> Fred's 2374 -> 2258 Engine Build Thread
friethmiller
post Jun 26 2026, 03:07 PM
I can't believe it but after 1-1/2 years of waiting for my engine components to be machined, I am finally picking up the parts tomorrow (IMG:style_emoticons/default/blink.gif). I will post more after talking to the owner about the issues he found with my case. This is what was holding everything up. Luckily. I have source another case (from my shed) and will be using this one instead. Here's a few pics of the my "other '74" after uncovering it today and wiping off a bit of dust. She needs to ride again! Hoping for Okteenerfest. Stay tuned!
12 Pages V < 1 2 3 4 > »
Replies(20 - 39)
friethmiller
post Jun 27 2026, 08:59 PM
Post #21
QUOTE(Montreal914 @ Jun 27 2026, 08:49 PM) *
All this to say that your LN lifters may be WebCam ones.
Right! I will find out. Here are the cards from both cams. 104 lc on both.
FYI, my intake/exhaust valves are 44/38 and my exhaust is a full 1 5/8” tangerine header + muffler.
friethmiller
post Jun 28 2026, 04:47 PM
Post #22
Trying to verify dimensions here. What is the standard case bore for the type 4 engine? AI says 2.559”. That seems too small. I’m measuring roughly 2.768 for the rear main on a case with a .02 line bore. Why am I off a decimal place? (IMG:style_emoticons/default/idea.gif)
930cabman
post Jun 28 2026, 05:48 PM
Post #23
QUOTE(friethmiller @ Jun 28 2026, 04:47 PM) *
I had my local machinist make up a "case gage", it's a couple thou over to allow for some clearance. I can check tomorrow and report back
cgnj
post Jun 28 2026, 06:06 PM
Post #24
@friethmiller AI is not your friend. That is for a type 1 motor.
Type4 Saddle bore is 70mm or 2.756. 2.768 is correct
friethmiller
post Jun 28 2026, 07:15 PM
Post #25
QUOTE(cgnj @ Jun 28 2026, 07:06 PM) *
Excellent! Thank you. (IMG:style_emoticons/default/beerchug.gif)
friethmiller
post Jun 29 2026, 06:08 PM
Post #26
Ok, I've confirmed two things.
  1. My EA block is too tight on #1, #2, and #3 saddles, as identified by my machinist.
  2. [Thankfully] My W-block checks out at .020 line bore
Working from a STD bore of 2.756" + .020 bore = 2.776". I used the 2-3" micrometer to set 0 on my bore gauge for #1-#3 saddles. Adjusted tips to set zero on my 1-2" micrometer for the #4 saddle at 1.9685 + .020 bore = 1.9885.
Photos of my work to measure each saddle in multiple directions. Will proceed with verifying my brand new crank next before preparing for assembly. So far so good. (IMG:style_emoticons/default/aktion035.gif)
Thanks again to @cgnj for the specs!
Montreal914
post Jun 29 2026, 07:02 PM
Post #27
Good news! (IMG:style_emoticons/default/sunglasses.gif)
Nice metrology tools btw.
Did you get a chance to measure the bearings?
Ninja
post Jun 29 2026, 07:11 PM
Post #28
Are bearings MORE available if you need .020 over on the OD?
I thought main bearings were a bit on the scarce side right now.
Nice work Fred!
zig-n-zag
post Jun 29 2026, 09:34 PM
Post #29
Yes, nice tools you have there.
With the main bearing tunnel being tight, ask your machinist if doing a line
hone can be achieved to re-new the saddles back to standard bearing size?
Jack Standz
post Jun 29 2026, 10:25 PM
Post #30
QUOTE(Ninja @ Jun 30 2026, 08:11 AM) *
Nice work Fred!
AApistons.com shows some .020 case/main bearings available, but not for std crankshaft size. So, depends on what his crankshaft measures at.
