> P.O mystery wiring
bajafreaks
post Aug 31 2026, 05:39 PM
The P.O owner of my car has done a few odds things as I'm discovering during the restoration. Heres the latest, any reason why they would splice this large red wire into the harness? I cut it but you can see in the pics where it spliced to the two main harnesses.
Shivers
post Aug 31 2026, 09:21 PM
These are from another thread here. Yellow has something to do with the starter solenoid. Maybe stealing power there.
Dlee6205
post Sep 1 2026, 05:28 AM
My guess is the PO installed an aftermarket switch for starting the car. It's common to have poor connections, high resistance in the ignition circuit and maybe adding a backup switch was their solution.
bajafreaks
post Sep 1 2026, 07:46 AM
QUOTE(Dlee6205 @ Sep 1 2026, 04:28 AM) *
Not sure where they would add a switch? the red wire was spliced into the yellow wire which per Shivers diagram that goes to the starter relay and then ties into the main body harness, I guess i need to see what wire its tied to at that harness.
- Lo-Fi Version Time is now: 15th September 2026 - 12:46 PM
