| morehills |
Sep 27 2026, 07:34 AM
Member ![]() ![]() Group: Members Posts: 151 Joined: 2-March 23 From: Great Barrington, MA Member No.: 27,202 Region Association: North East States
Not sure how the clip works and the bulb is tight and not removable from the front. Do I have to pull the assembly to get this bulb out? Thanks, John
| NARP74 |
Sep 27 2026, 08:42 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,572 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Should be a push down and twist type bulb connection.
Probably just corrosion from dissimilar metals. Try some lube spray of some kind. Work it in. Use a cloth, the bulb will probably break from the base. Might need pliers to get the base out after the glass comes out. Or remove both left and right assemblies and trade me for two "normal" ones without the extra bulb! |
Lo-Fi Version | Time is now: 27th September 2026 - 06:09 PM |
