> 74' 1.8 #2 is not firing?, asking for a friend
Type 47
post Aug 30 2026, 08:34 PM
L jet
original FI
also, installing an 123/Ignition distributor.
what is next step?
Replies(1 - 12)
Superhawk996
post Aug 30 2026, 08:48 PM
Need to determine what is missing the fuel or the spark
That plug on the bottom has previously fired as witnessed by carbon on threads and residue on electrodes but it also looks extremely lean.
If I were betting I’d put money on a clogged injector but you need to verify what’s missing and not trust a hunch.
Ninja
post Aug 30 2026, 09:12 PM
Not enough info yet...
What do the other plugs look like?
Does the fouled plug have a gap? Hard to tell in picture.
But, without any info...
Compression test
Ignition spark intensity test, color of spark across a 1/4" gap
Try another plug
Fuel tests, pressure, air leakage, maybe fuel quality (if old with alcohol in it).
Injector spray pattern tests
I agree with the Hawk, the lean plug would bug me.
How long has it been in?
When is the last time the car ran well?
Superhawk996
post Aug 30 2026, 09:37 PM
All good points
In the end what you have there are two plugs and neither looks normal.
One fouled rich
One running lean
Type 47
post Aug 30 2026, 09:50 PM
took plugs out and all were sooty, except #2.
took plugs out, emery clothed them, put them back in and same thing.
all sooty, except #2
clogged injector is a good thing to check!
JeffBowlsby
post Aug 30 2026, 10:06 PM
Being Ljet, be sure to check that all 4 wires on the resistor pack are intact on their resistors, and the harness grounds are in fact , well connected to ground.
Type 47
post Aug 31 2026, 05:40 PM
QUOTE(JeffBowlsby @ Aug 30 2026, 08:06 PM) *
OK will check next time I have a chance to go over to where the car is.
So I'm assuming L jet has tendencies to have ground issues, or am I reading too much into that?
JeffBowlsby
post Aug 31 2026, 08:13 PM
Not ground issues per se, but the injector wire attachments to the resistors are a known weakness, taking out each injector associated with a wire break.
StarBear
post Sep 1 2026, 06:05 AM
Had that a while ago, also on #2. The contact on the inside of the dizzy cap was dirty, so no spark. Cleaned it and all ok.
Still the over rich condition, too. Inside cap cleaning wouldn’t hurt that either.
rfinegan
post Sep 1 2026, 07:15 AM
swap 1-2 injectors and see if the problem follow the swap to 1..
no cost and can be done wit simple hand tools it 10-15 mins
do you hear it miss firing? duh, duh, duh, duh....etc
Type 47
post Sep 1 2026, 08:51 AM
QUOTE(StarBear @ Sep 1 2026, 04:05 AM) *
new cap
Type 47
post Sep 1 2026, 08:52 AM
QUOTE(rfinegan @ Sep 1 2026, 05:15 AM) *
great idea!
L-Jet914
post Sep 2 2026, 06:54 PM
If you have access to noid lights, you can connect one to #2 injector connector. Disable fuel and crank the engine over and see if the noid light illuminates. That will tell you if it's activating that injector.
- Lo-Fi Version Time is now: 4th September 2026 - 02:20 PM
