> Starting Problems, Starting with Throttle but Won't Idle
nmkimosabe
post Jul 31 2026, 04:18 PM
My 1974 1.8 with fuel injection will only start by manually opening the throttle but I can't get it idle and thus run properly. I recently had the AFM rebuilt and replaced the points, plugs, condenser and replaced the CHT sensor but the problem continues as it did before. I've looked for vacuum leaks to no avail with starter fluid. I now seek the expertise of the members of this forum for additional suggestions.
6 Pages V < 1 2 3 4 5 > »
Replies(40 - 59)
wonkipop
post Sep 9 2026, 01:28 PM
Post #41
@nmkimosabe
some other tips for you re your 1.8 problem.
make sure you don't have a collapsing fuel line somewhere.
they can fail with age - especially at tightish bends.
will collapse inward and strangle fuel supply.
be fine at idle but as soon as you give it some stick and demand the line will squash inwards cutting off supply.
sort of thing that can happen if the car has been lying around for a while and not being driven and then you start using it again and trouble starts.
i'm sure you would have checked the filter (or filters if additional have been fitted) to make sure they are clear. and the sock in the fuel tank at the intake can sometimes give trouble after all these years.
also check the operation of the distributor mechanical advance.
if you still have the original distributor with points and all.
could be sticking and require freeing up and lubrication if your mechanic has not already done that.
nmkimosabe
post Sep 9 2026, 04:16 PM
Post #42
QUOTE(wonkipop @ Sep 9 2026, 01:12 PM) *
@nmkimosabe
re 87 alfa romeo spider. thats a coincidence. one of the guys here at the workshop has exact same car. an 87. gold paint. he picked it up last year from up country. its been here for about 20 odd years. orig came from mid west USA. the guy he bought it from privately imported it and converted it to right hand drive using a very high quality english kit. quite a simple conversion from left to right hand drive using tube rod control levers that leave clutch operation and brake master cylinder on left hand side of engine bay firewall. uses a right hand drive steering box sourced from original parts and a very high quality dashboard moulding.
it was running like (IMG:style_emoticons/default/stromberg.gif) when he first got it. but apart from that was in first class shape cosmetically etc. basically had been a summer car in the USA since new.
he mucked around with it for a while after he first got it trying to get it right. i had tossed him some tech lit on L jet but like a lot of old school guys he failed to read it and persisted with his stoopid carb mentality, turning idle screws etc and going nowhere.
one day i just got sick of him hogging the service space and walked over - grabbed the plastic intake boot that ran from the air cleaner to the throttle body and wiggled it around while it was idling. engine died. he looked at me with a face that was a big question mark. i just said read the literature. its got an air leak you clown. sure enough the boot had cracks everywhere on its underside hidden from view and when you revved the engine to take off from the lights just twisting on its engine mounts was enough to open up the cracks and either kill the engine or make it stumble horribly.
car runs great now and is a very nice piece of kit. in superb condition. very low miles and still all original. paint etc.
as to citroens. i briefly owned an XM. very interesting car. very pleasant to drive.
when it was going. i eventually lost patience with it and moved it on. got that out of my system. too smart for their own good those cars. but people who like them seem to really like them. however, it won't be long before it gets just about impossible to keep one on the road. big big problem is getting hold of the hydraulic pressure spheres. supply has dried up and we are pretty much down to one guy in the whole of aus who will recharge and recondition them. once you can't get those its all over for those cars.
(IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
@wonkipop
My wife actually bought the Alfa new and it's in great shape and only has around 80,000 miles on it and looks brand new. She thought about selling it this summer but in great shape these cars generally max out at $18,000 if you're lucky. So why sell? I replaced all cloth vacuum hoses with rubber ones this summer and replaced the short boot connector towards the throttle body as it had a slight crack. Converting to a right-hand drive sounds like a major operation to me. My other project right now is getting my neighbors Vespa running. He's an older guy and it's been sitting for like five years so I've replaced the fuel line, vac line, had the car refurbished and replaced the petcock. I'm waiting on the intake manifold boot which has a crack and these things are highly sensitive to vac leaks as well. He was just going to trash it which is really stupid as they aren't cheap.
