> Fred's 2374 -> 2258 Engine Build Thread
friethmiller
post Jun 26 2026, 03:07 PM
I can't believe it but after 1-1/2 years of waiting for my engine components to be machined, I am finally picking up the parts tomorrow (IMG:style_emoticons/default/blink.gif). I will post more after talking to the owner about the issues he found with my case. This is what was holding everything up. Luckily. I have source another case (from my shed) and will be using this one instead. Here's a few pics of the my "other '74" after uncovering it today and wiping off a bit of dust. She needs to ride again! Hoping for Okteenerfest. Stay tuned!
friethmiller
post Jul 2 2026, 04:02 PM
Wanted to verify the oil clearance on the mains. AI says:
0.03 mm to 0.08 mm (0.001" to 0.003") for journals #1, #2, and #3
0.05 mm to 0.10 mm (0.0019" to 0.004") on journal #4
Does this sound correct or is this AI screwing up and giving me Type 1 specs? I think .002 is desired, if I'm remembering correctly. TIA.
friethmiller   Fred's 2374 -> 2258 Engine Build Thread   Jun 26 2026, 03:07 PM
Ron914   I can't believe it but after 1-1/2 years of w...   Jun 26 2026, 04:59 PM
friethmiller   Car looks great . Did this one start out like the...   Jun 26 2026, 07:54 PM
930cabman   Been holding out eh   Jun 26 2026, 05:35 PM
friethmiller   Turned out alright, I think. Learned a lot!   Jun 26 2026, 07:58 PM
Ninja   SHOW OFF!! An engine thread needs ENGINE ...   Jun 26 2026, 08:47 PM
friethmiller   Hee, hee… yes, it’ll all start tomorrow, Rick.   Jun 26 2026, 09:05 PM
friethmiller   Initial Layout (6/27/2026): After about 5 hours o...   Jun 27 2026, 05:16 PM
seanpaulmc   I’m so excited and it’s not even my car. :ch...   Jun 27 2026, 05:57 PM
friethmiller   I’m so excited and it’s not even my car. :c...   Jun 27 2026, 06:40 PM
Jack Standz   Hi Fred, Me thinks that's a great cam choice...   Jun 27 2026, 06:05 PM
Montreal914   WOW, super cool!! Where to begin my commen...   Jun 27 2026, 06:19 PM
friethmiller   Did you install the braces for the inner suspensi...   Jun 27 2026, 06:45 PM
Montreal914   Did you install the braces for the inner suspens...   Jun 27 2026, 07:49 PM
friethmiller   All this to say that your LN lifters may be WebCa...   Jun 27 2026, 08:59 PM
Puebloswatcop   I can't believe it but after 1-1/2 years of w...   Jun 27 2026, 06:44 PM
friethmiller   Fred, If she needs some TLC, I would be happy to ...   Jun 27 2026, 07:19 PM
Ninja   Ah, meat and potatoes... Thank you! So, 2258 ...   Jun 27 2026, 06:55 PM
friethmiller   Ah, meat and potatoes... Thank you! So, 2258...   Jun 27 2026, 07:16 PM
914werke   Rods checked out fine but were modified for bett...   Jun 27 2026, 07:43 PM
friethmiller   Curious , why offset as the published description...   Jun 27 2026, 08:35 PM
friethmiller   Trying to verify dimensions here. What is the sta...   Jun 28 2026, 04:47 PM
930cabman   Trying to verify dimensions here. What is the st...   Jun 28 2026, 05:48 PM
cgnj   @friethmiller AI is not your friend. That is for ...   Jun 28 2026, 06:06 PM
friethmiller   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jun 28 2026, 07:15 PM
friethmiller   Ok, I've confirmed two things. My EA block i...   Jun 29 2026, 06:08 PM
Montreal914   Good news! B:) Nice metrology tools btw. Di...   Jun 29 2026, 07:02 PM
