| friethmiller |
Aug 14 2026, 02:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,618 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
Bought this from @914Sixer 4 years ago and I'm thinking about installing it in the LE. I'm sure it's not the exact radio for an LE but it might be the one I go with for now. Question: what are all these pieces, I forget. The metal tabs look like hanger-type hardware. How does it install? I'm wondering if I'm missing anything. (IMG:style_emoticons/default/idea.gif) What about these weird looking connections? Speaker inputs I assume. Is this other wire a ground? Sorry, not a radio expert. TIA. (IMG:style_emoticons/default/biggrin.gif)
| 914Sixer |
Aug 14 2026, 03:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,609 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Plug and play. You have to pull knobs and face off radio. Drop radio in hole. Slot the locking bars and tighten them up. Put a back strap on to support the radio. Ground for radio is back strap. Single black wire is for 12V + to switched source. Other two wires are for R & L speakers, they are marked on the case.
Yes it is a correct available radio for 1974 LE. Radio was introduced in 1972. |
| friethmiller |
Aug 14 2026, 03:58 PM
Plug and play. You have to pull knobs and face off radio. Drop radio in hole. Slot the locking bars and tighten them up. Put a back strap on to support the radio. Ground for radio is back strap. Single black wire is for 12V + to switched source. Other two wires are for R & L speakers, they are marked on the case. Yes it is a correct available radio for 1974 LE. Radio was introduced in 1972. Excellent! Thanks Mark. I sure hope I can get to it this weekend - if not very soon. (IMG:style_emoticons/default/beer.gif) |
| Shivers |
Aug 14 2026, 04:07 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,722 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Plug and play. You have to pull knobs and face off radio. Drop radio in hole. Slot the locking bars and tighten them up. Put a back strap on to support the radio. Ground for radio is back strap. Single black wire is for 12V + to switched source. Other two wires are for R & L speakers, they are marked on the case. Yes it is a correct available radio for 1974 LE. Radio was introduced in 1972. Excellent! Thanks Mark. I sure hope I can get to it this weekend - if not very soon. (IMG:style_emoticons/default/beer.gif) https://www.youtube.com/watch?v=pxgI29vM0YE |
| friethmiller |
Aug 14 2026, 09:15 PM
Plug and play. You have to pull knobs and face off radio. Drop radio in hole. Slot the locking bars and tighten them up. Put a back strap on to support the radio. Ground for radio is back strap. Single black wire is for 12V + to switched source. Other two wires are for R & L speakers, they are marked on the case. Yes it is a correct available radio for 1974 LE. Radio was introduced in 1972. Excellent! Thanks Mark. I sure hope I can get to it this weekend - if not very soon. (IMG:style_emoticons/default/beer.gif) https://www.youtube.com/watch?v=pxgI29vM0YE That helps! Thank you |
| gulf908 |
Aug 14 2026, 10:19 PM
Member ![]() ![]() Group: Members Posts: 132 Joined: 25-December 13 From: Sydney Member No.: 16,795 Region Association: Australia and New Zealand |
fm
I have one of these but 6 button - a little extravagance from a later year - 1978 what year code is yours ? these are worth a good detailed installation mine takes a minute or two to warm up properly also make sure you have a good aerial and good speakers - mine are from Konigs autoradio in Haan Germany HTH Dennis (IMG:style_emoticons/default/smile.gif) |
| Shivers |
Aug 15 2026, 11:13 AM
Plug and play. You have to pull knobs and face off radio. Drop radio in hole. Slot the locking bars and tighten them up. Put a back strap on to support the radio. Ground for radio is back strap. Single black wire is for 12V + to switched source. Other two wires are for R & L speakers, they are marked on the case. Yes it is a correct available radio for 1974 LE. Radio was introduced in 1972. Excellent! Thanks Mark. I sure hope I can get to it this weekend - if not very soon. (IMG:style_emoticons/default/beer.gif) https://www.youtube.com/watch?v=pxgI29vM0YE That helps! Thank you You are welcome Sir |
| scallyk9 |
Aug 15 2026, 04:10 PM
Member ![]() ![]() Group: Members Posts: 393 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest
I have the exact same Becker installed in my restored LE (Bumblebee) and it is period correct and would have been available from your local Porsche dealer in 1974. All radios were dealer installed and you chose from a rack. As I recall, Beckers on top, some Blaupunkts below them, and a Motorola or two on the bottom. The Becker Mexico FM Cassette deck was the most expensive.
