> 3.0 cooling option
RKramden
post Oct 19 2026, 09:50 AM
I think I know the general response, but I’ll ask anyway.
Putting a 3.0 performance built (premium pump gas) into the 914.
No intention of racing. Maybe an auto cross or track night, or terrorize the neighborhood, but mostly C&C and PCA events.
No heat exchangers ( So.Cal), an oversized oil tank in the engine bay, and a 916-6 type engine lid.
In lieu of a remote oil cooler I was considering changing the fresh air fan piping to blow back through the heater longs up through the tins and outlet right next to the engine cooling fan inlet space. Or possibly just blow on either side of motor below the tins.
I’m wondering if this has ever been done successfully or if the idea makes any sense at all? Any thoughts or suggestions would be appreciated
brant
post Oct 19 2026, 10:04 AM
The heater fan is really an insignificant amount of air
The -6 engine fan is likely 10x the amount of air already
I don’t think it will help to any noticeable amount
If the car/engine runs cool (low rpm) you may be fine without an aux cooler. If the oil runs warm you won’t. Some do. Usually depends on the amount of wear the motor already has or how it’s used-rpm
post Oct 19 2026, 10:06 AM
914-6 GT in waiting
The fresh air fan hardly moves any air in the cabin. It's not going to do anything to cool the engine.
Are you ever going to be going up a hill on a hot day? Stopped at a light for a while or stuck in a traffic jam on the road with the asphalt radiating heat up into the car.
Superhawk996
post Oct 19 2026, 12:32 PM
(IMG:style_emoticons/default/agree.gif) both the above are correct
You cannot offset oil cooling with more air cooling.
The primary reason being the heat transfer coefficient of air is (IMG:style_emoticons/default/stromberg.gif) compared to oil. Oil cooling is about 10x more efficient than air cooling. This is why the 911 engine has an oil cooler in the first place and why all the S performance variants ran an aux cooler in addition to the engine mounted oil cooler.
Though the engine is called air cooled, it is heavily cooled by oil in addition to the cooling done by fan.
IronHillRestorations
post Oct 20 2026, 07:29 AM
I. I. R. C.
You won’t get enough airflow from the fresh air blower to help.
You might consider adding an oil cooler like this: Rear fender oil cooler
post Oct 20 2026, 09:58 AM
914-6 GT in waiting
Do the conversion, drive it. If it needs more cooling, figure out the best way to accomplish it with your budget and goals. You probably will need additional cooling but it’s not a sure bet. Some engines run cooler than others.
Sometimes it’s better to have a running car that needs mods that a project car that doesn’t move.
Superhawk996
post Oct 20 2026, 10:42 AM
QUOTE(mepstein @ Oct 20 2026, 11:58 AM) *
That’s some real wisdom there and didn’t cost you a dime. (IMG:style_emoticons/default/aktion035.gif)
pete-stevers
post Oct 20 2026, 02:39 PM
Shinee Side Up
My recommendation split for the external cooler up front with a Mocal 180 degree thermostat... Eric Shea has a great system... How much is that 3.0 worth? sometime you just have to split for it! (IMG:style_emoticons/default/biggrin.gif)
JmuRiz
post Oct 20 2026, 02:50 PM
QUOTE(mepstein @ Oct 20 2026, 07:58 AM) *
(IMG:style_emoticons/default/idea.gif) I resemble that remark (IMG:style_emoticons/default/wacko.gif)
Cairo94507
post Oct 20 2026, 03:52 PM
Michael
A 3.0 in southern CA is likely going to need an external oil cooler to be able to drive worry free in the summer or while sitting in stop/go traffic on the freeway. It's a bit of work but does not have to be overly complicated. Lots of threads here with different solutions that work. Good luck and enjoy the 3.0. (IMG:style_emoticons/default/beerchug.gif)
mb911
post Oct 20 2026, 07:48 PM
Build it first get it running add a cooler in the non driving season if needed. Do you guys in Cali have a non driving season? We are forced to here
Steve
post Oct 21 2026, 08:00 AM
QUOTE(mb911 @ Oct 20 2026, 06:48 PM) *
Not really.. It doesn't rain enough to have an off season. Just a couple seasons when you don't need AC.
I agree with others, So Cal is very toasty in the summer and this will need an external oil cooler during that time. You might get a way with a cooler and fan next to the trans. The 3.0 and 3.2 run much cooler than the smaller magnesium motors.
RKramden
post Oct 22 2026, 07:07 PM
Thank you all for your inputs. Ill be adding a remote cooler. Any thoughts on the oil tank size? Will the oversized PMB in fender model be enough or do I need more capacity?
post Oct 22 2026, 07:25 PM
914-6 GT in waiting
Oil tank - Definitely Ben’s/MB911/914-6Werkshop.com
Total capacity with a cooler is about 11 quarts.
RKramden
post Nov 2 2026, 05:47 PM
Based on my usage noted at the beginning of this thread, is there a need for a “catch can” in this system?
930cabman
post Nov 2 2026, 05:51 PM
QUOTE(RKramden @ Nov 2 2026, 06:47 PM) *
Never a bad idea, not much to go wrong with them and they keep things cleaned up
mb911
post Nov 3 2026, 08:34 PM
QUOTE(RKramden @ Nov 2 2026, 03:47 PM) *
Yes always otherwise where does the oil vapor go? Into the carbs? Yuck
worn
post Nov 3 2026, 11:30 PM
QUOTE(JmuRiz @ Oct 20 2026, 12:50 PM) *
Well, we all, or many of us do. I run a heat exchanger in the space behind the right axle. Have run the 3.2 in 100 degree weather on the 80 mph interstate without trouble. Haven’t tried stop and go under those conditions and hope not to.
- Lo-Fi Version Time is now: 15th November 2026 - 01:20 AM