Ninja   Are bearings MORE available if you need .020 over ...   Jun 29 2026, 07:11 PM
zig-n-zag   Yes, nice tools you have there. With the main b...   Jun 29 2026, 09:34 PM
friethmiller   With the main bearing tunnel being tight, ask you...   Jun 30 2026, 07:04 AM
Jack Standz   Are bearings MORE available if you need .020 over...   Jun 29 2026, 10:25 PM
friethmiller   Good news! B:) Did you get a chance to meas...   Jun 30 2026, 07:17 AM
Ninja   I have another question... How do the main bearin...   Jun 30 2026, 08:57 AM
friethmiller   I have another question... How do the main beari...   Jun 30 2026, 09:06 AM
Nogoodwithusernames   Fred, If mains are tight, I would see if the shop ...   Jun 30 2026, 09:21 AM
friethmiller   Ok, three things to report back on. I talked with...   Jun 30 2026, 02:25 PM
friethmiller   Please help play.... read the micrometer! Thi...   Jul 1 2026, 11:41 AM
cgnj   I'm watching now because you lost me.   Jul 1 2026, 12:35 PM
Ninja   Please help play.... [b]read the micrometer! ...   Jul 1 2026, 01:21 PM
friethmiller   Do you have a 2" and 3" standards? I...   Jul 1 2026, 01:37 PM
Shivers   Nice parts Fred   Jul 1 2026, 01:44 PM
zig-n-zag   A tip I got long ago was to always store engine ca...   Jul 2 2026, 02:53 AM
friethmiller   A tip I got long ago was to always store engine c...   Jul 2 2026, 06:03 AM
friethmiller   To summarize my current issue, I'm measuring m...   Jul 2 2026, 08:29 AM
Nogoodwithusernames   To summarize my current issue, I'm measuring ...   Jul 2 2026, 02:20 PM
friethmiller   Have you checked it with bearings installed? With...   Jul 2 2026, 03:43 PM
friethmiller   Wanted to verify the oil clearance on the mains. ...   Jul 2 2026, 04:02 PM
930cabman   Wanted to verify the oil clearance on the mains. ...   Jul 2 2026, 04:17 PM
friethmiller   Not yet. I’m asking if these are the recommende...   Jul 2 2026, 05:32 PM
friethmiller   Update: I spent a lot of time this weekend in the...   Jul 5 2026, 07:45 PM
friethmiller   W Case Measurements: Went out to the garage this ...   Jul 6 2026, 07:56 AM
friethmiller   EA Case Measurements: Ok, I might be alright. He...   Jul 6 2026, 03:20 PM
friethmiller   Initial Mockup Used a light coating of assembly l...   Jul 7 2026, 06:26 AM
friethmiller   Oil Pump Checks: Measured my Schadek 30mm pump th...   Jul 8 2026, 07:18 AM
friethmiller   Oil Pump Checks (Part2): Pulled out the pump gask...   Jul 8 2026, 08:13 AM
friethmiller   More Measurement Data: I've spent a lot of ti...   Jul 10 2026, 09:19 AM
930cabman   More Measurement Data: I've spent a lot of t...   Jul 11 2026, 05:25 AM
Jack Standz   [b]Oil Pump Checks (Part2): Pulled out the pump ...   Jul 10 2026, 12:16 PM
friethmiller   Fred, Where did you get these thick gaskets? Th...   Jul 10 2026, 12:27 PM
friethmiller   Fred, Where did you get these thick gaskets? T...   Jul 11 2026, 02:59 PM
friethmiller   @930cabman - yeah, you’re probably right. Mayb...   Jul 11 2026, 10:36 AM
930cabman   I like Plasti Gage, it has worked well for me in t...   Jul 11 2026, 01:06 PM
friethmiller   I like Plasti Gage... Me too! I think about...   Jul 11 2026, 07:22 PM
Robroe   Following you with great interest. I am also buil...   Jul 11 2026, 03:33 PM
