| nmkimosabe |
Jul 31 2026, 04:18 PM
Member ![]() ![]() Group: Members Posts: 99 Joined: 16-March 25 From: Santa Fe, NM Member No.: 28,660 Region Association: Rocky Mountains |
My 1974 1.8 with fuel injection will only start by manually opening the throttle but I can't get it idle and thus run properly. I recently had the AFM rebuilt and replaced the points, plugs, condenser and replaced the CHT sensor but the problem continues as it did before. I've looked for vacuum leaks to no avail with starter fluid. I now seek the expertise of the members of this forum for additional suggestions.
| nmkimosabe |
Aug 27 2026, 06:13 PM
I will try to clarify the status and progress to date. The original mechanic had no clue and basically lied about what was wrong with the vehicle. He went so far as to say the engine was shot and I knew it wasn't. I found a new mechanic who has been diligently working on the car from top to bottom. Here's a pretty accurate list of work completed:
Compression tested out at approximately 110psi at each of the cylinders Smoke test indicated vac leaks at the oil cap and valve covers --- repaired and retested Throttle valve switch was cleaned and adjusted Replaced the coil Replaced the cylinder head temp sensor Replaced spark plug wires, points, condenser, cap and plugs Checked dwell and points Adjusted valves Rechecked double relay and found broken / overheated pin 88Y. Replaced with spare. Cleaned the ground strap Replaced the ECU with a spare and will retest original to see if it still works...may have misspoken about it being fried Discovered distributor shaft end play in excess of 0.02 in. causing wander in dwell and erratic timing pulse when setting timing. To purchase a rebuilt distributor Hoping this extensive work results in my car returning to its original running condition. I appreciate all of the input and suggestions during this journey. |
| Superhawk996 |
Aug 27 2026, 07:08 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,191 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Given you had a worn distributor is there a reason you wanted to stay with rebuilt stock instead of going to a new 123 distributor?
The thing that bothers me here is your last update was UPDATE: Well, the car finally was running better in the shop but then died when the car was taken for a test drive This really doesn’t align with the bad distributor theory as a bad distributor doesn’t usually work then stop during a test drive. Usually when you get those kind of died instantly while driving failures, it’s electrical in nature. As Wonki suggested, that could extend all the way into the ECU not failing until hot. You may want to reach out to @jeffbowlsby - at one time he was offering a test service of ECU’s in car and with the ECU test equipment but that may have been D-jet only ? You’ve had a lot of parts swapped but I’m still not getting the sense that you have a mechanic that really understands L-jet. Could just be that you’ve had multiple problems masking other problems. (IMG:style_emoticons/default/confused24.gif) I wish I had a better suggestion for you but there’s just too many questions I have that can’t easily be answered 2nd hand not knowing what he’s tested electrically and how he tested it. Maybe Wonkipop has better suggestions - I’m not an L-jet guy and he is. |
| fiacra |
Aug 27 2026, 09:01 PM
Person.Woman.Man.Camera.TV. ![]() ![]() ![]() Group: Members Posts: 770 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California
I can't believe this saga took yet another turn. Hoping replacing the distributor FINALLY does it, but I'm not convinced yet. If you really want to stick with a stock distributor you can see if Bill at Sparxwerks has one in stock. If not, he can rebuild yours. Turnaround was quick for my distributor. I too would put in a vote for a 123 distributor. It makes sense if you already have to replace/rebuild the distributor.