nmkimosabe
post Sep 15 2026, 04:37 PM
Post #43
QUOTE(wonkipop @ Sep 9 2026, 01:28 PM) *
@nmkimosabe
UPDATE:
The mechanic said there's no cam issue as he adjusted all the valves awhile back. The car starts, idles nice and has a strong throttle. After a while when the car is hot it then stalls. It cools and then is fine. So we have a heat induced stalling issue. We will retest the CHT sensor, check the fuel pressure while he is driving it and also look at possible heater plumbing underneath deflecting hot air onto the fuel pump causing a vapor lock. He also plans to double check the wiring from the dual relay to the fuel pump. If we can find that gremlin, we should be good to go. Outside chance the fuel pump could be failing but he doesn't think so at this point. Do you have any thoughts on this plan? Thanks.
Superhawk996
post Sep 15 2026, 07:28 PM
Post #44
Here is the curve for CHT sensor - you will have an 012 CHT sensor.
Check both hot and cold Attached Image
Have I missed it or has your mechanic covered the basics?
When the car stalls and won’t start - what is the problem? Not getting spark or fuel mix / not getting fuel?
The spark plugs & pulling plugs can help tell that story both by observing the mix but also by physically observing the spark (ie is it weak yellowish spark, or is it a good strong white/blue spark) when it won’t start.
Forgive me for being blunt but it just seems this mechanic guy isn’t giving you very basic information. Maybe I’m just not following this closely enough to be of good assistance to you. (IMG:style_emoticons/default/confused24.gif)
nmkimosabe
post Sep 16 2026, 12:22 PM
Post #45
QUOTE(Superhawk996 @ Sep 15 2026, 07:28 PM) *
@Superhawk996
Thanks for the CHT data. I probably could have done a better job of keeping you updated and I apologize since you have been a constant contributor. My car is in the home stretch as it starts, idles great and has full power. After some time driving the car stalls and the thought is a heat induced issue. Since the fuel pump is in the original location on a shelf below the engine it could be a vapor lock. We saw bubbles in teh return fuel line which also possibly points to an overheated fuel pump. We are testing the CHT, checking the fuel tank sock, fuel lines and heater plumbing possibly deflecting air on the fuel pump. Fuel pump will also be tested under actual driving conditions in case that is the culprit as well. If you think of anything else please post it and thanks again for your posts.
Superhawk996
post Sep 16 2026, 02:57 PM
Post #46
Lets be clear here. You have no obligation to keep me posted. However, I would like to see you get your issue resolved and get you driving. I understand how frustrating this has to be for you. I also understand how easy it is for mechanics to run up a bill needlessly as well.
My goal is to help and to be helpful to you.
Forgive me in advance. I'm going to continue to be blunt. I don't think this mechanic has a clue. Forgive me this post is going to get lengthy.
If you are friends with this guy or he's working for free. It's all fine. Keep doing what your doing. Eventually, the car will get fixed.
If you are paying this guy shop rate to keep guessing, throwing parts at it, and/or not doing actual logical troubleshooting based on symptoms, testing, and reacting to the test results, you're getting fleeced and I'd like to help prevent that.
Why do I say this and why am I so confident in saying it? Lets break this down.
When the car has been running then stalls, it is literally a 5-15 minute job to determine whether it is a ignition problem (ie no spark) or a fuel problem. There is zero guess work involved in this.
Spark is in one of three states: Not there, weak, or Present (strong and white/blue color).
If you have a strong blue/white spark present at the tip of the spark plug -- you immediately know with certainty you have a fuel problem. You have to look at the tip of the plug. Just because a spark plug wire sparks at the top terminal, that doesn't necessarily mean the spark is present at the business end of the plug.
If you have a fuel problem that can quickly be broken down to 3 states:
No fuel present for whatever reason
Lean Mixture that won't light off and combust
Rich Mixture that won't light off and combust
Each of the three have their own troubleshooting that can be done with zero guesswork.
No fuel present is easy to diagnose with a fuel pressure gauge or by pulling an injector and seeing if you have fuel spraying from the injectors when it wont start.
Lean - easily confirmed by looking at the spark plugs and by using starting fluid. If its truly lean or not getting any fuel at all, a few brief shots of starting fluid into the intake with get the car coughing or sputtering briefly -- confirming the problem.