Maybe someone else will have the right size. We had a very hard time finding main bearings earlier this year for one motor. The other motor we fortunately already had the proper bearings.
friethmiller
post Jun 30 2026, 07:04 AM
Post #31
QUOTE(zig-n-zag @ Jun 29 2026, 10:34 PM) *
Yes, after I build this motor with my W block, I will likely send the EA block out to be checked and line bored correctly to .020. After waiting for so long for machine work on this build I want, at a minimum, a short block sitting in my garage ready to go. The EA motor will be my back-up (IMG:style_emoticons/default/smile.gif)
friethmiller
post Jun 30 2026, 07:17 AM
Post #32
QUOTE(Montreal914 @ Jun 29 2026, 08:02 PM) *
QUOTE(Ninja @ Jun 29 2026, 08:11 PM) *
QUOTE(Jack Standz @ Jun 29 2026, 11:25 PM) *
I just ordered another set of .020/std bearings last night from LN, just in case. The crank is brand new so it should measure as STD. @Montreal914 , I started looking at the two sets of bearing I do have on-hand. One looks like std/std, which is unobtainium at them moment. The other set is .020/std, however, the split bearing in the box doesn't match the others. These bearings sat in a box at the machine shop and I don't trust what might have happened to them. The Mahle line-bore (.020) bearings are sold out on AA. The do have some Silverline but not at .020/std as @Jack Standz mentioned. So, @Ninja - I think you can still find other non std/std but even those are a bit scarce at the moment.
Ninja
post Jun 30 2026, 08:57 AM
Post #33
I have another question...
How do the main bearing journals get TIGHT????
All the damage I've ever seen INCREASES the bores.
In a normal engine the parting surfaces (both block and cap) get a couple of thousands machined off to reduce the diameter and then a line bore is done back to standard size.
Exception is a "cracked" cap (GM LS series rods) where bore is increased and oversized OD bearings are used.
Never seen/heard about undersized main journals until your thread...
friethmiller
post Jun 30 2026, 09:06 AM
Post #34
QUOTE(Ninja @ Jun 30 2026, 09:57 AM) *
Improper prior machine work, is my guess. The place that did it is no longer in business.
Nogoodwithusernames
post Jun 30 2026, 09:21 AM
Post #35
Fred,
If mains are tight, I would see if the shop can machine them just to STD. No need to go overbore, especially for a "down the road" type project.
friethmiller
post Jun 30 2026, 02:25 PM
Post #36
Ok, three things to report back on. I talked with the machinist and called Web Cams today.
1) The Machinist said he offsets the oil grooves to better cool the bottom of the piston and still splash the wrist pin.
2) He also measured that the saddles #1-#3 on my EA case were all tight. He said he measured between .002 and .0027. This is in line with what I'm measuring. So that gives us a bore between 2.7733" - 2.774". Thats shy of the expected 2.776" for a .020 line bore. Note: #4 (smaller) saddle is spot on. This is a [previous] machining error in my book. Like I said earlier, I'll send this case to get bored to the correct dimensions.
3) The lady at Web Cam said that LN Engineering buys their cams for their builds but they don't buy Web Cam's lifters. She said that both lifters likely derived from the same scat origins and that I'm safe to proceed with using the LN lifters.
friethmiller
post Jul 1 2026, 11:41 AM
Post #37
Please help play.... read the micrometer! This is a 2-3" micrometer. I get 2.776. I hope I'm wrong.
cgnj
post Jul 1 2026, 12:35 PM
Post #38
I'm watching now because you lost me.
Ninja
post Jul 1 2026, 01:21 PM
Post #39
QUOTE(friethmiller @ Jul 1 2026, 12:41 PM) *
Yep!
I'm seeing 2.776 too!
I'm ALSO seeing a cheap mic. (IMG:style_emoticons/default/ninja.gif)
Do you have a 2" and 3" standards?
I'd want those to zero that mic.
One of my favorite mics is a Starrett 1.5-2.5 mic that can be zeroed at the center point with a 2" standard.
Cheap mics can work KICK-ASS but a known accurate standard is a must...
The method you were using the bore gauge (setting zero to your required measurement) is the ONLY way to go in my book.
Hats off to you Sir!
Many so called "machinist" don't do it that way.
Using one tool to determine your clearance is far more accurate than using two
friethmiller
post Jul 1 2026, 01:37 PM
Post #40
QUOTE(Ninja @ Jul 1 2026, 02:21 PM) *
I'm thinking this must be my problem. I swear this W case spec'd out the other day but when I rechecked it yesterday it was .002 - .003 too large. I have a 2" inch standard. let me verify/reset the mic.
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 21st November 2026 - 06:36 PM
