| friethmiller |
Jun 26 2026, 03:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,614 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
I can't believe it but after 1-1/2 years of waiting for my engine components to be machined, I am finally picking up the parts tomorrow (IMG:style_emoticons/default/blink.gif). I will post more after talking to the owner about the issues he found with my case. This is what was holding everything up. Luckily. I have source another case (from my shed) and will be using this one instead. Here's a few pics of the my "other '74" after uncovering it today and wiping off a bit of dust. She needs to ride again! Hoping for Okteenerfest. Stay tuned!
| friethmiller |
Jun 28 2026, 04:47 PM
Trying to verify dimensions here. What is the standard case bore for the type 4 engine? AI says 2.559”. That seems too small. I’m measuring roughly 2.768 for the rear main on a case with a .02 line bore. Why am I off a decimal place? (IMG:style_emoticons/default/idea.gif)
friethmiller Fred's 2374 -> 2258 Engine Build Thread Jun 26 2026, 03:07 PM
Ron914
I can't believe it but after 1-1/2 years of w... Jun 26 2026, 04:59 PM
friethmiller
Car looks great . Did this one start out like the... Jun 26 2026, 07:54 PM
930cabman Been holding out eh Jun 26 2026, 05:35 PM
friethmiller Turned out alright, I think. Learned a lot!
Jun 26 2026, 07:58 PM
Ninja SHOW OFF!!
An engine thread needs ENGINE ... Jun 26 2026, 08:47 PM
friethmiller Hee, hee… yes, it’ll all start tomorrow, Rick. Jun 26 2026, 09:05 PM
friethmiller Initial Layout (6/27/2026):
After about 5 hours o... Jun 27 2026, 05:16 PM
seanpaulmc I’m so excited and it’s not even my car. :ch... Jun 27 2026, 05:57 PM
friethmiller
I’m so excited and it’s not even my car. :c... Jun 27 2026, 06:40 PM
Jack Standz Hi Fred,
Me thinks that's a great cam choice... Jun 27 2026, 06:05 PM
Montreal914 WOW, super cool!! Where to begin my commen... Jun 27 2026, 06:19 PM
friethmiller
Did you install the braces for the inner suspensi... Jun 27 2026, 06:45 PM
Montreal914
Did you install the braces for the inner suspens... Jun 27 2026, 07:49 PM
friethmiller
All this to say that your LN lifters may be WebCa... Jun 27 2026, 08:59 PM
Puebloswatcop
I can't believe it but after 1-1/2 years of w... Jun 27 2026, 06:44 PM
friethmiller
Fred, If she needs some TLC, I would be happy to ... Jun 27 2026, 07:19 PM
Ninja Ah, meat and potatoes...
Thank you!
So, 2258 ... Jun 27 2026, 06:55 PM
friethmiller
Thank you!
So, 2258... Jun 27 2026, 07:16 PM
914werke Rods checked out fine but were modified for bett... Jun 27 2026, 07:43 PM
friethmiller
Curious , why offset as the published description... Jun 27 2026, 08:35 PM
930cabman
Trying to verify dimensions here. What is the st... Jun 28 2026, 05:48 PM
cgnj @friethmiller AI is not your friend. That is for ... Jun 28 2026, 06:06 PM
friethmiller
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 28 2026, 07:15 PM
friethmiller Ok, I've confirmed two things.
My EA block i... Jun 29 2026, 06:08 PM
Montreal914 Good news! B:)
Nice metrology tools btw.
Di... Jun 29 2026, 07:02 PM
Ninja Are bearings MORE available if you need .020 over ... Jun 29 2026, 07:11 PM
zig-n-zag Yes, nice tools you have there.
With the main b... Jun 29 2026, 09:34 PM
friethmiller
With the main bearing tunnel being tight, ask you... Jun 30 2026, 07:04 AM
Jack Standz
Are bearings MORE available if you need .020 over... Jun 29 2026, 10:25 PM
friethmiller
Good news! B:)
Did you get a chance to meas... Jun 30 2026, 07:17 AM
Ninja I have another question...
How do the main bearin... Jun 30 2026, 08:57 AM
friethmiller
How do the main beari... Jun 30 2026, 09:06 AM
Nogoodwithusernames Fred,
If mains are tight, I would see if the shop ... Jun 30 2026, 09:21 AM
friethmiller Ok, three things to report back on. I talked with... Jun 30 2026, 02:25 PM
friethmiller Please help play.... read the micrometer! Thi... Jul 1 2026, 11:41 AM
cgnj I'm watching now because you lost me. Jul 1 2026, 12:35 PM
Ninja
Please help play.... [b]read the micrometer! ... Jul 1 2026, 01:21 PM
friethmiller
Do you have a 2" and 3" standards?
