| jeff dodge |
Sep 1 2026, 02:07 PM
Newbie ![]() Group: Members Posts: 39 Joined: 5-September 24 From: middleton,WI Member No.: 28,332 Region Association: None |
My 1.8 fuel injected only pops when deceleration. Any ideas ? Thanks, Jeff
| Shivers |
Sep 1 2026, 03:19 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,578 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
| jeff dodge |
Sep 1 2026, 03:37 PM
My 1.8 fuel injected only pops when deceleration. Any ideas ? Thanks, Jeff Might be an exhaust leak. I had one at the head, the copper gasket was leaking and it made all sorts of racket at decel. I think that you might be right. I asked one other Porsche mechanic and he thought this was the most obvious culprit. Thanks, Jeff |
| orthobiz |
Sep 1 2026, 03:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,774 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest
My 1.8 does this also. As best I can tell it's benign, my mechanic could never get rid of it.
Paul |
| Jack Standz |
Sep 1 2026, 04:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 915 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
There is a decel (deceleration) valve that allows extra air into the motor for emissions and to suppress backfiring on deceleration. Suggest testing this as part of your troubleshooting process.
| wonkipop |
Sep 1 2026, 04:47 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,703 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
likely unburnt fuel popping in the muffler.
my 1.8 does it. for a reason. but only when its still cold or coldish, not after its fully warmed up. ........ got rid of the decel valve a long time ago. the decel valve is the original solution for burning up fuel during deceleration. brought the engine down to idle in a two step slower and burnt that fuel during slowdown. without decel valve it can tend to dump some fuel. if its just popping in the muffler its harmless. ie if its not real loud genuine backfires but just popping. some here will say the car needs the decel. i wouldn't argue with them. but i do know this. the D jets and L jets down here from that era have no decel valves (the VWs and mercs from late 60s and early 70s). the USA cars did have them ------my view primarily for emissions. |
| brant |
Sep 1 2026, 04:49 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,272 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Agreed
Most common cause of popping Anneal the gaskets (glowing red) and let the cool without water before re- installation (No quenching) |
Lo-Fi Version | Time is now: 9th September 2026 - 09:48 PM |
