| PCH |
Oct 7 2026, 01:55 PM
Member ![]() ![]() Group: Members Posts: 156 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California
Hi everyone:
I recently had my 1971 914/4 derusted and repainted. I am currently putting all the bits and pieces back together and have been working on the headlights. On the driver side I have a later model motor driving the headlight and on the passenger side I have an earlier model motor driving the headlight. Both motors work. However, as I cycled the headlights multiple times, I found that the passenger side headlight would need to automatically recycle itself to reposition itself to be in the same position as the passenger headlight. Both headlight actuators have new 914 rubber bushings. It seems that the driver side headlight is a little slower in its movement than the passenger side headlight. At a magical point it seems like the driver’s side headlight is far enough off that it will then cycle itself to get into the same position as the earlier passenger side headlight. I have adjusted the lever arm multiple times thinking that I had seated the arm perhaps a spline off, but that doesn’t seem to change anything. After a deep dive in what may cause this, I ran across a comment (I could not verify), that the early and later motors have different internals and turn at slightly different speeds. Does anyone know if this is true? I have not yet tried switching relays to see if the problem is in the relay. I am wondering, if perhaps the bushings are tighter on one arm than the other, whichwould possibly cause the engine on the driver side to turn slower. Does anyone else have any recommendations regarding what tests I should run to see to troubleshoot this problem. Any thoughts would be greatly appreciated. Thank you in advance, Peter |
Lo-Fi Version | Time is now: 8th November 2026 - 05:53 AM |
