Conversion Engine Wiring, Adapting engine to harness |
Qarl |
Aug 2 2003, 04:21 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I need to figure out how to wire up the engine (once it gets installed) to the main wiring harness for the six conversion
I have the internally regulated alternator so I won't be using the relay board. I have the 14-pin male connector that will plug into the main wiring harness. I just need to know what each pin is connected to... #1 through #14 (i.e., tach, alternator warning light, backup switch, etc.) Does anyone have any diagrams or the pin layout? Thanks, Karl |
redshift |
Aug 2 2003, 04:42 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Nope, I am sorry..
Your car is going to be way to nice for anyone to chance helping. (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/smash.gif) You must be contained! M -obviously kidding.. and no help- |
Qarl |
Aug 2 2003, 05:11 PM
I know it's on the PP site and I've searched but can't find it.
redshift |
Aug 2 2003, 05:35 PM
scotty |
Aug 2 2003, 06:00 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
Dang... where'd it go??? Well, here's what I did... I hope this helps more than it confuses.
Have fun. Scott =========== 914 14-pin..............................................911 14-pin to relay board.........................................from engine 1-ignition switch (yellow)........................1-ignition switch (yellow) 2-Alt. Light on dash (blue)......................11-alt. (blue) 5-oil warning light (green/red)................9-oil pressure switch (green/white) 914 #7-signal to tachometer (black/purple). I wired it directly to #C on cd ignition {yellow wire} from crane xr-700....) 914 #8-power for relays (power from fuse #9, signals ignition on, black) I routed this one to the front trunk where I've put in a relay board and fuse panelfor my (relocated) fuel pump, fog and driving lights. 911 #3-oil temp sender (green/black) wired to a wire that was separate from the 914 harness (green/black also, I think) that went to the oil temp guage on the appearance group harness. 911 #4-oil pressure sender (green/red) wired to a new wire I ran to the appearance group console. I wired 914 #3 and #4 directly to the reverse light switch, rather than use #5 and #6 on the 911 14-pin connection, since the PO had cut those off. Here are their colors/fuction: 3-reverse light switch (grey/brown) 5-reverse light switch (green/yellow) 4-reverse light switch (grey/brown) 6-reverse light switch (grey/brwn) I didn't use pins 9-14 on the 914, since I had an alternator with an internal regulator. Here's what they do: 9-heater blower switch (green/white) 10-ground for relay board (brown) 11-heater blower (green) 12-power from battery, no fuse (red) 13-fuel pump power (from relay on relay board, black-red) 14-power from battery (red) I also didn't use the following pins on the 911 14-pin harness: 2 (no wire), 7 (no wire), 8 (no wire), 10-realy to fuel pump, warm up regulator, aux air valve, thermo valve (red/white), 13-heter blower motor (yellow/black), or 14-B+ on alt. (red) |
Qarl |
Aug 2 2003, 06:02 PM
Scotty!
You da Man! Thanks! Karl |
MarkV |
Aug 2 2003, 07:50 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Have you looked at the engine harness that Jeff Bowlsby builds? He uses the correct wire & connectors & does a nice clean job. (IMG:style_emoticons/default/w00t.gif)
Lo-Fi Version | Time is now: 4th May 2024 - 01:46 AM |
