| Literati914 |
Sep 29 2026, 04:15 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,390 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
This is the module sold by JWest for allowing you to run with the fog-lights on at anytime, both with and without headlights on (like modern running lights). It also allows the driver to “dip” their lights as a warning - like during passing on a two lane, etc. I purchased it used, never installed and have no install instructions. $63 shipped.
Attached thumbnail(s) |
| PCH |
Sep 29 2026, 06:30 PM
Member ![]() ![]() Group: Members Posts: 153 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California
Great product. I have installed one on my 71. It allows you to flash your fog lights when the headlights are off.
| DC_neun_vierzehn |
Sep 30 2026, 03:51 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
I have this kit but haven’t gotten around to installing it yet. I should be able to make a copy of the instructions and share as a PDF if they are needed.
| s13u74cr4 |
Sep 30 2026, 03:34 PM
Member ![]() ![]() Group: Members Posts: 54 Joined: 2-September 23 From: PNW Member No.: 27,558 Region Association: Pacific Northwest |
Want it! PMed!
| Literati914 |
Oct 1 2026, 07:09 AM
Replied. Now Pending to @s13u74cr4
| s13u74cr4 |
Oct 1 2026, 10:35 PM
| jim_hoyland |
Oct 3 2026, 12:06 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,142 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Mine:
| s13u74cr4 |
Oct 9 2026, 04:02 PM
| jim_hoyland |
Oct 9 2026, 08:15 PM
Mine: Thanks much! Can't wait to try this out. What's the sentence that is cut off at the bottom there of your diagram? Installation Instructions: 1. Disconnect the battery. 6. 7. Connect the new gray wire to the original gray/red wire and reconnect both to the fog light switch. ADDITIONAL OPTION: The fog light switch is originally wired so that the fog lights can only be turned on while the headlights are on. To enable the fog lights to be turned on with the headlights off, disconnect the blue/black wire from the fog light switch and replace with the new blue wire. If this option is not desired, leave the original blue/black wire connected and the blue wire is not used. (NOTE: The flash feature will operate the same either way.) 8. Tape the end of the unused wire from step 7. 9. Reinstall the fog light switch. 10. Connect the new brown wire to the grounding post near the fuse panel. 11. Disconnect the yellow/red wire from the headlight relay (silver cube-shaped) on the fuse panel. Connect the new yellow wire to the end of this wire and the new green wire to the headlight relay at the “S” terminal from which the yellow/red wire was removed. 12. Connect the new red wire and the original red/white wire to position “56” of the headlight relay. 13. Connect the new black wire to fuse #9 on the fuse box, on the fused side (toward the front of the car). 14. Secure the module with the included tie wrap in a convenient position, such as along the main harness. 15. Replace the fuse panel, connect the battery, and enjoy being able to flash your lights! |
Lo-Fi Version | Time is now: 14th October 2026 - 11:21 AM |
