| friethmiller |
Aug 14 2026, 02:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,612 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
Bought this from @914Sixer 4 years ago and I'm thinking about installing it in the LE. I'm sure it's not the exact radio for an LE but it might be the one I go with for now. Question: what are all these pieces, I forget. The metal tabs look like hanger-type hardware. How does it install? I'm wondering if I'm missing anything. (IMG:style_emoticons/default/idea.gif) What about these weird looking connections? Speaker inputs I assume. Is this other wire a ground? Sorry, not a radio expert. TIA. (IMG:style_emoticons/default/biggrin.gif)
| 914Sixer |
Aug 14 2026, 03:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,606 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Plug and play. You have to pull knobs and face off radio. Drop radio in hole. Slot the locking bars and tighten them up. Put a back strap on to support the radio. Ground for radio is back strap. Single black wire is for 12V + to switched source. Other two wires are for R & L speakers, they are marked on the case.
Yes it is a correct available radio for 1974 LE. Radio was introduced in 1972. |
| friethmiller |
Aug 14 2026, 03:58 PM
Plug and play. You have to pull knobs and face off radio. Drop radio in hole. Slot the locking bars and tighten them up. Put a back strap on to support the radio. Ground for radio is back strap. Single black wire is for 12V + to switched source. Other two wires are for R & L speakers, they are marked on the case. Yes it is a correct available radio for 1974 LE. Radio was introduced in 1972. Excellent! Thanks Mark. I sure hope I can get to it this weekend - if not very soon. (IMG:style_emoticons/default/beer.gif) |
| Shivers |
Aug 14 2026, 04:07 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,711 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Plug and play. You have to pull knobs and face off radio. Drop radio in hole. Slot the locking bars and tighten them up. Put a back strap on to support the radio. Ground for radio is back strap. Single black wire is for 12V + to switched source. Other two wires are for R & L speakers, they are marked on the case. Yes it is a correct available radio for 1974 LE. Radio was introduced in 1972. Excellent! Thanks Mark. I sure hope I can get to it this weekend - if not very soon. (IMG:style_emoticons/default/beer.gif) https://www.youtube.com/watch?v=pxgI29vM0YE |
| friethmiller |
Aug 14 2026, 09:15 PM
Plug and play. You have to pull knobs and face off radio. Drop radio in hole. Slot the locking bars and tighten them up. Put a back strap on to support the radio. Ground for radio is back strap. Single black wire is for 12V + to switched source. Other two wires are for R & L speakers, they are marked on the case. Yes it is a correct available radio for 1974 LE. Radio was introduced in 1972. Excellent! Thanks Mark. I sure hope I can get to it this weekend - if not very soon. (IMG:style_emoticons/default/beer.gif) https://www.youtube.com/watch?v=pxgI29vM0YE That helps! Thank you |
| Shivers |
Aug 15 2026, 11:13 AM
Plug and play. You have to pull knobs and face off radio. Drop radio in hole. Slot the locking bars and tighten them up. Put a back strap on to support the radio. Ground for radio is back strap. Single black wire is for 12V + to switched source. Other two wires are for R & L speakers, they are marked on the case. Yes it is a correct available radio for 1974 LE. Radio was introduced in 1972. Excellent! Thanks Mark. I sure hope I can get to it this weekend - if not very soon. (IMG:style_emoticons/default/beer.gif) https://www.youtube.com/watch?v=pxgI29vM0YE That helps! Thank you You are welcome Sir |
friethmiller Beautiful Becker Europa 2 Radio - My Stupid Questions Aug 14 2026, 02:13 PM
gulf908 fm
I have one of these but 6 button - a little ex... Aug 14 2026, 10:19 PM
friethmiller
fm
I have one of these but 6 button - a little e... Aug 18 2026, 08:35 AM
scallyk9 I have the exact same Becker installed in my resto... Aug 15 2026, 04:10 PM
Superhawk996
A knowledgeable PCA Concours judge once told me ... Aug 17 2026, 06:33 PM
friethmiller
I have the exact same Becker installed in my rest... Aug 17 2026, 11:04 PM
Ninja
Trying to keep the expenditures under the wife... Aug 19 2026, 07:57 AM
Ninja What I really want to know is how are you going to... Aug 19 2026, 07:59 AM
friethmiller
What I really want to know is how are you going t... Aug 19 2026, 09:36 AM
Ninja
What I really want to know is how are you going ... Aug 19 2026, 11:38 AM
scallyk9 Both the glass pin stripe radio faceplate and the ... Aug 19 2026, 09:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th November 2026 - 09:44 AM |
