why offset as the published description...   Jun 27 2026, 08:35 PM
friethmiller   Trying to verify dimensions here. What is the sta...   Jun 28 2026, 04:47 PM
930cabman   Trying to verify dimensions here. What is the st...   Jun 28 2026, 05:48 PM
cgnj   @friethmiller AI is not your friend. That is for ...   Jun 28 2026, 06:06 PM
friethmiller   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jun 28 2026, 07:15 PM
friethmiller   Ok, I've confirmed two things. My EA block i...   Jun 29 2026, 06:08 PM
Montreal914   Good news! B:) Nice metrology tools btw. Di...   Jun 29 2026, 07:02 PM
Ninja   Are bearings MORE available if you need .020 over ...   Jun 29 2026, 07:11 PM
zig-n-zag   Yes, nice tools you have there. With the main b...   Jun 29 2026, 09:34 PM
friethmiller   With the main bearing tunnel being tight, ask you...   Jun 30 2026, 07:04 AM
Jack Standz   Are bearings MORE available if you need .020 over...   Jun 29 2026, 10:25 PM
friethmiller   Good news! B:) Did you get a chance to meas...   Jun 30 2026, 07:17 AM
Ninja   I have another question... How do the main bearin...   Jun 30 2026, 08:57 AM
friethmiller   I have another question... How do the main beari...   Jun 30 2026, 09:06 AM
Nogoodwithusernames   Fred, If mains are tight, I would see if the shop ...   Jun 30 2026, 09:21 AM
friethmiller   Ok, three things to report back on. I talked with...   Jun 30 2026, 02:25 PM
friethmiller   Please help play.... read the micrometer! Thi...   Jul 1 2026, 11:41 AM
cgnj   I'm watching now because you lost me.   Jul 1 2026, 12:35 PM
Ninja   Please help play.... [b]read the micrometer! ...   Jul 1 2026, 01:21 PM
friethmiller   Do you have a 2" and 3" standards? I...   Jul 1 2026, 01:37 PM
Shivers   Nice parts Fred   Jul 1 2026, 01:44 PM
zig-n-zag   A tip I got long ago was to always store engine ca...   Jul 2 2026, 02:53 AM
friethmiller   A tip I got long ago was to always store engine c...   Jul 2 2026, 06:03 AM
friethmiller   To summarize my current issue, I'm measuring m...   Jul 2 2026, 08:29 AM
Nogoodwithusernames   To summarize my current issue, I'm measuring ...   Jul 2 2026, 02:20 PM
friethmiller   Have you checked it with bearings installed? With...   Jul 2 2026, 03:43 PM
friethmiller   Wanted to verify the oil clearance on the mains. ...   Jul 2 2026, 04:02 PM
930cabman   Wanted to verify the oil clearance on the mains. ...   Jul 2 2026, 04:17 PM
friethmiller   Not yet. I’m asking if these are the recommende...   Jul 2 2026, 05:32 PM
friethmiller   Update: I spent a lot of time this weekend in the...   Jul 5 2026, 07:45 PM
friethmiller   W Case Measurements: Went out to the garage this ...   Jul 6 2026, 07:56 AM
friethmiller   EA Case Measurements: Ok, I might be alright. He...   Jul 6 2026, 03:20 PM
friethmiller   Initial Mockup Used a light coating of assembly l...   Jul 7 2026, 06:26 AM
friethmiller   Oil Pump Checks: Measured my Schadek 30mm pump th...   Jul 8 2026, 07:18 AM
friethmiller   Oil Pump Checks (Part2): Pulled out the pump gask...   Jul 8 2026, 08:13 AM
friethmiller   More Measurement Data: I've spent a lot of ti...   Jul 10 2026, 09:19 AM
930cabman   More Measurement Data: I've spent a lot of t...   Jul 11 2026, 05:25 AM
Jack Standz   [b]Oil Pump Checks (Part2): Pulled out the pump ...   Jul 10 2026, 12:16 PM
friethmiller   Fred, Where did you get these thick gaskets? Th...   Jul 10 2026, 12:27 PM
friethmiller   Fred, Where did you get these thick gaskets? T...   Jul 11 2026, 02:59 PM
friethmiller   @930cabman - yeah, you’re probably right. Mayb...   Jul 11 2026, 10:36 AM
