| Ninja |
Oct 1 2026, 08:43 AM
Member ![]() ![]() Group: Members Posts: 323 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
Heads up if you didn't know...
Rings can be made from different materials, and each has a different specific RMS (bore finish) to work properly. I choose the rings before I have the bores finished and tell the machine shop what they are. I always send the new rings so the machine shop can check themselves. The difference between cast iron and chrome steel rings; cast need ROUGH and chrome needs SMOOTH. Important for the machinist to know! Important for the machinist to ASK if he didn't know. If he didn't ask would be a gigantic red flag for me... |
| friethmiller |
Oct 1 2026, 08:50 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,624 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
Side clearance is CRITICAL!!! When you measured .0025 difference in the thickness my first thought was, I hope one of those falls between .001-2 to the piston. SO MUCH BS on how this stuff is fitting together for you! Make you wonder if ANY of the critters supplying parts actually "give a shit" if the final engine will live. I feel your pain! (IMG:style_emoticons/default/ninja.gif) Yeah Rick, the Hasting rings are suppose to work for these pistons but by the time I got the Piston to Cylinder Wall gap correct, the ring gaps increased by a magnitude of PI. No worries. There's plenty of things I can still do till it gets sorted out. I doubt this will cause much delay. It's just a shame about the side clearance, the Grant rings were around a .015" ring gap out of the box and could have certainly been opened up to meet the .017" spec. I did enjoy doing the head-to-head measurements. (IMG:style_emoticons/default/biggrin.gif) |
| friethmiller |
Oct 1 2026, 09:47 AM
Heads up if you didn't know... Rings can be made from different materials, and each has a different specific RMS (bore finish) to work properly. I choose the rings before I have the bores finished and tell the machine shop what they are. I always send the new rings so the machine shop can check themselves. The difference between cast iron and chrome steel rings; cast need ROUGH and chrome needs SMOOTH. Important for the machinist to know! Important for the machinist to ASK if he didn't know. If he didn't ask would be a gigantic red flag for me... Interesting. I'm working with the JE rep now on what they recommend. I'll ask Eric (machinist) about the honing surface. They had my rings originally but not on the recent rework to hone them out for the pistons. |
| Jack Standz |
Oct 1 2026, 10:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
We didn't use to have the knowledge and tools that are available today. Theories and hard research are now being exploited by those who know and pay attention.
Would send you some links, but am not able to right now. However, your machinist should use a profilometer. Powell Machine has some good YouTube videos that show how to dial in an aircooled cylinder bore/hone (jet ski or motorcycle engine, can't remember). Also, Lake Speed has some that discuss ring gap that are very good. If you can set the gap where you want it, based on sound experience, that makes a lot of sense. So, patience pays if you can wait and regrind the ring gap to exactly where you want it. However, if you can't, those gaps are very probably ok. They aren't horrible and aren't likely to be an issue (refer to the videos where Lake Speed discusses ring gap - a tight gap can destroy things and gap, even if it seems excessive, doesn't automatically lead to excessive blowby or a meaningful loss in power). |
| friethmiller |
Oct 2 2026, 07:36 AM
...refer to the videos where Lake Speed discusses ring gap - a tight gap can destroy things and gap, even if it seems excessive, doesn't automatically lead to excessive blowby or a meaningful loss in power... Thanks John. I've seen Lake's video about ring gap but I may need to revisit. I worked with one of the reps from JE Pistons yesterday. A guy named David. Apparently he's worked with a couple of Porsche race teams in the past. Cool guy. He recommended the same Hastings rings that I had found and ordered from Walmart online [of all places] yesterday morning. It's an oversized 3.78" ring set, which is the next size up. The rings should be here on Saturday with just normal FexEx shipping. That's way faster than any other source I could find and the Walmart price was lower too. We'll see. (IMG:style_emoticons/default/smile.gif) |
| Artfrombama |
Oct 2 2026, 10:04 AM
Artfrombama ![]() ![]() Group: Members Posts: 496 Joined: 21-January 24 From: One of the chosen few Member No.: 27,870 Region Association: South East States
He recommended the same Hastings rings that I had found and ordered from Walmart online [of all places] yesterday morning. I used Hastings rings on the top end overhaul of my 1.8. Broken in immediately and no blowby or oil consumption so far (Knocks on wood). |
| friethmiller |
Oct 4 2026, 08:16 AM
Guys,
Well, the oversized rings are good on side clearance but not on back clearance! I'm flush on the number one ring. Thinking about punting and just going with standard rings that have gaps a bit wider at .021" and .024" for #1 and #2, respectively. ![]() |
| friethmiller |
Oct 7 2026, 10:03 AM
Building Out the Long Block - Part 1(10/3 - 10/4/2026):
