Conversion Engine Wiring, Adapting engine to harness |
Qarl |
Aug 2 2003, 04:21 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I need to figure out how to wire up the engine (once it gets installed) to the main wiring harness for the six conversion
I have the internally regulated alternator so I won't be using the relay board. I have the 14-pin male connector that will plug into the main wiring harness. I just need to know what each pin is connected to... #1 through #14 (i.e., tach, alternator warning light, backup switch, etc.) Does anyone have any diagrams or the pin layout? Thanks, Karl |
MarkV |
Aug 2 2003, 07:50 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Have you looked at the engine harness that Jeff Bowlsby builds? He uses the correct wire & connectors & does a nice clean job. (IMG:style_emoticons/default/w00t.gif)
Lo-Fi Version | Time is now: 18th May 2024 - 01:00 AM |