Rich -- easily confirmed by looking at the spark plugs. Excessively black, sooty, carbon fouled, and/or soaking wet with gasoline will not allow the engine to start. This has its own troubleshooting techniques.
Lets break down your list piece by piece:
"Since the fuel pump is in the original location on a shelf below the engine it could be a vapor lock. We saw bubbles in the return fuel line which also possibly points to an overheated fuel pump."
Bubbles in the return line really aren't indicative of anything particular. The design of the 3 port pump is such that it has a means to self prime if air has gotten into the fuel lines.
If it truly is vapor lock -- that is easily checked by looking at fuel pressure on the supply line. This isn't guesswork. Fuel pressure is at spec when it won't start or it isn't. If anything vapor lock will produce a lean condition -- and again starting fluid would quickly confirm this by making the car cough for a few seconds.
"We are testing the CHT"
The typical failure mode for the CHT is to go open circuit or way too high of a resistance when hot causing an excessive rich condition that won't start but often smells of raw, unburned fuel at the tailpipe. Any competent mechanic would be familiar with this smell.
Super quick to check the CHT with a multimeter and zero guesswork is involved.
Again, a visual plug check is one way of confirming whether the CHT is forcing a rich or lean condition that is resulting in the no start when hot. Starting fluid test is quick too but depends on which way the mixture is (rich vs. lean)
"checking the fuel tank sock"
There is almost zero reason to be checking the fuel tank sock unless it is 100% confirmed, beyond any doubt, that the fuel pump is being starved of fuel. This is a bunch of work to drain the tank, pull the sock, and then hope you haven't created leaks or pinched the undertank fuel hose resulting in more problems.
Sure if you have zero fuel flow, this would be reasonable. But at this point your mechanic hasn't confirmed anything that would indicate that checking the sock is even relevant. The condition of the sock would have zero correlation to it stalling only when hot.
" fuel lines"
Again this is basically a binary. You either have fuel flow or you don't.
"heater plumbing possibly deflecting air on the fuel pump."
Not saying that this wouldn't contribute to vapor lock but until your mechanic actually confirms you have vapor lock and the inability to build fuel pressure after the car has heated and stalled, this is just a waste of time and would be billable hours for him. Correct me if I'm mistaken but at Mid-September the ambient temps in New Mexico are not even all that favorable for vapor lock to even be on the table.
"Fuel pump will also be tested under actual driving conditions in case that is the culprit as well."
I'm not sure what to say other than after two months of you struggling to solve the issues -- I cannot fathom why the fuel pump and fuel pressure is even a topic of conversation. It is one of the very first things that should have been measured and verified. Cold, Hot, running, and after the engine has stalled and won't restart.
So basically, these proposed things to check are all over the map between no fuel, lean, and rich with no confirmation that spark is even present at the business end of the spark plug when the car is in a no-start condition.
In order to help you move forward, and to potentially save you from being financially bled by this guy, we need to at least get information about whether you have spark present at the tip of the spark plug when the car won't start. Anything less than that with 100% certainty is just him jerking you around.
I may be completely off my rocker and lacking relevant nformation about whether there is spark present during the no-start. If this is the case. Ignore my ranting. (IMG:style_emoticons/default/happy11.gif)
wonkipop
post Sep 16 2026, 03:00 PM
Post #47
QUOTE(nmkimosabe @ Sep 16 2026, 12:22 PM) *
@Superhawk996
good.
i think you and your mechanic (this is the third mecjanic if i read the history of this correctly?) are on the correct trail.
as a tip. usually vapor lock in the fuel pumps is not an issue for the car on the move.
it tends only to happen after a shutdown following a good long hot run. radiant heat from the engine (primarily from the magnesium alloy cooling fan shroud in my opinion) causes boiling in both the fuel line snaking along the back of the firewall and the pump itself. yes heated air from the heater valve near the fuel pump always seems as if its a villain when the heater is not in use and its open exhausting hot air, but when the car is moving its drawn away by the venturi air flow under the car. i would tend to dismiss vapor lock as the issue if this is simply occuring a shortish time after the engine is running. also it does not really fit with how the problem emerged - suddenly after running ok the previous day way back when this started. and i'd add you would have been noticing if your car had vapor lock problems years ago.