At this point Gary I don't know what to say other than I admire your tenacity, and pity your bank account. I know it's a full day's drive away, but maybe rent a U-Haul car hauler, borrow a friend's truck, and put your car in the hands of the experts at PMB. |
| nmkimosabe |
Aug 28 2026, 04:26 PM
Given you had a worn distributor is there a reason you wanted to stay with rebuilt stock instead of going to a new 123 distributor? The thing that bothers me here is your last update was UPDATE: Well, the car finally was running better in the shop but then died when the car was taken for a test drive This really doesn’t align with the bad distributor theory as a bad distributor doesn’t usually work then stop during a test drive. Usually when you get those kind of died instantly while driving failures, it’s electrical in nature. As Wonki suggested, that could extend all the way into the ECU not failing until hot. You may want to reach out to @jeffbowlsby - at one time he was offering a test service of ECU’s in car and with the ECU test equipment but that may have been D-jet only ? You’ve had a lot of parts swapped but I’m still not getting the sense that you have a mechanic that really understands L-jet. Could just be that you’ve had multiple problems masking other problems. (IMG:style_emoticons/default/confused24.gif) I wish I had a better suggestion for you but there’s just too many questions I have that can’t easily be answered 2nd hand not knowing what he’s tested electrically and how he tested it. Maybe Wonkipop has better suggestions - I’m not an L-jet guy and he is. I appreciate you taking the time to respond. The mechanic now believes the electrical issue when the car died was possibly the burnt 88Y pin on the dual relay which was later switched. I've been as methodical and thorough throughout this process, and it has been quite aggravating. I've had many vintage Porsche's and never experienced this level of frustration. Stay tuned for an update this week. |
| nmkimosabe |
Aug 28 2026, 04:27 PM
I can't believe this saga took yet another turn. Hoping replacing the distributor FINALLY does it, but I'm not convinced yet. If you really want to stick with a stock distributor you can see if Bill at Sparxwerks has one in stock. If not, he can rebuild yours. Turnaround was quick for my distributor. I too would put in a vote for a 123 distributor. It makes sense if you already have to replace/rebuild the distributor. At this point Gary I don't know what to say other than I admire your tenacity, and pity your bank account. I know it's a full day's drive away, but maybe rent a U-Haul car hauler, borrow a friend's truck, and put your car in the hands of the experts at PMB. Thanks for the continuing moral support and I think (hope) we are close! |
| wonkipop |
Aug 29 2026, 05:06 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,783 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
Given you had a worn distributor is there a reason you wanted to stay with rebuilt stock instead of going to a new 123 distributor? The thing that bothers me here is your last update was UPDATE: Well, the car finally was running better in the shop but then died when the car was taken for a test drive This really doesn’t align with the bad distributor theory as a bad distributor doesn’t usually work then stop during a test drive. Usually when you get those kind of died instantly while driving failures, it’s electrical in nature. As Wonki suggested, that could extend all the way into the ECU not failing until hot. You may want to reach out to @jeffbowlsby - at one time he was offering a test service of ECU’s in car and with the ECU test equipment but that may have been D-jet only ? You’ve had a lot of parts swapped but I’m still not getting the sense that you have a mechanic that really understands L-jet. Could just be that you’ve had multiple problems masking other problems. (IMG:style_emoticons/default/confused24.gif) I wish I had a better suggestion for you but there’s just too many questions I have that can’t easily be answered 2nd hand not knowing what he’s tested electrically and how he tested it. Maybe Wonkipop has better suggestions - I’m not an L-jet guy and he is. I appreciate you taking the time to respond. The mechanic now believes the electrical issue when the car died was possibly the burnt 88Y pin on the dual relay which was later switched. I've been as methodical and thorough throughout this process, and it has been quite aggravating. I've had many vintage Porsche's and never experienced this level of frustration. Stay tuned for an update this week. yeah well, the dual relay is real important for having the fuel pump work in an L jet. so........ lets see. i can tell you another interesting story about "ECU"s. going back 25+ years ago, and being an early adopter of CAD (thanks to my time in chicago, (IMG:style_emoticons/default/beerchug.gif) thank you america) i had a hot rodded 486 i ran my drafting and modelling software on. and one day it (IMG:style_emoticons/default/stromberg.gif) itself. i came in the office and fired it up and it ran for about 10 minutes. then kaput. if i remember right i went out for a coffee and cig or three and came back and switched it back on. fired up. ran for 10 minutes. kaput again. sat down and thought about it. right. somethings getting hot and when its up to temp is when if fails. rang my computer tach man nerd at that time. the late 90s were great. nerds door to door. he came and picked up the box and threw it in his ute and took it home. ripped it apart. found the crack in the circuit board. i said great. i have forgotten to back up for a fortnight or two and i have a masterpiece or three on it i need to retrieve. "no worries". he set the box up on his back verandah outside over night with a hard drive to down load all the data and fired it up first thing the next morning and before it could get hot enough to die he managed to get all the data off it. saved our arses. but not our bank account as we had to get a new machine. forced us to get a pentium. (IMG:style_emoticons/default/biggrin.gif) moral of the story. if it runs and idles well etc but then when you head out the door and get 10 minutes down the road and it dies well.............and its an EFI system from half a century ago, you got to suspect some thing electrical. and start testing and diagnosing. and resist spraying it with parts machine gun. i hope this is the end of your troubles. very frustrating as you say. however - i would say this, L jet is very very simple and honestly not hard to get to the bottom of, if you get your brain into what it is. its a fairly limited set of things that can go wrong. |
| fiacra |
Aug 29 2026, 07:54 AM
It's funny how things always seem to circle back to the L-Jet dual relay. Having a spare one with you at all times is a good idea. I think you already have an extra one Gary but if you are in urgent need just let me know. They are often scarce, but still available. CIP1 is out of stock, but JBugs and FCP Euro still shows them as available. FCP Euro currently has the best price. I can no longer get them from my supplier in Europe.
