| Nein For Teens |
Aug 1 2026, 11:20 PM
Newbie ![]() Group: Members Posts: 5 Joined: 1-August 24 From: San Diego Member No.: 28,269 Region Association: Southern California |
Hi Teener's. I'm converting a tail-shift transmission to side shifting. I have all the parts for the conversion . . . I think :-) My concern is how to clock the center-console rod into the bottom of the shifter so that the u-joint and the rear shift rod end up where they are meant to be? Is there a simply procedure to accomplish this? Both the engine and the trans are out of the car. Just FYI: I'm just about to install one of Chris Foley's firewall bushing kits. All other bushings will be urethane of bronze. Thanks in advance for whatever help is available. Chris
| Nein For Teens |
Aug 1 2026, 11:23 PM
D'oh! Clearly, I'm new at this. I should have posted this in the tech section. How can I migrate it over there?
| dug |
Aug 2 2026, 12:18 AM
914-6 conv in progress ![]() ![]() Group: Members Posts: 185 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California |
Put the trans selector in 2nd.
Then with the shift lever held gently against the first/rev spring, not compressing it, push the shifter forward so it slides onto the tunnel rod. |
| Montreal914 |
Aug 2 2026, 09:12 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,183 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
Clocking it will be done once the power train is all in. Install everything in the engine bay including all shift linkage, then slide in the shifter assembly lower coupling into the tunnel rod.
Last, do the procedure dug suggested. (IMG:style_emoticons/default/driving.gif) |
| Nein For Teens |
Aug 2 2026, 09:16 PM
{Insert palm to the forehead emoticon here} That makes perfect sense. Thanks guys.
| rhodyguy |
Aug 4 2026, 10:33 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Examine the reverse detent plate and the contact point on the shift lever for wear. If the underside of the shift lever housing is gunked up, clean it. Have you sourced the firewall conversion bushing yet?
Lo-Fi Version | Time is now: 15th August 2026 - 03:42 PM |