friethmiller   Following you with great interest. I am also bui...   Jul 11 2026, 07:23 PM
friethmiller   Moving Forward While I wait for another case from...   Jul 11 2026, 08:08 PM
friethmiller   Yeah, I forgot about "Cam Degreeing". D...   Jul 11 2026, 08:42 PM
Jack Standz   [quote name='friethmiller' post='3264688' date='J...   Jul 11 2026, 10:31 PM
friethmiller   Thanks for checking Fred. Couldn't find it o...   Jul 12 2026, 05:13 AM
friethmiller   Of course it looks like you might be trying to ju...   Jul 12 2026, 07:35 AM
friethmiller   @930cabman - Plasticgauge on the W-case. Brand n...   Jul 12 2026, 09:26 AM
930cabman   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jul 12 2026, 01:16 PM
Ninja   Hi Fred, Me thinks that's a great cam choic...   Jul 12 2026, 11:38 AM
friethmiller   Can you provide a close-up view of the main beari...   Jul 12 2026, 07:51 PM
friethmiller   Ok, I reassembled the W case again without bearing...   Jul 12 2026, 08:13 PM
Jack Standz   [quote name='Jack Standz' post='3263078' date='Ju...   Jul 12 2026, 11:23 PM
friethmiller   Fuel Regulator: I needed to mount the new PMO fue...   Jul 13 2026, 07:52 AM
Ninja   WOW! those machine marks don't look even.....   Jul 13 2026, 08:08 AM
930cabman   WOW! those machine marks don't look even....   Jul 14 2026, 01:00 PM
friethmiller   perhaps a call to Ollies is in order Ollies in ...   Jul 14 2026, 01:23 PM
Ninja   Heads up! Checking line bore without the case...   Jul 13 2026, 10:43 AM
930cabman   Wish I knew of a reputable VW/Porsche engine machi...   Jul 14 2026, 07:25 PM
friethmiller   I hear ya there. When I torqued the crank in my E...   Jul 14 2026, 07:51 PM
930cabman   I hear ya there. When I torqued the crank in my ...   Jul 15 2026, 04:55 AM
friethmiller   I hear ya there. When I torqued the crank in my...   Jul 15 2026, 05:36 AM
930cabman   [quote name='930cabman' post='3265095' date='Jul ...   Jul 15 2026, 09:03 AM
friethmiller   Given the information available I would give this...   Jul 15 2026, 12:36 PM
930cabman   [quote name='930cabman' post='3265146' date='Jul ...   Jul 15 2026, 01:01 PM
Ninja   Ill fitting! But I'd want to see all of t...   Jul 15 2026, 01:26 PM
friethmiller   Note the backs of these same #2 bearings. Note: t...   Jul 15 2026, 01:37 PM
930cabman   Once again, I am not a "real" engine bui...   Jul 16 2026, 04:50 AM
friethmiller   Once again, I am not a "real" engine bu...   Jul 16 2026, 06:33 AM
friethmiller   All this is in the past, though. I'm looking ...   Jul 16 2026, 08:33 AM
930cabman   All this is in the past, though. I'm looking...   Jul 16 2026, 12:22 PM
friethmiller   [quote name='friethmiller' post='3265264' date='J...   Jul 16 2026, 01:26 PM
930cabman   Whoa, quite the timeline. The learning experience ...   Jul 16 2026, 05:58 PM
friethmiller   @930cabman - so true! Thanks for your input/...   Jul 17 2026, 10:56 AM
Ninja   Awesome! Chris's exhaust is exemplary...   Jul 17 2026, 12:19 PM
friethmiller   Do I have to run the AFR gauge into the main cabin...   Jul 17 2026, 01:24 PM
Ninja   I'd watch that gauge more than anything else b...   Jul 17 2026, 02:23 PM
3 Pages V  1 2 3 >
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 11th November 2026 - 07:01 PM
