2 Pages V < 1 2
> 914 Rubber Bumper Tops, Back in Stock - New Molds?
PCH
post Nov 2 2026, 08:31 PM
Post #21
I had trouble with my new front bumper top. My 914 is a 71 so it may be a early bumper issue.
I solved the fit issue by removing bumper top material on the inside of the ends at the bend. That improved things enough to glue the bumper top corners to the bumper. not ideal and a lot of work but it did the trick.
PCH
post Nov 2 2026, 08:34 PM
Post #22
And here's the result after triming the front bumper top and gluing it to the bumper.Attached Image Attached Image
frank_c
post Nov 2 2026, 11:29 PM
Post #23
QUOTE(Matty900 @ Oct 30 2026, 01:50 PM) *
Hey, guys, I have an update
We just produced 50 sets of the internal metal for them and will start producing them, and should have some stock back in for Black Friday.
Hi Matt,
Thanks very much for the clarification on the new mold topic and the update on availability.
I've been waiting for these to become available so that I can complete my bumper backdate project. Once I get the in-stock notice, I'll be sure to order the F&R kit the same day and not to wait a few days like last time.
-Frank
post Nov 3 2026, 05:14 AM
Post #24
914-6 GT in waiting
Hey, guys, I have an update. The issue with the bumper tops that I think was the conversation about a new tool that was floating around had to do with a production run that had an issue and how they were released from the tool. We had been out of these for a while, and when we had a production run, they were immediately sold out, with everyone who had them on their wish list. We just produced 50 sets of the internal metal for them and will start producing them, and should have some stock back in for Black Friday.
The issue with the over-tightening and pushing the side out I have a video on that I believe addresses the issue; I just need to find it, and I will post it here. I do want to know if this works for you or if you are seeing something else that I am missing.
Sorry Matt but it's not an over tightening issue. It's a design/production issue. They don't fit correctly. Match them up against an original one and you will see.
Mikey914
post Nov 3 2026, 10:40 AM
Post #25
The rubber man
QUOTE(Steve @ Oct 3 2026, 03:15 PM) *
If you do a search, there was some workarounds for the ends sticking out. Put washers under the studs on the ends and worse case drill holes in your bumper and use sheet metal screws to pull the ends in. Washers didn’t help my situation and I wasn’t going to drill holes in my bumper.
a lot of folks don't understand that there are rubber washers needed to set the height correctly, In fact when we started making them. They often look like part of the old bumper as they've been compressed onto the bumper for decades, but they are needed.
I'm out of the loop at this point, but we had started including them at one point.
The original molds were made from nos unmounted bumpers, so they were identical to the factory as the molds were made from them.
I think what you experience with the auto Atlanta bumper tops is that it is a harder plastic like material that will not compress easily, so the spacers aren't needed???
2 Pages V < 1 2
- Lo-Fi Version Time is now: 18th November 2026 - 05:52 AM