A knowledgeable PCA Concours judge once told me that I had the Mercedes version with the chrome ring knobs and I should have plain black soft-touch knobs in a vintage Porsche, but a photo of the chrome ring version is in Dr. B. Johnson's 914 "A Restorer's Guide to Authenticity III" as a dealer option or owner installed. |
| Superhawk996 |
Aug 17 2026, 06:33 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,181 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
A knowledgeable PCA Concours judge once told me that I had the Mercedes version with the chrome ring knobs and I should have plain black soft-touch knobs in a vintage Porsche, but a photo of the chrome ring version is in Dr. B. Johnson's 914 "A Restorer's Guide to Authenticity III" as a dealer option or owner installed. Funny how that works. A bunch of snobs that never wanted to acknowledge the 914 as a Porsche are now suddenly experts on 914’s. (IMG:style_emoticons/default/barf.gif) (IMG:style_emoticons/default/headbang.gif) NARP forever (IMG:style_emoticons/default/aktion035.gif) |
| friethmiller |
Aug 17 2026, 11:04 PM
I have the exact same Becker installed in my restored LE (Bumblebee) and it is period correct and would have been available from your local Porsche dealer in 1974. All radios were dealer installed and you chose from a rack. As I recall, Beckers on top, some Blaupunkts below them, and a Motorola or two on the bottom. The Becker Mexico FM Cassette deck was the most expensive. A knowledgeable PCA Concours judge once told me that I had the Mercedes version with the chrome ring knobs and I should have plain black soft-touch knobs in a vintage Porsche, but a photo of the chrome ring version is in Dr. B. Johnson's 914 "A Restorer's Guide to Authenticity III" as a dealer option or owner installed. Good to hear this. I ordered a 2 din radio plate from 914 rubber thinking this would be the correct opening for this radio install. I don’t fully understand how to mount a face plate to the dash yet but I can’t see how it would work with the plate that has separate holes for the knobs. (IMG:style_emoticons/default/idea.gif) |
| friethmiller |
Aug 18 2026, 08:35 AM
fm I have one of these but 6 button - a little extravagance from a later year - 1978 what year code is yours ? these are worth a good detailed installation mine takes a minute or two to warm up properly also make sure you have a good aerial and good speakers - mine are from Konigs autoradio in Haan Germany HTH Dennis (IMG:style_emoticons/default/smile.gif) Dennis, First off, I think Aussies & Kiwis who own 914s are the best! (IMG:style_emoticons/default/first.gif) Not sure on the date code. Stickers are all gone. Any stampings are hard to read. Is there a place to look for this date? The speakers I want for this radio are a bit pricey and would come from Germany. Going to wait... just bought the final 3 tires for the LE. Trying to keep the expenditures under the wife's radar (IMG:style_emoticons/default/happy11.gif) |
| Ninja |
Aug 19 2026, 07:57 AM
Member ![]() ![]() Group: Members Posts: 323 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
| Ninja |
Aug 19 2026, 07:59 AM
What I really want to know is how are you going to fix the chrome "pops" on that surround?
You've been able to fix everything else... |
| friethmiller |
Aug 19 2026, 09:36 AM
What I really want to know is how are you going to fix the chrome "pops" on that surround? You've been able to fix everything else... Nothing more than #0000 steel wool on that item. It should make the "pops" less noticeable. Ninja, you sound like a "concourse weenie" (IMG:style_emoticons/default/lol-2.gif) |
| Ninja |
Aug 19 2026, 11:38 AM
What I really want to know is how are you going to fix the chrome "pops" on that surround? You've been able to fix everything else... Nothing more than #0000 steel wool on that item. It should make the "pops" less noticeable. Ninja, you sound like a "concourse weenie" (IMG:style_emoticons/default/lol-2.gif) But, you RESTORE like a concours weenie! (IMG:style_emoticons/default/first.gif) |
| scallyk9 |
Aug 19 2026, 09:17 PM
Both the glass pin stripe radio faceplate and the chrome surrounds are available from a Becker vendor and available on eBay. I had to purchase both for my Europa II Stereo.
Lo-Fi Version | Time is now: 18th November 2026 - 05:11 AM |