I will also add that if you have a gremlin infestation in your L-Jet electrical system then having Jeff go through your FI harness or having him make a new one for you is a worthy investment. These >50 year old harnesses, especially the wiring exposed to the heat in the engine bay, can cause all kinds of hard to diagnose problems. I know it's an investment to get a new harness, but Jeff's work is top notch and I wouldn't hesitate to do it. I know that your mechanic thinks the FI harness is OK, but think of replacing the harness as a maintenance item at this stage in the life of your car. Given the work that I know you have personally done on this car, replacing the harness is well within your skill set. If electrical items are frying, who knows what is going on in the harness. |
| nmkimosabe |
Aug 29 2026, 12:02 PM
Given you had a worn distributor is there a reason you wanted to stay with rebuilt stock instead of going to a new 123 distributor? The thing that bothers me here is your last update was UPDATE: Well, the car finally was running better in the shop but then died when the car was taken for a test drive This really doesn’t align with the bad distributor theory as a bad distributor doesn’t usually work then stop during a test drive. Usually when you get those kind of died instantly while driving failures, it’s electrical in nature. As Wonki suggested, that could extend all the way into the ECU not failing until hot. You may want to reach out to @jeffbowlsby - at one time he was offering a test service of ECU’s in car and with the ECU test equipment but that may have been D-jet only ? You’ve had a lot of parts swapped but I’m still not getting the sense that you have a mechanic that really understands L-jet. Could just be that you’ve had multiple problems masking other problems. (IMG:style_emoticons/default/confused24.gif) I wish I had a better suggestion for you but there’s just too many questions I have that can’t easily be answered 2nd hand not knowing what he’s tested electrically and how he tested it. Maybe Wonkipop has better suggestions - I’m not an L-jet guy and he is. I appreciate you taking the time to respond. The mechanic now believes the electrical issue when the car died was possibly the burnt 88Y pin on the dual relay which was later switched. I've been as methodical and thorough throughout this process, and it has been quite aggravating. I've had many vintage Porsche's and never experienced this level of frustration. Stay tuned for an update this week. yeah well, the dual relay is real important for having the fuel pump work in an L jet. so........ lets see. i can tell you another interesting story about "ECU"s. going back 25+ years ago, and being an early adopter of CAD (thanks to my time in chicago, (IMG:style_emoticons/default/beerchug.gif) thank you america) i had a hot rodded 486 i ran my drafting and modelling software on. and one day it (IMG:style_emoticons/default/stromberg.gif) itself. i came in the office and fired it up and it ran for about 10 minutes. then kaput. if i remember right i went out for a coffee and cig or three and came back and switched it back on. fired up. ran for 10 minutes. kaput again. sat down and thought about it. right. somethings getting hot and when its up to temp is when if fails. rang my computer tach man nerd at that time. the late 90s were great. nerds door to door. he came and picked up the box and threw it in his ute and took it home. ripped it apart. found the crack in the circuit board. i said great. i have forgotten to back up for a fortnight or two and i have a masterpiece or three on it i need to retrieve. "no worries". he set the box up on his back verandah outside over night with a hard drive to down load all the data and fired it up first thing the next morning and before it could get hot enough to die he managed to get all the data off it. saved our arses. but not our bank account as we had to get a new machine. forced us to get a pentium. (IMG:style_emoticons/default/biggrin.gif) moral of the story. if it runs and idles well etc but then when you head out the door and get 10 minutes down the road and it dies well.............and its an EFI system from half a century ago, you got to suspect