some bubbles in the return line are normal. the fuel pump and fuel line attached to the third port on the original style fuel pumps are designed to do this. thats how it gets rid of air in the system. modern two port pumps also designed to do this. they tend to do it back through the supply line.
to me what is happening continues to point to an electrical component issue.
it is sounding like a heat related failure. soon as component gets hot it fails.
i'd be looking real hard at the CHT making sure its working when its warmed up.
then move to other components. i know the ECU has been dismissed as an unlikely possibility and probably is. but it can suffer at this point in time from a heat related failure too. works fine then fails when heated after operation for a while. id make it last on my list as its a very durable item that was heavily over engineered when it was made back the day.
sometimes it can get a bit tricky with these heat related component failures.
they test fine cold but fail when they hit a certain temp after operating for a while.
a corroded wire or dirty corroded connection can also do this exact behaviour.
anyway it sounds like you and your mechanic are close. real close to solving this.
wonkipop
post Sep 16 2026, 03:20 PM
Post #48
i should add the symptoms are also fitting a fuel blockage supply issue.
this can be due to a collapsed fuel line.
you wll find this where there are rubber hoses connecting more rigid sections of fuel lines. they run fine for a while but suction of fuel causes the line to collapse after a time strangling off fuel supply. also if aged hoses they fail internally and collapse inward.
it can be filter. will run fine for a while until whatever is blockng the filter is drawn back into the filter and clogs it. floats away after you shut off. repeats.
sock in tank could also be trouble in a similar way.
if old fuel lines will collapse inside and not necessarily be visible.
if new fuel lines will have been curved in too tighter a bend.
the best way to check this initially is plumb in a fuel pressure gauge into the injector loop after the fuel pump in the engine bay. usually the line to the cold start injector is the best place. plumb it in. start the engine. run it as you have been. wait for the moment when it has the stop running point and keep an eye on the gauge. does the pressure drop just before the engine stops running. thats going to confirm a fuel delivery problem. either a blockage or a loss of signal to the fuel pump which causes it to stop running. do it a second time, run the whole sequence again but this time have the car up on a hoist or in a position where you are able to get your head under the car and listen to the pump. see if it stops running just before the engine dies.
if you can get your hand up there you can also just feel the pump. it wll be vibrating when running.
thinking about the fuel pump. if its an original. there is nothing really in there internally to fail in the way you are describing. i know because i have rebuilt three of those 3 port pumps entirely top to bottom. when they fail its usually total kaput. the electrical motor inside it wears out either its brushes or the rotor. or the seals go and it leaks fuel everywhere but usually out of the electrical plug connection. so i doubt its the fuel pump. internal failure of a fuel pump is almost always total kaput. could be the connection or wires to it but i doubt its the pump itself.
wonkipop
post Sep 16 2026, 03:38 PM
Post #49
re vapor lock as an issue.
i live in a real hot place despite it being north antarctica.
real hot in summer that is.
cold in winter though. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
i've only had the vapor lock problem a couple of times.
fuel pump is in stock location.
once was in chicago in summer after a good long hot drive to michigan.
stopped at a park in chicago for a rest. would not restart after half an hour.
walked away and sat back down in the park. after about an hour it was fine.
and once again when i lived in perth.
similar scenario.
that was years and years ago.
since recommissioning i have fitted metal fuel lines to replace the original stock plastic.
i have shielded the fuel lines where they run across the back of the firewall with reflective insulation. done nothing with the fuel pump in terms of shielding.
have never had any vapor lock problems since then which was about 6 years ago.
its had at least two very long runs up country. got plenty hot. shut down for a stop in a country town for half an hour while i had a coffee. np problem restarting.
perfect conditions for vapor lock. was a classic hot early australian summer day too.
temp in the low 30s (centigrade). i'm fairly convinced myself that the problems with vapor lock are in the feed lines across the firewall rather than the pump when it comes to vapor lock. i could be wrong, but it is my theory now and i am sticking with it.
i don't drive it in high summer here. temps are too high to be comfortable in the car.
high 30s even low 40s C. so its never had that harsh test.
wonkipop
post Sep 16 2026, 04:08 PM
Post #50
ps
the fuel pressure figures you are looking for on an L jet is 35 lbs at higher revs under load- acceleraton (engine demanding fuel) and dropping to 28 libs at idle.
the figures are different from a D jet which is i believe a constant 28 libs.