Deck Height and Pistons to Valve Clearance: While waiting on the oversized rings, I decided to keep my feet moving on other things. With the pistons in #1 & #2, I verified a deck height without shims where the piston was crowning over the top of the cylinder (expected with a 78mm crank). Shooting for between .040"-.045", I added shims to finally settle on a .044" of deck height. This keeps me at the goal of 9.2:1 CR. Next, was the valve clearance check with the shims installed. After getting max lift from both intake and exhaust valves, I verified at least .089" of clearance for the intake and twice that for the exhaust. It's amazing how just a small valve relief (0.9cc) makes such a big difference. (IMG:style_emoticons/default/aktion035.gif) ![]() ![]() Installing Pistons & Cylinders: With the oversized rings a bust and advice from others including the JE rep and Jack Standz, I decided to just go with the rings I had. Having a few extra thou of gap isn't going to be a problem, IMO. It just means I can drive like I'm on the track! (IMG:style_emoticons/default/driving-girl.gif) Anyways... here are the rings going on and the cylinders going in. I followed the instructions on where to clock the different rings on an air-cooled engine. ![]() This next photo shows how not to insert a snap ring into the piston. This was for photo-purposes only. The 2nd photo shows how to properly prevent your snap ring from entering your engine (IMG:style_emoticons/default/biggrin.gif) Luckily I didn't have any mishaps. ![]() Valve Geometry: With the head installed and torqued, I then set about checking the rocker alignment on the valve stems. The 2nd photo shows the set of shims I used to get the rockers in a reasonable spot on the stem. The 3rd photo shows a typically alignment with the aluminum spacer and standard .040" shims. And, the 4th photo shows the end result where shims were switched out and placed in different spots to get a better alignment. ![]() ![]() Next up was the big task of verify valve lift and valve geometry in order to zero-in on a push rod length. The following photos show just a glimpse of what took several hours to do. Here, I am working with an adjustable aluminum push rod to get as close to the max lift as possible while maintaining correct geometry at half lift. The second photo shows a quick geometry check to verify I'm adjusting in the correct direction and I've got good alignment. ![]() Cutting Push Rods: Once I finalized the numbers, I then had to figure out where to cut the push rods. This is definitely where you want to measure 15x before cutting anything. These heavy-duty Aluminum pushrods are not cheap! (IMG:style_emoticons/default/blink.gif) This process of cutting, sanding, and remeasuring took several hours to do. I was so worried about over cutting the push rods that I ended up sanding forever to make sure I eased into my target length. Note: sanding the ends was done on a sheet of glass to help keep things as flat as possible. ![]() Push Rod Tubes: I ordered these from Tangerine Racing and was a little hesitant based on the price. Let me tell you... these are super nice, sturdy, and worth every penny. Thanks Chris! ![]() Part 2 coming soon. |
| friethmiller |
Oct 9 2026, 09:26 AM
Building Out the Long Block - Part 2(10/5 - 10/7/2026):
Working mornings and evenings on the engine now. Here are some pics of the other side, cylinders 3 + 4, going together with the same tasks for rocker alignment, assembly, tin work, and push rods & tubes. ![]() ![]() ![]() ![]() Here's the engine assembled. ![]() Next, was the install of the Tangerine Racing downpipes - best done from the side. The #4 cylinder is always tricky due to the tight space between the push rod tubes. Had to flatten the pipe in the vise just a bit more to get it to fit properly. ![]() ![]() Next, the fan shroud and pulley. Picture here shows the new allen bolts that I had to purchase for the A/C fan hub. The tops of the previous bolts were stripped out from a long tool being used from an angle during disassembly. (IMG:style_emoticons/default/chair.gif) Unfortunately, the only bolts I could find were 5mm too long. So, if I use a longer bolt the ends will likely extend into the front crank seal, which will not be good. To prevent this from happening, I used two 2.5mm washers in front of each bolt. This caused a lot of work because I had to hand file 6 washers flat on one side to allow them to sit properly against the shaft. The yellow line represents where the long shafted allen tool needs to go so as not to strip out the tops next time. (IMG:style_emoticons/default/rolleyes.gif) Obviously, one could argue that using very long bolts from the A/C pulley to the fan hub would probably work better. Dealer's choice... ![]() Here's a picture of just how much Tangerine Racing gear I have installed (IMG:style_emoticons/default/happy11.gif) ![]() Here's the engine as I finish up the tin work, electrics (wires, plugs, coil), and add oil. ![]() Next up are the carbs and fuel lines. I'm still waiting on the thin base gaskets arriving on Saturday but need to mock these in here to tackle the broken, frayed Master to Slave wire. While I did order a replacement from Chris Foley, I stopped by a local bike shop the other day and was given a new brake line for free (super nice guys there). This should work! ![]() ![]() Here's the new line rough'd in for now and a pic of the 1/4" fuel line that will only be used for the break-in scheduled for this weekend [hopefully]. More work to do to prepare for that. Additional posts coming soon. Cheers! (IMG:style_emoticons/default/beerchug.gif) ![]() ![]() |
| seanpaulmc |
Oct 9 2026, 11:22 AM
Member ![]() ![]() Group: Members Posts: 484 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States
Fred, any sealant between the case and the cylinders (and shims)? And, why or why not?