some thing electrical. and start testing and diagnosing. and resist spraying it with parts machine gun. i hope this is the end of your troubles. very frustrating as you say. however - i would say this, L jet is very very simple and honestly not hard to get to the bottom of, if you get your brain into what it is. its a fairly limited set of things that can go wrong. I love your story about the hot -rodded 486 and I have similar memories of those and the IT nerds running around the company offices. I would agree that L-jet seems like a simple system once you figure it out, but it does require a learning curve to understand it fully and how all the components work together. Of course, what doesn't. I'm curious as to why you live in Antartica? |
| nmkimosabe |
Aug 29 2026, 12:06 PM
It's funny how things always seem to circle back to the L-Jet dual relay. Having a spare one with you at all times is a good idea. I think you already have an extra one Gary but if you are in urgent need just let me know. They are often scarce, but still available. CIP1 is out of stock, but JBugs and FCP Euro still shows them as available. FCP Euro currently has the best price. I can no longer get them from my supplier in Europe. I will also add that if you have a gremlin infestation in your L-Jet electrical system then having Jeff go through your FI harness or having him make a new one for you is a worthy investment. These >50 year old harnesses, especially the wiring exposed to the heat in the engine bay, can cause all kinds of hard to diagnose problems. I know it's an investment to get a new harness, but Jeff's work is top notch and I wouldn't hesitate to do it. I know that your mechanic thinks the FI harness is OK, but think of replacing the harness as a maintenance item at this stage in the life of your car. Given the work that I know you have personally done on this car, replacing the harness is well within your skill set. If electrical items are frying, who knows what is going on in the harness. Thanks for the offer of the dual relay but fortunately I had a spare probably because you told me months ago to have one just in case! Guess i need to get another one as my spare is now being used. I spoke with Jeff awhile back and once I get my car back, I think the next thing I will do is replace the wiring harness. I need to some research about installing one first. Looking at the harnesses on Jeff's site it doesn't look too difficult if one pays attention. Have a good weekend. |
| wonkipop |
Aug 29 2026, 02:07 PM
[quote name='nmkimosabe' date='Aug 29 2026, 12:02 PM' post='3270040']
[quote name='wonkipop' post='3270009' date='Aug 29 2026, 05:06 AM'] [quote name='nmkimosabe' post='3269962' date='Aug 28 2026, 04:26 PM'] [quote name='Superhawk996' post='3269857' date='Aug 27 2026, 07:08 PM'] [/quote] I love your story about the hot -rodded 486 and I have similar memories of those and the IT nerds running around the company offices. I would agree that L-jet seems like a simple system once you figure it out, but it does require a learning curve to understand it fully and how all the components work together. Of course, what doesn't. I'm curious as to why you live in Antartica? [/quote] (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) north antarctica. an internationally irrelevant island continent off the coast of antarctica on the edge of the southern ocean. i live in the post industrial resort town of melbourne - thats mell bun not mel born. antarctic research staff take their summer breaks here. where the factory was that the first car in antartica was made. sadly the old VW factory was pulled down last year. i think someone managed to get the famous sign - a giant VW emblem. it was lying on the ground at one stage. i thought about it but decided it was a little large to fit on the garage wall. ![]() |
| nmkimosabe |
Sep 5 2026, 05:34 PM
It was suggested to me today by a person with several 914's that since it now runs and idles but doesn't want to perform properly under load that perhaps I may have a flat cam. How common is this issue and could this be the problem? It's never been mentioned before by anyone. Any input is welcome.
| Superhawk996 |
Sep 5 2026, 08:41 PM
Not likely.