930cabman   I like Plasti Gage, it has worked well for me in t...   Jul 11 2026, 01:06 PM
friethmiller   I like Plasti Gage... Me too! I think about...   Jul 11 2026, 07:22 PM
Robroe   Following you with great interest. I am also buil...   Jul 11 2026, 03:33 PM
friethmiller   Following you with great interest. I am also bui...   Jul 11 2026, 07:23 PM
friethmiller   Moving Forward While I wait for another case from...   Jul 11 2026, 08:08 PM
friethmiller   Yeah, I forgot about "Cam Degreeing". D...   Jul 11 2026, 08:42 PM
Jack Standz   [quote name='friethmiller' post='3264688' date='J...   Jul 11 2026, 10:31 PM
friethmiller   Thanks for checking Fred. Couldn't find it o...   Jul 12 2026, 05:13 AM
friethmiller   Of course it looks like you might be trying to ju...   Jul 12 2026, 07:35 AM
friethmiller   @930cabman - Plasticgauge on the W-case. Brand n...   Jul 12 2026, 09:26 AM
930cabman   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jul 12 2026, 01:16 PM
Ninja   Hi Fred, Me thinks that's a great cam choic...   Jul 12 2026, 11:38 AM
friethmiller   Can you provide a close-up view of the main beari...   Jul 12 2026, 07:51 PM
friethmiller   Ok, I reassembled the W case again without bearing...   Jul 12 2026, 08:13 PM
Jack Standz   [quote name='Jack Standz' post='3263078' date='Ju...   Jul 12 2026, 11:23 PM
friethmiller   Fuel Regulator: I needed to mount the new PMO fue...   Jul 13 2026, 07:52 AM
Ninja   WOW! those machine marks don't look even.....   Jul 13 2026, 08:08 AM
930cabman   WOW! those machine marks don't look even....   Jul 14 2026, 01:00 PM
friethmiller   perhaps a call to Ollies is in order Ollies in ...   Jul 14 2026, 01:23 PM
Ninja   Heads up! Checking line bore without the case...   Jul 13 2026, 10:43 AM
930cabman   Wish I knew of a reputable VW/Porsche engine machi...   Jul 14 2026, 07:25 PM
friethmiller   I hear ya there. When I torqued the crank in my E...   Jul 14 2026, 07:51 PM
930cabman   I hear ya there. When I torqued the crank in my ...   Jul 15 2026, 04:55 AM
friethmiller   I hear ya there. When I torqued the crank in my...   Jul 15 2026, 05:36 AM
930cabman   [quote name='930cabman' post='3265095' date='Jul ...   Jul 15 2026, 09:03 AM
friethmiller   Given the information available I would give this...   Jul 15 2026, 12:36 PM
930cabman   [quote name='930cabman' post='3265146' date='Jul ...   Jul 15 2026, 01:01 PM
Ninja   Ill fitting! But I'd want to see all of t...   Jul 15 2026, 01:26 PM
friethmiller   Note the backs of these same #2 bearings. Note: t...   Jul 15 2026, 01:37 PM
930cabman   Once again, I am not a "real" engine bui...   Jul 16 2026, 04:50 AM
friethmiller   Once again, I am not a "real" engine bu...   Jul 16 2026, 06:33 AM
friethmiller   All this is in the past, though. I'm looking ...   Jul 16 2026, 08:33 AM
930cabman   All this is in the past, though. I'm looking...   Jul 16 2026, 12:22 PM
friethmiller   [quote name='friethmiller' post='3265264' date='J...   Jul 16 2026, 01:26 PM
930cabman   Whoa, quite the timeline. The learning experience ...   Jul 16 2026, 05:58 PM
friethmiller   @930cabman - so true! Thanks for your input/...   Jul 17 2026, 10:56 AM
Ninja   Awesome! Chris's exhaust is exemplary...   Jul 17 2026, 12:19 PM
friethmiller   Do I have to run the AFR gauge into the main cabin...   Jul 17 2026, 01:24 PM
Ninja   I'd watch that gauge more than anything else b...   Jul 17 2026, 02:23 PM
3 Pages V  1 2 3 >
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 7th November 2026 - 02:44 PM