I... Jul 1 2026, 01:37 PM
Shivers Nice parts Fred Jul 1 2026, 01:44 PM
zig-n-zag A tip I got long ago was to always store engine ca... Jul 2 2026, 02:53 AM
friethmiller
A tip I got long ago was to always store engine c... Jul 2 2026, 06:03 AM
friethmiller To summarize my current issue, I'm measuring m... Jul 2 2026, 08:29 AM
Nogoodwithusernames
To summarize my current issue, I'm measuring ... Jul 2 2026, 02:20 PM
friethmiller
Have you checked it with bearings installed? With... Jul 2 2026, 03:43 PM
friethmiller Wanted to verify the oil clearance on the mains. ... Jul 2 2026, 04:02 PM
930cabman
Wanted to verify the oil clearance on the mains. ... Jul 2 2026, 04:17 PM
friethmiller Not yet. I’m asking if these are the recommende... Jul 2 2026, 05:32 PM
friethmiller Update:
I spent a lot of time this weekend in the... Jul 5 2026, 07:45 PM
friethmiller W Case Measurements:
Went out to the garage this ... Jul 6 2026, 07:56 AM
friethmiller EA Case Measurements:
Ok, I might be alright. He... Jul 6 2026, 03:20 PM
friethmiller Initial Mockup
Used a light coating of assembly l... Jul 7 2026, 06:26 AM
friethmiller Oil Pump Checks:
Measured my Schadek 30mm pump th... Jul 8 2026, 07:18 AM
friethmiller Oil Pump Checks (Part2):
Pulled out the pump gask... Jul 8 2026, 08:13 AM
friethmiller More Measurement Data:
I've spent a lot of ti... Jul 10 2026, 09:19 AM
930cabman
I've spent a lot of t... Jul 11 2026, 05:25 AM
Jack Standz
[b]Oil Pump Checks (Part2):
Pulled out the pump ... Jul 10 2026, 12:16 PM
friethmiller
Fred,
Where did you get these thick gaskets? Th... Jul 10 2026, 12:27 PM
friethmiller
Fred,
Where did you get these thick gaskets? T... Jul 11 2026, 02:59 PM
friethmiller @930cabman - yeah, you’re probably right. Mayb... Jul 11 2026, 10:36 AM
930cabman I like Plasti Gage, it has worked well for me in t... Jul 11 2026, 01:06 PM
friethmiller
I like Plasti Gage...
Me too! I think about... Jul 11 2026, 07:22 PM
Robroe Following you with great interest. I am also buil... Jul 11 2026, 03:33 PM
friethmiller
Following you with great interest. I am also bui... Jul 11 2026, 07:23 PM
friethmiller Moving Forward
While I wait for another case from... Jul 11 2026, 08:08 PM
friethmiller Yeah, I forgot about "Cam Degreeing". D... Jul 11 2026, 08:42 PM
Jack Standz
[quote name='friethmiller' post='3264688' date='J... Jul 11 2026, 10:31 PM
friethmiller
Thanks for checking Fred. Couldn't find it o... Jul 12 2026, 05:13 AM
friethmiller
Of course it looks like you might be trying to ju... Jul 12 2026, 07:35 AM
friethmiller @930cabman - Plasticgauge on the W-case. Brand n... Jul 12 2026, 09:26 AM
930cabman
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 12 2026, 01:16 PM
Ninja
Hi Fred,
Me thinks that's a great cam choic... Jul 12 2026, 11:38 AM
friethmiller
Can you provide a close-up view of the main beari... Jul 12 2026, 07:51 PM
friethmiller Ok, I reassembled the W case again without bearing... Jul 12 2026, 08:13 PM
Jack Standz
[quote name='Jack Standz' post='3263078' date='Ju... Jul 12 2026, 11:23 PM
friethmiller Fuel Regulator:
I needed to mount the new PMO fue... Jul 13 2026, 07:52 AM
Ninja WOW! those machine marks don't look even..... Jul 13 2026, 08:08 AM
930cabman
WOW! those machine marks don't look even.... Jul 14 2026, 01:00 PM
friethmiller
perhaps a call to Ollies is in order
Ollies in ... Jul 14 2026, 01:23 PM
Ninja Heads up!
Checking line bore without the case... Jul 13 2026, 10:43 AM
930cabman Wish I knew of a reputable VW/Porsche engine machi... Jul 14 2026, 07:25 PM
friethmiller I hear ya there. When I torqued the crank in my E... Jul 14 2026, 07:51 PM
930cabman
I hear ya there. When I torqued the crank in my ... Jul 15 2026, 04:55 AM
friethmiller
I hear ya there. When I torqued the crank in my... Jul 15 2026, 05:36 AM
930cabman
[quote name='930cabman' post='3265095' date='Jul ... Jul 15 2026, 09:03 AM
friethmiller
Given the information available I would give this... Jul 15 2026, 12:36 PM
930cabman
[quote name='930cabman' post='3265146' date='Jul ... Jul 15 2026, 01:01 PM
Ninja Ill fitting!
But I'd want to see all of t... Jul 15 2026, 01:26 PM
friethmiller Note the backs of these same #2 bearings. Note: t... Jul 15 2026, 01:37 PM
930cabman Once again, I am not a "real" engine bui... Jul 16 2026, 04:50 AM
friethmiller
Once again, I am not a "real" engine bu... Jul 16 2026, 06:33 AM
friethmiller All this is in the past, though. I'm looking ... Jul 16 2026, 08:33 AM
930cabman
All this is in the past, though. I'm looking... Jul 16 2026, 12:22 PM
friethmiller
[quote name='friethmiller' post='3265264' date='J... Jul 16 2026, 01:26 PM
930cabman Whoa, quite the timeline. The learning experience ... Jul 16 2026, 05:58 PM
friethmiller @930cabman - so true! Thanks for your input/... Jul 17 2026, 10:56 AM
Ninja Awesome!
Chris's exhaust is exemplary... Jul 17 2026, 12:19 PM
friethmiller Do I have to run the AFR gauge into the main cabin... Jul 17 2026, 01:24 PM
Ninja I'd watch that gauge more than anything else b... Jul 17 2026, 02:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th November 2026 - 08:04 PM |
