> Transmission Mount Washer Spec
DennisV
post Aug 14 2026, 07:20 PM
Is there anything special about the washers for the M12 transaxle mounting bolts (i.e., thicker, larger OD)? Part number: 914-375-239-00. #39 in parts catalog diagram.
They appear to be NLA and I can't find a description or photo of them. Washers I have are 13 ID and 27 OD. Normal thickness.
Thank you.
Replies(1 - 5)
Luke M
post Aug 14 2026, 07:30 PM
Yes, they are special thick washers. Pm Bruce Stone I'm sure he has a few hanging around. (IMG:style_emoticons/default/beerchug.gif)
DennisV
post Aug 14 2026, 07:41 PM
QUOTE(Luke M @ Aug 14 2026, 06:30 PM) *
Sigh. Thanks. Good to know.
If anyone can share the spec that would be greatly appreciated. I'm going to install the engine tomorrow. I have a bag of thick washers I could potentially modify if I knew the correct thickness and OD.
Cairo94507
post Aug 19 2026, 08:10 AM
Michael
I recall them being about 3/16" thick. Good luck.
Flyinlow
post Aug 19 2026, 05:11 PM
Flyinlow
QUOTE(DennisV @ Aug 14 2026, 06:20 PM) *
Thank you.
Hi… the washers are 40 mm O.D. 12 mm I.D.and 5mm thick
DennisV
post Aug 20 2026, 08:47 AM
QUOTE(Flyinlow @ Aug 19 2026, 04:11 PM) *
Thank you.
Thank you! I'll add this info to the parts vault.
The one's I made were 41.7 mm OD, drilled to 12.7 ID, and a 4 thick washer. So I'll probably roll with this for the foreseeable future.
- Lo-Fi Version Time is now: 12th October 2026 - 09:59 AM