Can be measured if you really wanted to. I’d focus on the basics. Are you capable of pulling the spark plugs and posting photos? |
| nmkimosabe |
Sep 6 2026, 05:19 PM
Not likely. Can be measured if you really wanted to. I’d focus on the basics. Are you capable of pulling the spark plugs and posting photos? I hope you're right about the cam as that would be a whole new ballgame. I'm curious where you are headed with the spark plug inspection? |
| wonkipop |
Sep 6 2026, 07:49 PM
It was suggested to me today by a person with several 914's that since it now runs and idles but doesn't want to perform properly under load that perhaps I may have a flat cam. How common is this issue and could this be the problem? It's never been mentioned before by anyone. Any input is welcome. given how you initially reported to me the problem suddenly emerging - i would so no to this diagnosis re camshaft. |
| nmkimosabe |
Sep 7 2026, 03:37 PM
It was suggested to me today by a person with several 914's that since it now runs and idles but doesn't want to perform properly under load that perhaps I may have a flat cam. How common is this issue and could this be the problem? It's never been mentioned before by anyone. Any input is welcome. given how you initially reported to me the problem suddenly emerging - i would so no to this diagnosis re camshaft. I sure hope you and others are correct as It's never come up until someone mentioned it at a car show Saturday. So I finally realized that you are in Australia ---is that correct? Appreciate your feedback. |
| wonkipop |
Sep 7 2026, 05:09 PM
It was suggested to me today by a person with several 914's that since it now runs and idles but doesn't want to perform properly under load that perhaps I may have a flat cam. How common is this issue and could this be the problem? It's never been mentioned before by anyone. Any input is welcome. given how you initially reported to me the problem suddenly emerging - i would so no to this diagnosis re camshaft. I sure hope you and others are correct as It's never come up until someone mentioned it at a car show Saturday. So I finally realized that you are in Australia ---is that correct? Appreciate your feedback. yes. aus. once known as terra incognita. though i spent time in your wonderful country back in late 80s/early 90s. went to grad school in chicago. where and when i got my 914 that i brought back here. its travelled 2/3 + around the world and crossed two oceans since it was made. |
| nmkimosabe |
Sep 8 2026, 12:35 PM
It was suggested to me today by a person with several 914's that since it now runs and idles but doesn't want to perform properly under load that perhaps I may have a flat cam. How common is this issue and could this be the problem? It's never been mentioned before by anyone. Any input is welcome. given how you initially reported to me the problem suddenly emerging - i would so no to this diagnosis re camshaft. I sure hope you and others are correct as It's never come up until someone mentioned it at a car show Saturday. So I finally realized that you are in Australia ---is that correct? Appreciate your feedback. yes. aus. once known as terra incognita. though i spent time in your wonderful country back in late 80s/early 90s. went to grad school in chicago. where and when i got my 914 that i brought back here. its travelled 2/3 + around the world and crossed two oceans since it was made. Pretty amazing have your 914 visiting the world with you. Can you get service work done over there? My Uncle lived in Australia when he was stationed there for years and loved it. I've been reading more about cam issues and it doesn't seem like they just happen overnight but slowly your car will begin to lose its power and only get worse. We are revisiting the fuel pump under load and also further inspecting the dual relay in case it's overheating under load. Stay tuned. |
| wonkipop |
Sep 8 2026, 01:00 PM
@nmkimosabe
situation re servicing /parts etc for aged aircooled VWs or porsches is identical to USA. all the old air cooled mechanics are dead or retired. specialists machinists etc are dying out, but thats not restricted to being an air cooled thing. parts access is per USA situation. i do a good deal of work on the car myself and what i don't do gets done by our resident mechanic. there are a bunch of us here with a co-operative workshop. our cars get worked on by him on heavy duty matters. for instance he rebuilt all the suspension on my 914 when i recommissioned it about 5 years or so back. i had had its stored for the 16 years or so previous. the rest of the recommission work i assisted him. for the last three months i have been head down - arse up on 4 late 60s / early 70s mercedes benzs. working with the mechanic on various recommissioning and minor restoration servicing issues on those cars. one of which is a 1972 benz CE250 still running its D jet EFI system. its turned out to be a pretty special car. another of them is a benx 6.3 - the big V8. mechanically fuel injected. its been fun. i've been attending to all the interior wood trim in all the cars - amongst other things. have developed another useless set of skills as a result. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) its all fun. the older cars are not necessarily the headache for parts at present. funnily enough its the cars that are about 20-25 years old that parts are drying up on (which are cars that do not have extensive cult followings say like the 914). i have a friend with a 97 citroen xantia we look after for her. that car is suddely proving very difficult to get bits and bobs for. but she persists. she loves it. its sort of the last of the fully hydraulic citroens and they just don't make em like that anymore. (IMG:style_emoticons/default/beerchug.gif) good luck with your 1.8 sometimes it can be exasperating trying to get to the bottom of a niggle. |
