| Maltese Falcon |
Sep 30 2026, 01:04 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,396 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
If you take part in forced induction Day, enjoy the 930 (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving-girl.gif)
| 930cabman |
Sep 30 2026, 04:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,849 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Yes indeed, aka widowmaker
It took me awhile to have the guts to run WOT, and its a rush for sure enjoy safely |
| Spoke |
Sep 30 2026, 07:54 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,430 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
My '86 930 is in the final phase of engine restore at The 9 Store.
Internal engine parts replaced: camshaft flange cover dowel pin for cam gear barrel nut for camshaft oil line camshaft oil line restrictor alternator shim washer camshaft thrust washer rod bearing set #8 nose bearings camshaft drive gear woodruff key main bearing set head studs - canyon engine gasket set - case engine gasket set - heads oil pressure relief valve plug for oil pressure relief valve guide sleeve for oil pressure relief spring for oil pressure relief valve lock plate oil return tubes exhaust valves intake valves rocker arm shaft fuel injector intake manifold flange intermediate shaft bearings rocker arm shaft bolt bushing for rocker shaft bolt nut for rocker shaft bolt rocker arm shaft o-ring timing chain timing chain rail (5) timing chain rail (1) valve adjusting screw mahle p & c's oil line banjo bolt New SC turbo cams Refurbished rockers Rocker locks Other items replaced/restored Turbo refurbish New engine electrical harness Crank-fired Coil on Plug Clewett Flat Fan Belt Fuel distributor refurbish Replace tin rubber gaskets Transmission restore New clutch/PP/clutch cable Replace heat flappers PMB restore of all 4 calipers CVJ Axles Restore half shafts Spokeworks RTS-Brake modules lock rear turnsignal and brake together Attached image(s)
| infraredcalvin |
Sep 30 2026, 08:28 AM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,774 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
| 930cabman |
Sep 30 2026, 09:24 AM
How does it go, date Italian, marry ......
nobody ever said a 930 is a cheap date, but they do rock like no other (IMG:style_emoticons/default/piratenanner.gif) |
Lo-Fi Version | Time is now: 30th September 2026 - 12:09 PM |