the fuel pump and fuel pressure regulator are geared for this.
the fpr does it via the vacuum connection which triggers the pressure drop under high manifold vacuum (idle and cruise conditions).
the fuel pump has to be able to deliver the pressure (and flow) of 35 lbs.
usually the fuel pumps have no trouble with this. they are designed to achieve around 60 to 70 lbs before they pressure relieve themselves through the third port if there is a failure further up line in the injector ring section. this would be caused by a jammed fuel pressure regulator. its all designed to stop it bursting fuel lines etc in the injector ring. not being able to maintain 35 lbs in that ring under demand would be of concern.
wonkipop
post Sep 16 2026, 04:20 PM
Post #51
QUOTE(Superhawk996 @ Sep 16 2026, 02:57 PM) *
" fuel lines"
i think he is on his third mechanic @Superhawk996 .
the first one sounded hopeless.
the guy on the car now sounds a lot more careful and methodical.
has definitely made progress.
some of the other suggestions have come from outside sources.
ie the flat camshaft one. a complete furphy.
i don't think any of the mechanics were involved in that suggestion.
anyways - it can be frustrating and persistence and patience is required.
they are beautifully sweet little engines the L jet 1.8s.
but everything is getting old now - including the mechanics who have familiarity with them and of course the time and patience to persist.
a lot of costs and pressures on anyone in any trade or business these days - dunno what its like in the USA at the moment but the economy has gone to hell down here which puts extra pressure on regular mechanics running their shops and businesses.
but it definitely sounds like progress in being made with the guy he has the car with now.
down here if you find a good mechanic you stick to them like glue.
a disappearing species?
Superhawk996
post Sep 16 2026, 05:03 PM
Post #52
@wonkipop
The state of the repair industry is (IMG:style_emoticons/default/sheeplove.gif) here. Lots of reasons but its become very hard to find good & honest shops.
Case in point. In 2023 when I was working `100% of my time to frame & build my garage, I sent the BMW to a local "highly rated" "reputable" Indy European specialty shop for a simple serpentine belt replacement and tensioner replacement. I just didn't have the time to do it myself.
They are the highest rated shop in my area for European cars and honestly there aren't many good alternatives here.
Easy right?
Well this year the belt starts squealing like a stuck pig.
So this time I did the work. Found the tensioner was never replaced. It was clear it hadn't been replaced based on the corrosion on it and more importantly the date codes on the tension parts.
The date codes were dated back to 2016 and 2017. Aluminum casting was dated 2016. The idler wheel was dated 2017. The assembly was dated 2017.
There is no way in hell that was a new part that had been sitting in a warehouse for 6 years before being sold to a high volume BMW shop to be installed in my car. The wear and corrosion on the part made it 100% clear that it was never replaced in 2023.
That but 1 very personal example I had occur directly. Having been an engineer within the auto industry for my entire career (30 years) with major OEM's I could tell you horror stories of the scams that go on inside the dealership network of claimed warranty and recall work that never happened even though it was billed.
I totally get your point, and a good mechanic is indeed worth his weight in gold. I may be wrong, but based on the information that has been posted about this car over the course of the summer, I don't think OP has one.
It could be that I'm just not understanding what is going on in the background or that information isn't being clearly communicated here. I'm just making an observation based on what is in this thread as well as the prior 2 or 3 that OP posted. From what is posted its very clear the mechanic has not done very basic troubleshooting to resolve what is happening once the car gets hot and stalls.
I honestly hope I'm wrong.
wonkipop
post Sep 17 2026, 02:49 AM
Post #53
yeah.
right on @Superhawk996 .
mike in here just sorted out an audi TT.
was reported to be making a high pitched squeal from the engine.
it did it when it first arrived on the back of the flat bed.
then fark me, it stopped doing it.
mike had it in the shop for 3 weeks trying to make it squeal again.
bastard thing would not do it and it was taking up space in the shop.
fortunately customer (widow of good friend of patron owner) was patient.
finally mike just said fark it and took it for a good heave ho up the expressway that leaves town for sydney and just kept driving. it started squealing.
drove it back to the workshop, put me in it and lifted it on the hoist.
i had instructions to rev it to 2000 and hold it.
he isolated the sound inside the timing case behind the timing cover.
