| Cvrguy |
Oct 1 2026, 01:15 PM
Newbie ![]() Group: Members Posts: 48 Joined: 18-September 25 From: Los Angeles Member No.: 28,995 Region Association: None |
I had all of the instrument lights go out on me recently. Is there a single ground point for them? If so, where is it? I checked the defrost light wire aft of the shifter. That's not the problem.
| JeffBowlsby |
Oct 1 2026, 01:42 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,366 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Probably the ground behind the fuse panel, drivers side. You might also have a dash light subharness that could be disconnected, its not very long, is behind the dash gauges, look for any of the black/blue striped wires to find the common single connector to the main chassis harness.
| FlacaProductions |
Oct 1 2026, 01:52 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,284 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
the common black/blue striped line was the one i was going to suggest - it runs thru all the dash lights - if there is a gap "early" in the chain, they all go
| emerygt350 |
Oct 2 2026, 06:03 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,780 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I had the pot go in my headlight switch. Lost all the dash lights. Rather than muck with it (I mean, they are so damn dim even with LEDs, why a dimmer?) I just bypassed the pot on the switch and have them just full on when I pull the lights.
The pot went before I upgraded to the LEDs. Sadly, you have to pull the knee guard to get at the switch otherwise it would be an easy thing to check. |
| JamesM |
Oct 2 2026, 10:56 AM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,328 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
| Cvrguy |
Oct 2 2026, 10:57 AM
thanks to all
| Cvrguy |
Oct 2 2026, 11:17 AM
The car came with a JWest fuse panel installed by a PO. When I lowered it, the common ground point was obvious. This rectangular flasher fell out from above the lower bolster. There is also a flasher module on the back of the fuse panel. Any idea which is which? What is the empty relay supposed to feed?
Lo-Fi Version | Time is now: 15th October 2026 - 01:46 PM |
