| Shivers |
Sep 22 2026, 11:36 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,601 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
This is the front suspension from my 72 that I am putting in Howard. This one is straight, I do not have another. The adjuster cap on one side fell off as soon as I removed the adjuster bolt. The other side is holding it position like it's from Texas.
And the arm I could get off the torsion bar is stuck fast. I need to get the bars out without harming the splines or heating it up so much it takes the spring out of the bars. I'm sure this is semi common so I'd sure appreciate hearing how you managed to get yours loose. So would Howard. (IMG:style_emoticons/default/biggrin.gif) Thanks ![]() ![]() ![]() |
| Cfletch |
Sep 22 2026, 11:58 AM
Member ![]() ![]() Group: Members Posts: 255 Joined: 30-January 14 From: Santa Barbara Member No.: 16,941 Region Association: Southern California |
The back side has a plug of sorts that can be removed and later installed if I'm not mistaken, you can then use a punch and a hammer to hit it out of its home from the back side. Its probably slightly rusted into the splines, giving you a hard time removing it.
| Shivers |
Sep 22 2026, 12:12 PM
| Shivers |
Sep 22 2026, 12:18 PM
| 914werke |
Sep 22 2026, 12:25 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,754 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
The (IMG:style_emoticons/default/agree.gif) |
| Shivers |
Sep 22 2026, 12:36 PM
The (IMG:style_emoticons/default/agree.gif) Roger that. Thanks guys I will give it a go. |
| Shivers |
Sep 22 2026, 01:09 PM
Gaaads. Well I’m shaking it boss, but that plug is not wanting to play fair. I concaved it with a ball peen which gave me gaps then tried to rotate the cap with a punch. No love. What am I missing?
Attached thumbnail(s) |
| Shivers |
Sep 22 2026, 01:13 PM
There is one nagging question that came up as I was hammering on that plug. If this is what I need to do to get it out, how in heck do you get it back in?
| Patrick_139 |
Sep 22 2026, 01:28 PM
Newbie ![]() Group: Members Posts: 29 Joined: 2-March 24 From: Claremont Member No.: 27,975 Region Association: Southern California |
Since you won't be reusing that plug, I would suggest inserting a screw into it and using that for leverage to pull the cap off. Or drill a hole in the plug and then use a screwdriver to pry it out. It's a $5 part.
| Patrick_139 |
Sep 22 2026, 01:32 PM
| Shivers |
Sep 22 2026, 02:42 PM
I got them
| Shivers |
Sep 22 2026, 02:45 PM
Well hahaha, I ended up grabbing my brass mallet and hitting it from the back side a couple wacks and that plug ended up somewhere in my backyard. Cleaned the splines with oil and a wire brush and removed the rust soup with a paper towel. I dipped that same end into a tube of grease and slid it back into the splines. Then it was just grab the brass drift and send the torsion bar back the way it came.
Thanks everyone (IMG:style_emoticons/default/smile.gif) 900-040-008-01 cap part number |
| Superhawk996 |
Sep 22 2026, 04:59 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,077 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
| SirAndy |
Sep 22 2026, 07:01 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,520 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
When in doubt, BFH ...
(IMG:style_emoticons/default/smash.gif) |
| rjames |
Sep 22 2026, 09:41 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,475 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
Are you sure those bars are in good enough condition to be put back in service?
| Shivers |
Sep 22 2026, 11:04 PM
Are you sure those bars are in good enough condition to be put back in service? Remember when all that Weltmeister stuff came through here in the early 90’s. I got sway bars, torsion bars and springs from George. But then life happened and I only put a few thousand miles on it. There are no gouges or unauthorized machining. Most of the rust came off with oil and a wire brush. I hit it with the circular brush and the splines look new. So I am good with the way they look. Thanks |
Lo-Fi Version | Time is now: 23rd September 2026 - 02:08 AM |