off came the timing cover. water pump was leaking anyway.
lo and behold the tiniest of the pulleys had a worn bearing.
it would track true at times - no noise and then could get itself slightly off true - noise.
was it replaced the last time the timing belts were done?
everything else appeared to have been replaced.
but not the pulley? or replaced but shite part? though the tensioner was down to its last legs!
yep. its not good out there in "specialist" land.
any number of reasons. could not obtain pulley? - with timing belt kit.
who knows. but when last done it went ahead we suspect without replacement pulley wheel. just a wheel the timing belt whips around on its journey.
waiting to drive valves into pistons. probably the cheapest part in the whole timing assembly. (IMG:style_emoticons/default/sad.gif)
nmkimosabe
post Sep 17 2026, 06:53 PM
Post #54
QUOTE(Superhawk996 @ Sep 16 2026, 05:03 PM) *
@wonkipop
Easy right?
@Superhawk996
I've gained some valuable information from your posts, and I've distilled those into key points to discuss with my mechanic. They've also helped to improve my own understanding of these cars and will benefit me in the future. Stay tuned for future updates as we are getting close.
Superhawk996
post Sep 17 2026, 08:42 PM
Post #55
I apologize if I’m coming off a bit harsh. My end goal is to help and will do what ever I can to help.
These are pretty basic cars and you’ll get there
If you have questions ask and at a minimum we can get you pointed in the right direction. Sometimes it hard to ask when you dont know what you don’t know but seriously - everyone wants to see you succeed and enjoy your car. Just ask if you have questions or concerns.
nmkimosabe
post Sep 18 2026, 01:04 PM
Post #56
QUOTE(Superhawk996 @ Sep 17 2026, 08:42 PM) *
@Superhawk996
We're good and I do really appreciate your knowledge about these cars as it's proven beneficial to me already. I will definitely reach out for more advice. Have a good weekend.
fiacra
post Sep 20 2026, 12:37 PM
Post #57
Person.Woman.Man.Camera.TV.
Some great advice from @Superhawk996 and @Wonkipop , as usual. I will only disagree with one thing Superhawk said -- if you ask for advice I do think you have some nominal obligation to come back and let everyone know what happened. People who find themselves in the same situation in the future will benefit from seeing what worked to solve your problem and how you got there. For me, that is the main utility of this forum and it seems a small price to pay for asking for help. Gary has been diligent in updating this thread, and I'm hopefull he is just one step away from the finish line.
wonkipop
post Sep 20 2026, 02:18 PM
Post #58
QUOTE(fiacra @ Sep 20 2026, 12:37 PM) *
dead on mate (IMG:style_emoticons/default/beerchug.gif)
i hope gary and his mechanic get this nailed without too much further frustration and i am very keen to know exactly what the issue turns out to be. difficult to help from this distance so can only really point to possibilities. but whatever it is that plagued him could very well turn out to be important for L jet owners to know.
nmkimosabe
post Sep 23 2026, 04:12 PM
Post #59
QUOTE(wonkipop @ Sep 20 2026, 02:18 PM) *
I just heard from the mechanic, and he is asking for input on the following:
-The pump starts around 6 amps then climbs to 7.5-8 once fully warm (after over 20 minutes), and the relay box & wire terminals get fairly hot
-He needs a fuel pump amp/draw spec that can be verified (or pump resistance spec, either)
-We have torrential rain here so when it subsides he will perform a loaded fuel pressure test, but so far, pressure has stayed at approx. 34-35 PSI with the throttle open/regulator vacuum line disconnected.
-The car suffers from difficult hot-starting.
-Do you know of a source for a good OE cylinder head sensor or a good aftermarket one?
Superhawk996
post Sep 23 2026, 07:41 PM
Post #60
I don’t have a OEM 3 port pump on-site to measure. From Pelican:
Attached Image.
If push comes to shove I can go retrieve one from storage and measure but I think he’s chasing ghosts if you have 34psi.
Did he measure the CHT resistance both hot and cold or is the request for a CHT supplier just throwing parts at it?
“ The car suffers from difficult hot-starting.”. Why has he not given you more detail on why it’s having trouble - is getting spark? Is it rich, is it lean?
- Lo-Fi Version Time is now: 24th November 2026 - 09:09 PM
