| VaccaRabite |
Jul 24 2026, 07:22 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,894 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Also It’s time for new bushings.
The smart guy gets the ceramic spherical bushing for the firewall. But ALL of them should be replaced. You will be amazed what a transformation it is. Zach |
| 914werke |
Jul 24 2026, 12:13 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,709 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
See the nylon/plastic in there? That's what makes it the one-timer... A dab of blue loctite on a CLEAN but used screw makes it reusable. Zach ..Until in backs out & you are left on the side of the road (IMG:style_emoticons/default/happy11.gif) False economy! Why risk a 200. tow for x2 6. parts? |
| TJB/914 |
Jul 24 2026, 03:48 PM
Mid-Engn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,505 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest
| bdstone914 |
Jul 25 2026, 04:39 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,342 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
.Pelican Parts Porsche Or any of the regular sellers |
| FlacaProductions |
Jul 25 2026, 08:29 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,257 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
https://www.pelicanparts.com/More_Info/9014...RRoCTKcQAvD_BwE
https://sierramadrecollection.com/products/...9zDx7P5JRaNiUWt 901-424-229-00 is the part number you're looking for. |
| emerygt350 |
Jul 25 2026, 08:33 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,678 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
See the nylon/plastic in there? That's what makes it the one-timer... A dab of blue loctite on a CLEAN but used screw makes it reusable. Zach ..Until in backs out & you are left on the side of the road (IMG:style_emoticons/default/happy11.gif) False economy! Why risk a 200. tow for x2 6. parts? That's where the hose clamp becomes the right choice. Tighten the cone screw down and put a hose clamp around that bad boy. |
| Ace Le Count |
Jul 25 2026, 04:40 PM
Looking for 4712908713 ![]() ![]() Group: Members Posts: 219 Joined: 20-February 18 From: Golden Valley, AZ Member No.: 21,910 Region Association: None |
I had this same problem last week on my '73. I pulled back the firewall boot and chunks of the old bushings fell out. I ordered the complete kit from pelican parts. (Great quality, by the way). You will need to get the rear end of the car off the ground to do it. Install is straightforward. I ended up unbolting the stick shift assembly (3 bolts) and slid the front linkage rod forward. I also tried boiling the firewall bushing to get it to go in. After many unsuccessful attempts, I just cut through one side of the bushing with a razor blaze and pushed it in little by little, with the cut end at 12 o'clock. Worked for me. As of Thursday, the car is all put back together and shifts beautifully.
Lo-Fi Version | Time is now: 27th July 2026 - 11:37 AM |