| nmkimosabe |
Sep 9 2026, 11:03 AM
@nmkimosabe situation re servicing /parts etc for aged aircooled VWs or porsches is identical to USA. all the old air cooled mechanics are dead or retired. specialists machinists etc are dying out, but thats not restricted to being an air cooled thing. parts access is per USA situation. i do a good deal of work on the car myself and what i don't do gets done by our resident mechanic. there are a bunch of us here with a co-operative workshop. our cars get worked on by him on heavy duty matters. for instance he rebuilt all the suspension on my 914 when i recommissioned it about 5 years or so back. i had had its stored for the 16 years or so previous. the rest of the recommission work i assisted him. for the last three months i have been head down - arse up on 4 late 60s / early 70s mercedes benzs. working with the mechanic on various recommissioning and minor restoration servicing issues on those cars. one of which is a 1972 benz CE250 still running its D jet EFI system. its turned out to be a pretty special car. another of them is a benx 6.3 - the big V8. mechanically fuel injected. its been fun. i've been attending to all the interior wood trim in all the cars - amongst other things. have developed another useless set of skills as a result. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) its all fun. the older cars are not necessarily the headache for parts at present. funnily enough its the cars that are about 20-25 years old that parts are drying up on (which are cars that do not have extensive cult followings say like the 914). i have a friend with a 97 citroen xantia we look after for her. that car is suddely proving very difficult to get bits and bobs for. but she persists. she loves it. its sort of the last of the fully hydraulic citroens and they just don't make em like that anymore. (IMG:style_emoticons/default/beerchug.gif) good luck with your 1.8 sometimes it can be exasperating trying to get to the bottom of a niggle. @wonkipop It sounds like you have a lot going on with different and interesting cars over there. I have an 1987 Alfa Romeo Spider Veloche that we bought new, and it's been a great car and also has the L-jet type engine. You are correct about these air-cooled mechanics retiring or passing away. It's really all professional trade folks such as upholsters and others. I had a friend who did custom upholstery and none of his employees were interested in buying it for nothing, so he closed the shop. Where i live there are a lot of retired wealthy folks with cool cars including one guy with a Citroen. One of my best friend's daughter lives in Sydney and owns some type of fitness center. I'm hoping my mechanic is able to figure out the issue now that it at least is running as I suspect it could be a fuel pump or dual relay that craps out under load and not the cam. Fingers crossed. Have a good day working on your cars! |
| wonkipop |
Sep 9 2026, 01:12 PM
@nmkimosabe
re 87 alfa romeo spider. thats a coincidence. one of the guys here at the workshop has exact same car. an 87. gold paint. he picked it up last year from up country. its been here for about 20 odd years. orig came from mid west USA. the guy he bought it from privately imported it and converted it to right hand drive using a very high quality english kit. quite a simple conversion from left to right hand drive using tube rod control levers that leave clutch operation and brake master cylinder on left hand side of engine bay firewall. uses a right hand drive steering box sourced from original parts and a very high quality dashboard moulding. it was running like (IMG:style_emoticons/default/stromberg.gif) when he first got it. but apart from that was in first class shape cosmetically etc. basically had been a summer car in the USA since new. he mucked around with it for a while after he first got it trying to get it right. i had tossed him some tech lit on L jet but like a lot of old school guys he failed to read it and persisted with his stoopid carb mentality, turning idle screws etc and going nowhere. one day i just got sick of him hogging the service space and walked over - grabbed the plastic intake boot that ran from the air cleaner to the throttle body and wiggled it around while it was idling. engine died. he looked at me with a face that was a big question mark. i just said read the literature. its got an air leak you clown. sure enough the boot had cracks everywhere on its underside hidden from view and when you revved the engine to take off from the lights just twisting on its engine mounts was enough to open up the cracks and either kill the engine or make it stumble horribly. car runs great now and is a very nice piece of kit. in superb condition. very low miles and still all original. paint etc. as to citroens. i briefly owned an XM. very interesting car. very pleasant to drive. when it was going. i eventually lost patience with it and moved it on. got that out of my system. too smart for their own good those cars. but people who like them seem to really like them. however it won't be long before it gets just about impossible to keep one on the road. big big problem is getting hold of the hydraulic pressure spheres. supply has dried up and we are pretty much down to one guy in the whole of aus who will recharge and recondition them. once you can't get those its all over for those cars. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 24th November 2026 - 09:09 PM |