| friethmiller |
Oct 9 2026, 12:47 PM
Fred, any sealant between the case and the cylinders (and shims)? And, why or why not? Yeah it's hard to see from any of the photos. Each cylinder had a .086" and a .040" shim stack and I used Curil T2 seal between all the layers. Here's a pic I didn't include earlier of initial layer of Curil getting applied against the cylinder - before the shims. ![]() |
| Jack Standz |
Oct 9 2026, 02:23 PM
Nice work Fred! A foreshadowing to my future self of all the stuff we will be working on (also have two motors at various stages of preparation). (IMG:style_emoticons/default/biggrin.gif)
Those sure are nice pushrod tubes. Very nice. We already have SS ones longer than stock ones due to the rods and spacers we plan to use. Yours come with pushrod tube spacers, but you aren't using them? Your motor width on this stroker motor isn't a problem I suppose? Very much like the rings welded on to make future pushrod tube seal changes a breeze. Gonna steal that modification and add it to our stroker pushrod tubes and weld something to pry against (maybe a half ring to the bottom half of the tube?). If you don't have it in the plan, maybe consider welding legs/spacers onto the oil pickup to reduce risk of "the Type IV Syndrome ". Couldn't see if you made that modification yet. We used aluminum pushrods on the 2056 motor and have a set of the heavy duty ones like yours for our future builds. Have used a pipe cutter like you, but if you have a lathe available, it's more precise and faster (some use an arrow cutter) and it's another option to sneak up on the perfect length. Kind of a moot point for this motor, but IMHO your rockers have enough adjustability that worrying about over-precision on cutting them to a perfect length isn't 100% necessary. Either way, your valve train geometry looks to be "certified good enough". (IMG:style_emoticons/default/biggrin.gif) Our best wishes for this weekend's breakin!! |
| friethmiller |
Oct 9 2026, 02:35 PM
... Yours come with pushrod tube spacers, but you aren't using them? Your motor width on this stroker motor isn't a problem I suppose? If you don't have it in the plan, maybe consider welding legs/spacers onto the oil pickup to reduce risk of "the Type IV Syndrome ". Couldn't see if you made that modification yet. ... Thanks! Yes, these are TRs standard length push rods but with spacers installed. Sorry I didn't get a pic of that. What leg/spacer modification are you referring? I assume you're talking about the 9.2 ft/lb "bolt of death" on the oil pick-up. (IMG:style_emoticons/default/confused24.gif) Please elaborate. Thanks. |
| Jack Standz |
Oct 9 2026, 03:24 PM
Here's one example of the fix to he,p prevent type iv syndrome:
https://www.thesamba.com/vw/forum/viewtopic.php?p=7934672 |
| friethmiller |
Oct 9 2026, 03:36 PM
Here's one example of the fix to he,p prevent type iv syndrome: https://www.thesamba.com/vw/forum/viewtopic.php?p=7934672 Ah yes! I know the issue but didn't know of this fix. Genius! I'm going to say it's a little late on this build but will very much consider it on my next one, which will be in a few months. Thanks for this! (IMG:style_emoticons/default/smilie_pokal.gif) |
| Jack Standz |
Oct 9 2026, 03:52 PM
There may be some value in turning down the cross bolt/fastener at the point it sits through the oil pickup tube. May prevent side loading the fastener and boss by the camshaft saddle.
The plan is to add legs to the oil pickup bell, but am also considering either leaving off the through bolt (and installing something to plug the case hole) or turning it down so there is enough movement to hopefully prevent type iv syndrome. Plan B is to never let anyone 3lse work on our cars! (IMG:style_emoticons/default/biggrin.gif) Sorry for not mentioning it earlier, but we have been out-of-town lately. |
| Jack Standz |
Oct 9 2026, 03:57 PM
If you remove the oil pickup tube through bolt, you might still be able to push the pickup to one side and add some legs to the oil pickup bell?
| Jack Standz |
Oct 10 2026, 11:03 AM
Here's another version of what someone has done to address the type iv syndrome. Maybe something to consider?
This looks like it might work with an assembled, motor, particularly one Iike yours that hasn't been filled with oil yet. And those "wings" probably don't need to be quite that wide. Attached image(s)
| friethmiller |
Oct 10 2026, 12:27 PM
Ah, yeah. My engine has oil in it for a few days now. It’s too late for me (IMG:style_emoticons/default/sad.gif)
| porschetub |
Oct 10 2026, 11:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,204 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Ah, yeah. My engine has oil in it for a few days now. It’s too late for me (IMG:style_emoticons/default/sad.gif) Great progress as usual, are you planning to keep the carbs fitted after running in is completed ? if so you have a good start with the TR cable setup ,believe they are fiddley to set-up but work well . IMO if the break-in is ok you should have a strong engine there ,good luck with that and sure it will go well (IMG:style_emoticons/default/beerchug.gif) . |
Lo-Fi Version | Time is now: 23rd November 2026 - 09:04 AM |
