| mtndawg |
Oct 1 2026, 08:05 PM
Member ![]() ![]() Group: Members Posts: 425 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None
I’m installing these 911 struts. What kind of hardware is needed to attach these rotors to the hubs? Do I need to use locktite?
Attached thumbnail(s) |
| sixaddict |
Oct 1 2026, 09:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,090 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
The hub is not shown in pics……it goes on spindle and is secured with nut shown in picture.
| sixaddict |
Oct 1 2026, 09:48 PM
| mtndawg |
Oct 1 2026, 10:06 PM
Here’s a photo with the hub. What hardware is used to attach the rotor where the screwdriver is inserted? Do I have this right?
| pfreiburger |
Oct 1 2026, 10:53 PM
Member ![]() ![]() Group: Members Posts: 155 Joined: 6-October 20 From: Fond du Lac, WI Member No.: 24,738 Region Association: None
Hello - I don't know what year your 911 parts are, but a 70-73 uses M8x22 bolts, M8 hex nuts and spring washers. The Porsche # is 900-075-079-02, but any of the fastener supply vendors (also AA, etc.) can supply good ones, a couple of bucks a throw or less. The originals were a grade 8.8, so get at least that - I might be tempted to go to 10.9. Cheers!
| Retroracer |
Oct 2 2026, 05:28 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 669 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest
..also check the manual for the correct torque on those. Would suggest high temp Loctite as well.
- Tony |
| sixaddict |
Oct 2 2026, 05:51 AM
Tony..
For my education, how difficult is it to remove mounting bolts if locktite is used. I’ve never used it in this area……. Thanks |
| mtndawg |
Oct 2 2026, 09:50 PM
Here we go, grade 10 with wave washer m8 x 25 since that’s what they had, fits perfectly. Needing new wedge pins to get closer to install.
Lo-Fi Version | Time is now: 14th October 2026 - 10:45 AM |
